[KERNEL BUG] - mt7921e - Wifi not working - (another ASUS Vivobook}
Hello. I've recently installed Garuda Linux on my ASUS Vivobook 15. After installing Garuda, the wifi was fine on the first boot. I was able to find and connect to my wifi network. I've updated the system with sudo pacman -Syu and rebooted and then the wifi stopped working. The network manager cannot find any wifi to connect to. I tried reinstalling Garuda but to no avail. I've currently switched from the linux-zen kernel to linux-lts and the wifi works again. Is there a way to use wifi while sticking to the linux-zen kernel?
inxi
Kernel: 5.15.18-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6b9b1581-851d-48e8-aefd-50c43c9df285 rw rootflags=subvol=@
resume=UUID=627ec95c-1cbb-46d5-b209-fc50f8eee503 loglevel=3
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513EAN_X513EA
Mobo: ASUSTeK model: X513EAN v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: X513EAN.201 date: 05/31/2021
ID-1: BAT0 charge: 34.1 Wh (79.9%) condition: 42.7/42.1 Wh (101.5%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x88
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 918 high: 1150 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1015 2: 631 3: 769
4: 998 5: 1051 6: 836 7: 896 8: 1150 bogomips: 44851
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.18-1-lts running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-5: PipeWire v: 0.3.44 running: yes
Device-1: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel port: N/A
bus-ID: 0000:02:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-10:4 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 476.94 GiB used: 17.92 GiB (3.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 004C
temp: 34.9 C scheme: GPT
used: 17.92 GiB (3.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.45 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3000
Processes: 264 Uptime: 9m wakeups: 1273 Memory: 7.45 GiB
used: 2.48 GiB (33.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1346 lib: 323 Shell: fish
Garuda (2.5.3-1):
System install date:     2022-02-01
Last full system update: 2022-02-01
Failed units:            dev-binderfs.mount systemd-networkd-wait-online.service
Hi there, welcome.
It should be this known bug.
You'll have to wait for a solution in v5.16.5 or next...
https://bbs.archlinux.org/viewtopic.php?id=273620
Just to make sure, the bug is from the regular linux kernel and therefore affects linux-zen right?
I definitely think so
in addition to the Arch Linux forums posted above by @ filo, also see
and
It should be fixed in 5.17 (mainline) I guess, but am not sure, as neither of users responded back…
No worries. I'll just stick to lts until it's updated
Possible fix:
https://askubuntu.com/questions/1380400/no-wifi-adapter-found-on-ubuntu-20-04-3-lts
Oh I forgot to update this situation. I updated my system around a week ago and linux-zen got updated. Now my wifi works again with the kernel.
Hello.
Kernel: 5.16.16-lqx2-1-lqx arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: audit=0 intel_pstate=disable hpet=disable
BOOT_IMAGE=/@/boot/vmlinuz-linux-lqx
root=UUID=8c94e2ac-ccc3-4a87-9561-eaf3706a13d8 rw rootflags=subvol=@
resume=UUID=bfb26db0-2770-4e94-9a7e-ca390fe33b5a loglevel=3
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 info: latte-dock
ID-1: BAT0 charge: 41.3 Wh (100.0%) condition: 41.3/42.1 Wh (98.1%)
status: not charging cycles: 11
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x9A
Speed (MHz): avg: 3019 high: 3918 min/max: 400/2701 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3129 2: 3026
3: 3006 4: 3918 5: 3230 6: 2536 7: 2280 8: 3033 bogomips: 44851
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
driver: i915 v: kernel ports: active: eDP-1 empty: HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
bus-ID: 1-6:4 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x0903 built: 2019
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.16.16-lqx2-1-lqx running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:7961 class-ID: 0280
bus-ID: 1-10:5 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 2.29 TiB used: 150.75 GiB (6.4%)
temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD My Passport 25E1 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1015 scheme: GPT
used: 150.75 GiB (32.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.46 GiB used: 1.06 GiB (14.3%)
System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (RPM): cpu: 4100
Processes: 309 Uptime: 29m wakeups: 666 Memory: 7.46 GiB
used: 3.15 GiB (42.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1734 lib: 491 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date:     2022-03-18
Last full system update: 2022-03-25 ↻
Failed units:            systemd-networkd-wait-online.service systemd-oomd.socket
Hello. I’ve posted about a month ago about having my laptop not detecting wifi networks after boot. It still occurs for me. I use the Liquorix kernel normally and this is what I have to do to fix it:
Boot into grub, select linux-lqx in advanced menu, the system says network disconnected and can’t connect to wifi
Reboot into grub menu, select the default linux-zen kernel, the system will freeze up and the caps lock light indicator will start to blink
Hold the power button to turn off laptop and boot back into linux-lqx, wifi works again.
