Hello,
I just upgraded to cinnamon 5.4 a couple of hours ago. After restart, the desktop is not launching properly. It seems that the window manager doesn't start. I can open a terminal and type muffin, I get back the window borders and desktop effects, but I don't get the panel (cinnamon doesn't seem to be running).
I'm lost.
Thanks.
Hello and welcome in the Garuda Forum!
I've got issues with kwin as well. Based on the last update. I needed to use my 'before update' snapshot.
If I type "cinnamon --replace",
it fails with
"failed to init X11 display : failed to acquire window manger ownership"
Please post the output of:
Kernel: 5.17.15-lqx1-1-lqx arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: audit=0 intel_pstate=disable hpet=disable
BOOT_IMAGE=/@/boot/vmlinuz-linux-lqx
root=UUID=12847d82-8bc9-483a-8997-3e72f1e31635 rw rootflags=subvol=@
nvidia-drm.modeset=1 quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 ibt=off
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: 1: GDM v: 42.0 note: stopped 2: LightDM v: 1.30.0
Type: Desktop Mobo: Micro-Star model: B550M-A PRO (MS-7C96) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.81
date: 05/25/2022
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen+ gen: 2
built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2479 high: 2835 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2415 2: 2420
3: 2835 4: 2413 5: 2481 6: 2409 7: 2447 8: 2416 9: 2631 10: 2475 11: 2414
12: 2402 bogomips: 76794
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
v: 515.48.07 alternate: nvidiafb,nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 4 ports: active: none
off: DVI-D-1 empty: HDMI-A-1 bus-ID: 2b:00.0 chip-ID: 10de:1d01
compositor: xfwm v: 4.16.1 driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0.0 screens: 1
s-diag: 610mm (24")
Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled
model: Idek Iiyama PLE2483H serial: <filter> built: 2015 res: 1920x1080
hz: 60 dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: NVIDIA GP108 High Definition Audio vendor: Gigabyte
bus-ID: 2b:00.1 chip-ID: 10de:0fb8 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.17.15-lqx1-1-lqx running: yes
Local Storage: total: 2.73 TiB used: 945.42 GiB (33.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: <filter> rev: 054 scheme: GPT
model: WD20EZBX-00AYRA0 size: 1.82 TiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 128 GiB size: 128 GiB (100.00%) used: 57.8 GiB (45.2%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 803.01 GiB size: 803.01 GiB (100.00%)
used: 216.22 GiB (26.9%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 128 GiB size: 128 GiB (100.00%)
used: 57.8 GiB (45.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 128 GiB size: 128 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 1.2 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 39%
Processes: 394 Uptime: 5m wakeups: 0 Memory: 15.56 GiB
used: 3.66 GiB (23.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 alt: 11 clang: 13.0.1 Packages: 2131
pacman: 2093 lib: 412 flatpak: 14 snap: 24 Shell: Zsh v: 5.9
running-in: xfce4-terminal inxi: 3.3.18
Garuda (2.6.3-2):
System install date: 2022-02-01
Last full system update: 2022-06-18
Failed units: bluetooth-autoconnect.service systemd-oomd.socket
I have also this error in .xsession-errors
JS ERROR: Error: No signal 'switch-workspace-complete' on object 'CinnamonWM'
It looks like you are running XFCE, not Cinnamon. Can you explain what's going on here?
Yes I'm running xfce since I can't start Cinnamon.
Which DE was installed first on this system?
Cinnamon. I installed using cinnamon iso.
It was OK until this Cinnamon 5.4 update earlier today.
What happens if you reinstall Cinnamon?
sudo pacman -S cinnamon
I reinstalled cinnamon (BTW there was an update a few minutes ago, 5.4.0-2), but it doesnt' change anything.
paru -Rcn garuda-cinnamon-settings
did the trick!
Update : there seems to be a bug with the panel smart hide feature. If I re-enable it, Cinnamon crashes.
If there is a bug/regression in Cinnamon then rolling back to a previous snapshot and/or downgrading that specific package is a valid approach until the software is fixed.
I'm having the same issue, i get this message after an update
Problems during cinnamon startup
Cinnamon started successfully, but one or more applets, desklets or extensions failed to load.
Check your system log and the cinnamon lookinglass log for any issues. You can disable the offending extension in cinnamon settings to prevent this message from recurring. Please contact the developer.
Then i cannot use any cinnamon settings or related settings apps
Lookinglass shows some applet errors but on a fresh install with removed applets and then the update it still makes no difference.
Restarting cinnamon or restoring cinnamon defaults stops it entirely with a blank screen.
I will check if this command works though.
Are you referring to the 'intelligently hide panel' feature? I have this disabled but still have the same issue.
Do you know what does this though?
Yes. This option normally makes the panel to hide when overlapped by a window. "Hide panel automatically" doesn't cause any problem.
I reinstalled garuda-cinnamon-settings and it didn't crash after that. This seems related to the panel smart hide feature, I opened an issue on github, seems that I am not the only one.
opened 04:28PM - 18 Jun 22 UTC
Cinnamon version - 5.4.0-2
* Distribution - Garuda Linux (arch)
* Graphics h… ardware *and* driver used - gt 1030, nvidia proprietary 515.48.07-2
* 64 bit
Hello,
the panel smart hide feature seems to cause Cinnamon crash in 5.4:
