Hello, curious if anyone can give me some guidance on what to do next here. Installed updates and during kernel install my laptop plug got jiggled which sometimes shuts it down. I know thats an issue to solve, but another day...
Since this time i have to boot using a snapshot because the main boot menu item is broken. kernel file seems to be missing.
I have tried to install grub boot repair for garuda from pacman. didnt help.
I tried just updating within the snapshot...that didnt work.
I tried restoring to a few days old snapshot but that does not fix this issue either. it seems the boot parameters are outside the snapshot system.
What i would like to do is repair the default grub options so the original system will boot up without having to manually select a snapshot to boot from. Is it possible to do that? Thanks.
╰─λ inxi -Fxxxza
Kernel: 5.11.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2021-03-22_12-18-13/@/boot/vmlinuz-linux-zen
root=UUID=eb9481f5-69a8-41f6-b77e-1882b00a8fb7 pci=nocrs quiet splash
resume=UUID=920cfba5-ba13-4f96-b357-8534e49a7196 loglevel=3
rootflags=defaults,noatime,space_cache,autodefrag,compress=zstd,ssd,subvol=timeshift-btrfs/snapshots/2021-03-22_12-18-13/@
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 80FG v: Lenovo Z70-80 serial: <filter>
Chassis: type: 10 v: Lenovo Z70-80 serial: <filter>
Mobo: LENOVO model: Lenovo Z70-80 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO
v: ABCN95WW date: 07/31/2015
ID-1: BAT0 charge: 31.8 Wh (100.0%) condition: 31.8/37.6 Wh (84.5%) volts: 16.2
min: 14.4 model: Lenovo IdeaPad type: Unknown serial: <filter> status: Full
Info: Dual Core model: Intel Core i7-5500U bits: 64 type: MT MCP arch: Broadwell
family: 6 model-id: 3D (61) stepping: 4 microcode: 2F cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 19155
Speed: 2638 MHz min/max: 500/3000 MHz Core speeds (MHz): 1: 2638 2: 2756 3: 2470
4: 2391
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 840M] vendor: Lenovo driver: nouveau v: kernel
bus-ID: 04:00.0 chip-ID: 10de:1341 class-ID: 0302
Device-3: Syntek Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 2-6:4
chip-ID: 174f:14be class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 128 size: 380x210mm (15.0x8.3")
diag: 434mm (17.1")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.11.8-zen1-1-zen running: yes
Sound Server-3: JACK v: 0.125.0 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.24 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168
vendor: Lenovo driver: ath10k_pci v: kernel port: 4000 bus-ID: 03:00.0
chip-ID: 168c:003e class-ID: 0280
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 2-7:5 chip-ID: 0cf3:e300 class-ID: e001
Report: ID: hci0 state: down bt-service: enabled, running address: <filter>
Local Storage: total: 894.25 GiB used: 21.83 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 5100 MTFDDAK960TCB
size: 894.25 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: U051 scheme: GPT
ID-1: / raw-size: 885.19 GiB size: 885.19 GiB (100.00%) used: 21.83 GiB (2.5%)
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 546 KiB (0.2%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 885.19 GiB size: 885.19 GiB (100.00%) used: 21.83 GiB (2.5%)
ID-4: /var/log raw-size: 885.19 GiB size: 885.19 GiB (100.00%)
used: 21.83 GiB (2.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 885.19 GiB size: 885.19 GiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
ID-2: swap-2 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
ID-3: swap-3 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
System Temperatures: cpu: 70.0 C mobo: N/A
Processes: 229 Uptime: 22m wakeups: 1 Memory: 7.68 GiB used: 3.66 GiB (47.6%)
Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0
Packages: pacman: 1591 lib: 356 Shell: Zsh v: 5.8 running-in: alacritty
inxi: 3.3.03
