Hello! I'm new to Linux, second day actually. I installed the latest version of Garuda dragonized on a partition and loved it! It played all my games really well and I had no issues.
The only problem seemed to start when I tried to boot back to windows to transfer some files over and the wifi stopped working on Garuda. Looking around it seems like Garuda doesn't work well with windows dual booting. Woops.
The Wifi still works on windows just fine and my bluetooth headphones and mouse still work on Garuda.
So far I've tried.
Disabling mac randomization and restarting the wifi module on Garuda Network assistant.
Disabling windows power saving on the wifi card in Device Manager.
Reinstalling Garuda (The live USB doesn't detect wifi either)
Switching to Garuda Xfce live usb (Doesn't detect wifi either)
Restarting, shutdown or holding the power button and swapping between windows and Garuda repeatedly.
Leaving my laptop unplugged and powered down for a time (7 hours)
adding pcie_aspm=off
to the end of GRUB_CMDLINE_LINUX_DEFAULT
in /etc/default/grub
Terminal Text
OS: Garuda Linux
Host: ROG Strix G513QY_G513QY 1.0
Kernel: 5.16.3-zen1-1-zen
Uptime: 22 secs
Packages: 1802 (pacman)
Shell: bash
DE: Plasma 5.23.5
WM: KWin
WM Theme: Sweet-Dark
Terminal: konsole
CPU: AMD Ryzen 9 5900HX with Radeon Graphics (16) @ 3.3GHz
GPU: AMD ATI Radeon RX 6700/6700 XT / 6800M
GPU: AMD ATI 07:00.0 Cezanne
Memory: 2.04GiB / 15.10GiB
Here is the full output of "sudo inxi -Fxxxza"
Host: tom-rogstrixg513qyg513qy Kernel: 5.16.3-zen1-1-zen x86_64 bits: 64
compiler: gcc v: 11.1.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=49cbabf1-bf20-4cca-b788-29b2923c2d3e rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: ROG Strix G513QY_G513QY v: 1.0
Mobo: ASUSTeK model: G513QY v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G513QY.316 date: 11/29/2021
ID-1: BAT0 charge: 88.9 Wh (100.0%) condition: 88.9/90.0 Wh (98.8%)
volts: 17.4 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion serial: 03B3
status: Full
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1502 high: 2240 min/max: 1200/4889 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1466 2: 1394
3: 1396 4: 1395 5: 1395 6: 2195 7: 2240 8: 1397 9: 1397 10: 1395 11: 1394
12: 1397 13: 1395 14: 1395 15: 1396 16: 1396 bogomips: 105400
IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0380
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 300 dpi: 142
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.3-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 03:00.1
chip-ID: 1002:ab28 class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 1002:1637
Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.3-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: 7c:10:c9:23:ea:d3
Device-2: MEDIATEK vendor: AzureWave driver: N/A modules: mt7921e
port: N/A bus-ID: 05:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF-ID-1: anbox0 state: down mac: b6:80:74:1a:32:b7
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-4:2 chip-ID: 13d3:3563 class-ID: e001 serial: 000000000
Report: bt-adapter ID: hci0 rfk-id: 0 state: up
address: EC:2E:98:71:D4:D8
Local Storage: total: 596.45 GiB used: 329.73 GiB (55.3%)
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: S6F5NE0R295396
rev: FXM7201Q temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Samsung
model: Flash Drive FIT size: 119.51 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: 0360921060018443 rev: 1100 scheme: MBR
ID-1: / raw-size: 158.19 GiB size: 158.19 GiB (100.00%)
used: 60.41 GiB (38.2%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 25.8 MiB (26.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 158.19 GiB size: 158.19 GiB (100.00%)
ID-4: /var/log raw-size: 158.19 GiB size: 158.19 GiB (100.00%)
ID-5: /var/tmp raw-size: 158.19 GiB size: 158.19 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.1 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
GPU: device: amdgpu temp: 47.0 C device: amdgpu temp: 50.0 C mem: 44.0 C
fan: 6 watts: 13.00
Processes: 417 Uptime: 3m wakeups: 4 Memory: 15.1 GiB
used: 2.22 GiB (14.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1802 lib: 546 Shell: fish
sudo rfkill list all output
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
I searched the forums and the wiki, but nothing seemed to work for me/directly pertain to my system. Hope I formatted all that right lol
tbg
30 January 2022 01:41
2
Welcome to the Garuda community @TomFoolerly .
A couple of suggestions:
Make sure fastboot is disabled in Windows, the power down and do a cold boot.
If that didn't work, then resetting the bios to the factory default is likely going to be necessary.
Yeah sorry, should of mentioned that. Fast boot and secure boot are both disabled.
I tried Manjaro kde plasma on live usb and it connected to wifi.
Yeah I'll try that. Do you happen to know what's going on specifically? So I know what to look out for.
tbg
30 January 2022 01:56
4
I just had a second look at your output, and I believe your issue is similar to a problem I have encountered once before.
Just wait on the bios reset, I think I know what's causing this, but I need to check my notes.
I loading up the UEFI menu and hit "reset to factory default"
Booted up Garuda, no change.
tbg
30 January 2022 02:12
6
Did you install the program anbox
Do you have any anbox
kernel versions installed?