As you can see I essentially have to boot my laptop three times just to get wifi to work. I already tried wiping and installing fresh but to no avail. Is there a fix so that I don’t have to do this this everytime I boot?
What happens if you boot into lqx, then reboot into lqx again (skip the zen boot)?
Try the linux-mainline kernel.
Just to note, the Qualcomm Atheros AR93xx Wireless Network Adapter or Ath9k also has issues with the latest kernels. I am following the bug here and here.
Luckily, I had an extra USB wifi adapter in the meantime.
If I skip the zen boot then nothing changes. Wifi still won't be detected when booting into lqx again.
I booted into lqx just to have the wifi not work, then I booted to mainline and the screen froze like zen does. I'm guessing if I booted straight into mainline/zen there'd be no problems, though I'll have to test that at some point.
I'm guessing this bug affects more than one adapter, including mine? My issue is weird though. It's not like wifi is completely broken. I just have to reboot into different kernels and then it's fixed for a while, though when I turn it on again after some time the issue comes back again...
Not sure what they did with wifi and the kernels. My guess, regression bugs because I have experienced the same issue many years ago.
With mine, I have wifi, but testing it, it suddenly drops down in speed. It also will completely stall if you try and download say a large file, mostly affecting 5G, 2G not as bad but still an issue.
When you boot and wifi is not working, have you compared your running modules against the modules when it is working? Same for the network, compare working vs non-working.
Post a working wifi and non-working wifi pair of each of these commands:
hwinfo --netcard --bluetooth | grep -Ei "(speed|hotplug|model|status|cmd|file|detected|driver:)" | grep -v "Config S"
lsmod |sort
Here's the output when wifi doesn't work:
  Model: "MEDIATEK Network controller"
    Driver Status: mt7921e is active
    Driver Activation Cmd: "modprobe mt7921e"
8250_dw                16384  0
ac97_bus               16384  1 snd_soc_core
acpi_cpufreq           20480  0
acpi_pad               24576  0
acpi_tad               20480  0
acpi_thermal_rel       16384  1 int3400_thermal
aesni_intel           380928  4
af_alg                 28672  6 algif_hash,algif_skcipher
agpgart                40960  5 intel_agp,intel_gtt,radeon,ttm,nouveau
algif_hash             16384  1
algif_skcipher         16384  1
amdgpu               7417856  0
asus_nb_wmi            28672  0
asus_wmi               45056  1 asus_nb_wmi
blake2b_generic        20480  0
bluetooth             524288  46 btrtl,hidp,btintel,btbcm,bnep,btusb,rfcomm
bnep                   20480  2
bridge                339968  0
btbcm                  24576  1 btusb
btintel                40960  1 btusb
btrfs                1703936  1
btrtl                  20480  1 btusb
btusb                  57344  0
cec                    81920  2 drm_kms_helper,i915
cfg80211             1015808  4 mt76,mac80211,mt7921_common,mt76_connac_lib
cmac                   16384  3
coretemp               16384  0
crc16                  16384  1 bluetooth
crc32c_generic         16384  0
crc32c_intel           24576  2
crc32_pclmul           16384  0
crct10dif_pclmul       16384  1
cryptd                 28672  3 crypto_simd,ghash_clmulni_intel
crypto_simd            16384  1 aesni_intel
crypto_user            16384  0
dm_mod                163840  0
drm                   593920  16 gpu_sched,drm_kms_helper,amdgpu,radeon,drm_ttm_helper,i915,ttm,nouveau
drm_kms_helper        319488  4 amdgpu,radeon,i915,nouveau
drm_ttm_helper         16384  3 amdgpu,radeon,nouveau
dw_dmac                16384  0
ecdh_generic           16384  2 bluetooth
efi_pstore             16384  0
enclosure              16384  1 ses
fat                    90112  1 vfat
fuse                  159744  1
ghash_clmulni_intel    16384  0
gpu_sched              53248  1 amdgpu
hid_multitouch         28672  0
hidp                   28672  0
i2c_algo_bit           16384  4 amdgpu,radeon,i915,nouveau
i2c_designware_core    32768  1 i2c_designware_platform
i2c_designware_platform    16384  0
i2c_hid                28672  1 i2c_hid_acpi
i2c_hid_acpi           16384  0
i2c_i801               32768  0
