Hi All. I really like the new theme ‘Broadwing’ so I installed Panel Colorizer, to my existing install, that’s good. But I want my window borders to match a new install. So I want this current border
to be pink on the active window and blue on an inactive window.
I’ve looked everywhere but cant find it.
Help
Kernel: 6.13.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
root=UUID=7b049ab1-cf8c-4eb1-809e-b21343f9b233 rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0 wm: kwin_wayland vt: 1
Type: Desktop Mobo: MSI model: A68HM-E33 V2 (MS-7721) v: 9.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 8.5 date: 11/01/2018
Info: model: AMD Athlon X4 860K bits: 64 type: MCP arch: Steamroller level: v2 built: 2014
process: GF 28nm family: 0x15 (21) model-id: 0x30 (48) stepping: 1 microcode: 0x6003106
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3893 min/max: 1700/3700 boost: enabled scaling: driver: acpi-cpufreq
governor: performance cores: 1: 3893 2: 3893 3: 3893 4: 3893 bogomips: 29544
Device-1: Advanced Micro Devices [AMD/ATI] Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: PC Partner / Sapphire driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s
lanes: 8 ports: active: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 42.0 C
Device-2: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 046d:085e class-ID: 0102
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-1 pos: primary,left model: Dell S2721H serial: <filter> built: 2020 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 pos: right model: Dell S2721H serial: <filter> built: 2022 res:
gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 460 Graphics (radeonsi polaris11 ACO DRM 3.61
6.13.7-zen1-1-zen) device-ID: 1002:67ef memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.304 layers: 5 device: 0 type: discrete-gpu name: AMD Radeon RX 460 Graphics
(RADV POLARIS11) driver: N/A device-ID: 1002:67ef surfaces: xcb,xlib,wayland device: 1
type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A device-ID: 10005:0000
Device-1: Advanced Micro Devices [AMD] FCH Azalia vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP /
560/560X] vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-3: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.1
API: ALSA v: k6.13.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0
IF-ID-2: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
Local Storage: total: 1.35 TiB used: 593.52 GiB (43.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240M500SSD1 size: 223.57 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: MU05
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240M500SSD1 size: 223.57 GiB block-size:
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EALX-009BA0 size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter>
fw-rev: 1H15 scheme: GPT
ID-1: / raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 63.24 GiB (28.3%) fs: btrfs
dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 27.4 MiB (9.1%) fs: vfat
dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 63.24 GiB (28.3%) fs: btrfs
ID-4: /var/log raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 63.24 GiB (28.3%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-5: /var/tmp raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 63.24 GiB (28.3%)
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1037
Memory: total: 16 GiB available: 15.57 GiB used: 5.18 GiB (33.3%)
Processes: 283 Power: uptime: 1h 20m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 6.21 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1693 libs: 431 tools: octopi,pacseek,paru Compilers: gcc: 14.2.1
Client: Unknown Client: garuda-rani inxi: 3.3.37
System install date: 2024-08-28
Last full system update: 2025-03-20
