Hello
after the latest Cinnamon bug was solved with latest update I could no longer use my key-shortcuts to probably send current app on another workspace. Checked it twice, but the keys are still defined ( for example [Super] + [
] to send it on the next workspace ) and re-defining them doesn't solve the issue.
Wondering if anybody else got this issue or using keys for specific tasks on Cinnamon?
Kernel: 5.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=3acd578e-46d5-4b3e-b159-d07795e6e296 rw rootflags=subvol=@
Desktop: Cinnamon v: 5.4.2 tk: GTK v: 3.24.34 info: plank wm: Mutter
dm: LightDM v: 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: M5A99FX PRO R2.0 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2501
date: 04/07/2014
Info: model: AMD FX-8350 bits: 64 type: MT MCP arch: Piledriver
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 8 smt: enabled cache: L1: 384 KiB
desc: d-8x16 KiB; i-4x64 KiB L2: 8 MiB desc: 4x2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1803 high: 3539 min/max: 1400/4000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1714 2: 3539
3: 1405 4: 1404 5: 1404 6: 1403 7: 1649 8: 1913 bogomips: 64212
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN 4 process: GF 14nm
built: 2016-20 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: DP-1,DVI-D-1 empty: DP-2,HDMI-A-1,HDMI-A-2
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 869x285mm (34.21x11.22")
s-diag: 915mm (36.01")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: right model: BenQ G922HDL
serial: <filter> built: 2009 res: 1366x768 hz: 60 dpi: 85 gamma: 1.2
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
max: 1366x768 min: 640x480
Monitor-2: DP-1 mapped: DisplayPort-0 pos: primary,left
model: AOC e2752Vq serial: <filter> built: 2013 res: 1920x1080 hz: 60
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
OpenGL: renderer: AMD Radeon RX 480 Graphics (polaris10 LLVM 13.0.1 DRM
3.46 5.18.6-zen1-1-zen)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.18.6-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 09:00.0 chip-ID: 10ec:8168
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
ID-2: swap-2 type: partition size: 3.73 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 28.2 C mobo: N/A gpu: amdgpu temp: 61.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1211
Processes: 368 Uptime: 5m wakeups: 0 Memory: 15.53 GiB
used: 3.66 GiB (23.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 2066
lib: 532 flatpak: 0 Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.19
Garuda (2.6.4-1):
System install date: 2021-12-06
Last full system update: 2022-06-24
Thanks.