i2c_smbus              16384  1 i2c_i801
i915                 3096576  25
idma64                 20480  0
igen6_edac             24576  0
int3400_thermal        16384  0
int3403_thermal        16384  0
int340x_thermal_zone    16384  2 int3403_thermal,processor_thermal_device
intel_agp              24576  0
intel_gtt              24576  2 intel_agp,i915
intel_lpss             16384  1 intel_lpss_pci
intel_lpss_pci         28672  2
intel_pmc_bxt          16384  1 iTCO_wdt
intel_pmt              16384  0
intel_powerclamp       16384  0
intel_rapl_common      24576  2 intel_rapl_msr,processor_thermal_rapl
intel_rapl_msr         16384  0
intel_soc_dts_iosf     16384  1 processor_thermal_device_pci_legacy
intel_spi              16384  1 intel_spi_pci
intel_spi_pci          16384  0
intel_tcc_cooling      16384  0
ipmi_devintf           20480  0
ipmi_msghandler        65536  1 ipmi_devintf
ip_tables              32768  0
irqbypass              16384  1 kvm
iTCO_vendor_support    16384  1 iTCO_wdt
iTCO_wdt               16384  0
joydev                 24576  0
kvm                  1060864  1 kvm_intel
kvm_intel             348160  0
ledtrig_audio          16384  2 snd_hda_codec_generic,snd_sof
libarc4                16384  1 mac80211
libcrc32c              16384  1 btrfs
llc                    16384  2 bridge,stp
loop                   32768  3
mac80211             1036288  3 mt76,mt7921_common,mt76_connac_lib
mc                     57344  4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
mei_hdcp               20480  0
mei_pxp                16384  0
Module                  Size  Used by
mousedev               24576  0
mt76                  106496  3 mt7921e,mt7921_common,mt76_connac_lib
mt76_connac_lib        49152  2 mt7921e,mt7921_common
mt7921_common          86016  1 mt7921e
mt7921e                32768  0
mtd                    77824  3 spi_nor,intel_spi
mxm_wmi                16384  1 nouveau
nfnetlink              20480  0
nls_cp437              20480  1
nls_utf8               16384  1
nouveau              2428928  0
pinctrl_tigerlake      32768  0
platform_profile       16384  1 asus_wmi
pmt_class              16384  1 pmt_telemetry
pmt_telemetry          16384  0
processor_thermal_device    16384  1 processor_thermal_device_pci_legacy
processor_thermal_device_pci_legacy    16384  0
processor_thermal_mbox    16384  2 processor_thermal_rfim,processor_thermal_device
processor_thermal_rapl    16384  1 processor_thermal_device
processor_thermal_rfim    16384  1 processor_thermal_device
qrtr                   49152  4
radeon               1691648  0
raid6_pq              122880  1 btrfs
rc_core                53248  1 cec
rfcomm                 53248  16
rfkill                 32768  8 asus_wmi,bluetooth,cfg80211
rng_core               16384  1 tpm
scsi_transport_sas     49152  1 ses
serio_raw              16384  0
ses                    20480  0
snd                   110592  16 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_sof,snd_timer,snd_compress,snd_soc_core,snd_pcm
snd_compress           20480  1 snd_soc_core
snd_hda_codec         167936  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda
snd_hda_codec_generic    86016  1 snd_hda_codec_realtek
snd_hda_codec_hdmi     65536  1
snd_hda_codec_realtek   151552  1
snd_hda_core          110592  9 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda
snd_hda_ext_core       32768  3 snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda
snd_hda_intel          53248  1
snd_hrtimer            16384  1
snd_hwdep              16384  1 snd_hda_codec
snd_intel_dspcfg       24576  2 snd_hda_intel,snd_sof_intel_hda_common
snd_intel_sdw_acpi     16384  2 snd_sof_intel_hda_common,snd_intel_dspcfg
snd_pcm               147456  10 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_compress,snd_soc_core,snd_hda_core,snd_pcm_dmaengine
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_seq                81920  7 snd_seq_dummy
snd_seq_device         16384  1 snd_seq
snd_seq_dummy          16384  0
snd_soc_acpi           16384  2 snd_soc_acpi_intel_match,snd_sof_intel_hda_common
snd_soc_acpi_intel_match    61440  2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
snd_soc_core          319488  4 soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda
