trying to install Garuda but every time I load it with Nvidia drivers it always gets stuck on
"Starting Terminate Plymouth Boot Screen..."
Welcome
Check you have fast boot and secure boot disabled in your bios
both are disabled
Can you provide your
from the live usb
Also will it install not using proprietary drivers
it does install using open source just not the proprietary option. and you able to run me through how I do that?
The live environment is what you are booted into on the USB stick before you install. To run the command, just type garuda-inxi in the terminal, simple as that. You can open a browser from the live environment and log in to the forum to paste the output of the command.
I can't get onto the live environment though I can't access the terminal as it won't boot when I select proprietary. it does seem to boot into open source though. should i just boot into that option and post my garuda-inxi from there
Yes. The output may be helpful for determining why you cannot boot proprietary.
You might want to try installing from there. Worry about the friggen Ndumbia drivers subsequent to first boot, post install.
Kernel: 5.16.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
misobasedir=garuda misolabel=GARUDA_DR460NIZEDGAMING_WHITETAI quiet
systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.3 info: latte-dock wm: kwin_x11
Type: Laptop System: PC Specialist product: NH5xAx v: N/A
serial: <superuser required> Chassis: Notebook type: 10
Mobo: CLEVO model: NH5xAx serial: <superuser required> UEFI: Insyde
v: 1.07.07TPCS date: 06/03/2020
ID-1: BAT0 charge: 54.4 Wh (100.0%) condition: 54.4/62.1 Wh (87.5%)
volts: 12.3 min: 10.9 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
Info: model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3483 high: 3757 min/max: 2200/3906 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3591 2: 3594
3: 3593 4: 3591 5: 3757 6: 3748 7: 2998 8: 2998 bogomips: 57491
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: CLEVO/KAPOK
driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 3 speed: 8 GT/s ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2
bus-ID: 07:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 5-4:2
chip-ID: 04f2:b685 class-ID: 0e02
loaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: nouveau
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: HDMI-1 mapped: HDMI-A-1 pos: right model: MSI MAG272C
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
size: 598x336mm (23.5x13.2") diag: 686mm (27") ratio: 16:9 modes:
Monitor-2: eDP-1 pos: primary,left built: 2019 res: 1920x1080 hz: 144
dpi: 142 gamma: 1.2 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x350
OpenGL: renderer: NV168 v: 4.3 Mesa 21.3.7 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: CLEVO/KAPOK
link-max: gen: 3 speed: 8 GT/s bus-ID: 07:00.1 chip-ID: 10de:1aeb
Device-2: AMD Starship/Matisse HD Audio vendor: CLEVO/KAPOK
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: JBL Quantum One type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-9:5 chip-ID: 0ecb:203a
Sound Server-1: ALSA v: k5.16.12-zen1-1-zen running: yes
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0f1 state: up speed: 100 Mbps duplex: full mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-10:8 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 2.31 TiB used: 0 KiB (0.0%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 51.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 model: 512GB PCS PCIe M.2 SSD
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: T0707A0L
temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra
size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 76.0 C mobo: N/A gpu: nouveau temp: 49.0 C
Processes: 292 Uptime: 9m wakeups: 1 Memory: 15.58 GiB
used: 3.96 GiB (25.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1719 lib: 509 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-20
Last full system update: 2022-03-20
Yes, this might be your best bet. This person similarly could not boot the live environment with proprietary NVIDIA drivers: Garuda ISO boot stuck on Starting Terminating Plymouth Boot Screen - #21 by EthanSnowy
Their solution ended up being to install using the open-source drivers, then install the LTS kernel which has very robust driver support. With the LTS kernel they were able to switch to the NVIDIA driver they wanted to use.
are you able to run me through where i can get the LTS Kernal?
you can add it after you have installed the os from the garuda assistant or it will ask you when you install to add another kernel
After you boot into the new installation a post-install wizard will run asking you about various software, etc. that you may wish installed or set. One of wizards will ask if you want to install the Linux LTS kernel, so please select that. After you finish the wizarding, reboot, then use your cursor to select âAdvancedâ and choose the LTS kernel.
LTS kernels arenât miracle-workers but can be helpful due to their more conservative (vs aggressive) hardware settings.
so i did that the kernel would not install and when i went to the Garuda Settings Manager to try install the drivers from there i just end up getting this
Starting
> Using config 'video-nvidia-dkms' for device: 0000:07:00.0 (0300:10de:2191) Display controller nVidia Corporation TU116M [GeForce GTX 1660 Ti Mobile]
> Installing video-nvidia-dkms...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-dkms/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
error: failed retrieving file 'core.db' from mirror.osbeck.com : SSL connection timeout
resolving dependencies...
:: python-pyxdg and python-xdg are in conflict. Remove python-xdg? [y/N] error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Error: pacman failed!
Error: script failed!
Done ...
- Booted into the live environment, 2) installed Garuda, then, 3) ran through the wizard? Did you skip any of those steps or am I reading your post incorrectly?
If I had this error message I think I might run âreflector-simpleâ from a terminal, then update the system before anything else. It âsoundsâ like you donât have your mirrors setup yet.
yeah done all that, and this is what happened when i ran 'reflector-simple'
(yad:42488): Gtk-WARNING **: 16:09:58.588: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is not a valid
color name
(yad:42488): Gtk-WARNING **: 16:09:58.588: Theme parsing error: gtk-dark.css:5825:14: not a number
(yad:42488): Gtk-WARNING **: 16:09:58.588: Theme parsing error: gtk-dark.css:5826:13: not a number
(yad:42488): Gtk-WARNING **: 16:09:58.588: Theme parsing error: gtk-dark.css:5827:11: Expected a length
update, worked when i did it again, mirrors are all set up. still will not install the drivers i need
Your CPU temperature is into the range that you should be getting concerned. I would blow the dust out of your Laptop as best you can using compressed air.
Has there been a bios update for your laptop since 2020. If so, I would suggest you update your bios.
The LTS kernel âwouldnât installâ on a brand new Garuda installation? Thatâs just impossible; there is a bit of missing information here.
What specifically did you do to install the LTS kernel, and what exactly was the output you received that led you to believe it wouldnât install?