I don't know if you need anbox
, but that program is likely going to need to be uninstalled to fix your wifi issue.
To uninstall anbox
issue this command:
sudo pacman -Rns anbox-support anbox-git
Then reboot.
Then please post:
inxi -naz
After rebooting hopefully your WiFi is active again.
No such luck
I don't remember installing anbox
but I ran the command and it appeared to remove it.
I rebooted and nothing changed. I tried running the sudo pacman -Rns anbox-support anbox-git
command again and this time it said nothing was found. I tried resetting the wifi module with garuda network assistant as well and nothing.
Here's the output from
inxi -naz
Fan Speeds (RPM): cpu: 2500
GPU: device: amdgpu temp: 50.0 C mem: 46.0 C fan: 61 watts: 16.00
device: amdgpu temp: 46.0 C
tbg
30 January 2022 03:11
8
Please post:
grep -r "blacklist\|install\|options" /etc/modprobe.d/ /etc/modules-load.d/ /usr/lib/modprobe.d/
Yeah no problem.
/usr/lib/modprobe.d/amdgpu.conf:options amdgpu ppfeaturemask=0xffffffff
/usr/lib/modprobe.d/systemd.conf:options bonding max_bonds=0
/usr/lib/modprobe.d/systemd.conf:options dummy numdummies=0
/usr/lib/modprobe.d/nvdimm-security.conf:install libnvdimm /usr/bin/ndctl load-keys ; /sbin/modprobe --ignore-install libnvdimm $CMDLINE_OPTS
/usr/lib/modprobe.d/bluetooth-usb.conf:options btusb reset=1
/usr/lib/modprobe.d/nobeep.conf:blacklist pcspkr
/usr/lib/modprobe.d/noime.conf:blacklist mei
/usr/lib/modprobe.d/noime.conf:blacklist mei_me
tbg
30 January 2022 03:20
10
Try:
sudo systemctl stop NetworkManager; sudo modprobe -r mt7921e; sudo modprobe -vr mt7921e; sudo systemctl start NetworkManager
I assume it worked there was no output. It said "took 4 seconds"
Tried rebooting, no change.
tbg
30 January 2022 03:31
12
You should have run the new garuda-inxi
command given in our help request template, as that would have told me if tlp
was installed on your system.
is tlp
installed on your system?
Try starting your laptop with the power unplugged.
Oh sorry I'm dumb. When I read that in the template my brain thought it was an example of how to structure my request.
Here's the output of garuda-inxi
Kernel: 5.16.3-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
pcie_aspm=off
ID-1: BAT0 charge: 89.0 Wh (100.0%) condition: 89.0/90.0 Wh (98.9%)
volts: 16.6 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
Speed (MHz): avg: 1396 high: 1397 min/max: 1200/4889 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1397 2: 1397
3: 1397 4: 1396 5: 1397 6: 1397 7: 1395 8: 1396 9: 1395 10: 1397 11: 1396
12: 1395 13: 1396 14: 1396 15: 1397 16: 1395 bogomips: 105400
bus-ID: 3-4:2 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 596.45 GiB used: 60.48 GiB (10.1%)
rev: FXM7201Q temp: 31.9 C scheme: GPT
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
used: 60.46 GiB (38.2%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
Fan Speeds (RPM): cpu: 2400
GPU: device: amdgpu temp: 46.0 C device: amdgpu temp: 50.0 C mem: 44.0 C
fan: 6 watts: 11.00
Processes: 398 Uptime: 0m wakeups: 4 Memory: 15.1 GiB
used: 2.04 GiB (13.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1796 lib: 545 Shell: fish
Garuda:
System install date: 2022-01-28
Last full system update: 2022-01-28
Using TLP: No
Oh yeah sorry. No change.
tbg
30 January 2022 03:58
16
My best guess is this is likely a bios, firmware, or kernel issue.
You need to check if a bios update is available for your laptop and install it if there is.
Install linux-firmware-git
, reboot.
If not working after rebooting, again run:
Then check your wifi for any differences.
If still no improvements, you will need to test some alternate kernels. Start by installing and testing the linux-mainline
kernel. If no better luck, then test the linux
kernel as well. Also try the linux-xanmod-rog
kernel. The last hope might be linux-next-git
if those kernels don't help.
I'm not quite sure what further to suggest if none of those suggestions pan out, (so hopefully one will work).
Hey hopefully it works. I'll try it tomorrow and see what happens. Thanks for the help
tbg
30 January 2022 04:42
18
Usually I watch the Arch Wifi issues carefully, but I missed one from yesterday claiming a kernel update broke your driver. They also claim downgrading the kernel will fix it.
https://bbs.archlinux.org/viewtopic.php?id=273620
Uhhh, how do I downgrade a kernel on Arch? I saw some posts about it online but they all seemed to be for Ubuntu. Reading around it seems 5.16.1 would be the best for me.
I tried putting in sudo pacman -Syu linux-lts linux-lts-headers
But that seems to require wifi
Naman
30 January 2022 17:34
20
Hi, see
https://wiki.archlinux.org/title/Downgrading_packages
You may also want to use snapper to restore snapshot.
Also, after downgrading/restoring snapshot maybe you would like to test Linux-mainline, that is based on 5.17, rc1, and is precompiled in Chaotic AUR. Maybe this bug has been fixed in it, but am not sure.