snd_soc_hdac_hda       20480  1 snd_sof_intel_hda_common
snd_sof               131072  2 snd_sof_pci,snd_sof_intel_hda_common
snd_sof_intel_hda      16384  1 snd_sof_intel_hda_common
snd_sof_intel_hda_common    86016  1 snd_sof_pci_intel_tgl
snd_sof_pci            16384  2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
snd_sof_pci_intel_tgl    16384  0
snd_sof_xtensa_dsp     16384  1 snd_sof_intel_hda_common
snd_timer              40960  3 snd_seq,snd_hrtimer,snd_pcm
soundcore              16384  1 snd
soundwire_cadence      32768  1 soundwire_intel
soundwire_generic_allocation    16384  1 soundwire_intel
soundwire_intel        40960  1 snd_sof_intel_hda_common
sparse_keymap          16384  1 asus_wmi
spidev                 20480  0
spi_nor                86016  1 intel_spi
spi_pxa2xx_platform    28672  0
squashfs               57344  1
stp                    16384  1 bridge
tpm                    86016  3 tpm_tis,tpm_crb,tpm_tis_core
tpm_crb                16384  0
tpm_tis                16384  0
tpm_tis_core           24576  1 tpm_tis
ttm                    81920  5 amdgpu,radeon,drm_ttm_helper,i915,nouveau
uas                    28672  0
uinput                 20480  0
usbhid                 53248  0
usb_storage            73728  1 uas
uvcvideo              122880  0
vfat                   24576  1
video                  49152  3 asus_wmi,i915,nouveau
videobuf2_common       65536  4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
videobuf2_memops       16384  1 videobuf2_vmalloc
videobuf2_v4l2         36864  1 uvcvideo
videobuf2_vmalloc      16384  1 uvcvideo
videodev              270336  3 videobuf2_v4l2,uvcvideo,videobuf2_common
wmi                    32768  4 asus_wmi,wmi_bmof,mxm_wmi,nouveau
wmi_bmof               16384  0
x86_pkg_temp_thermal    16384  0
xhci_pci               20480  0
xhci_pci_renesas       16384  1 xhci_pci
xor                    24576  1 btrfs
x_tables               49152  1 ip_tables
zram                   36864  2
And here's with wifi:
  Model: "MEDIATEK WLAN controller"
  Driver: "mt7921e"
  Device File: wlo1
  Link detected: yes
8250_dw                16384  0
acpi_pad               24576  0
acpi_tad               20480  0
aesni_intel           380928  8
af_packet              53248  8
algif_hash             16384  1
amdgpu               7417856  0
asus_nb_wmi            28672  0
bnep                   20480  2
bridge                339968  0
btbcm                  24576  1 btusb
btrfs                1703936  1
btrtl                  20480  1 btusb
btusb                  57344  0
ccm                    20480  6
cmac                   16384  3
coretemp               16384  0
crypto_user            16384  0
dm_mod                163840  0
dw_dmac                16384  0
efi_pstore             16384  0
fat                    90112  1 vfat
fuse                  159744  1
hidp                   28672  0
i2c_i801               32768  0
i915                 3096576  25
idma64                 20480  0
igen6_edac             24576  0
intel_agp              24576  0
intel_pmt              16384  0
ip_tables              32768  0
iTCO_wdt               16384  0
joydev                 24576  0
kvm_intel             348160  0
loop                   32768  3
mei_hdcp               20480  0
mei_pxp                16384  0
Module                  Size  Used by
mousedev               24576  0
mt7921e                32768  0
nfnetlink              20480  0
nls_cp437              20480  1
nls_utf8               16384  1
nouveau              2428928  0
qrtr                   49152  4
radeon               1691648  0
rc_core                53248  1 cec
rfcomm                 53248  16
rfkill                 32768  9 asus_wmi,bluetooth,cfg80211
serio_raw              16384  0
ses                    20480  0
snd_hrtimer            16384  1
spidev                 20480  0
squashfs               57344  1
stp                    16384  1 bridge
tpm_crb                16384  0
tpm_tis                16384  0
uas                    28672  0
uinput                 20480  0
usbhid                 53248  0
uvcvideo              122880  0
vfat                   24576  1
wmi_bmof               16384  0
xhci_pci               20480  0
xor                    24576  1 btrfs
zram                   36864  2
