System: Kernel: 5.14.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=8fb4d0aa-c7a3-4503-a2bd-892955066d06 rw
systemd.unified_cgroup_hierarchy=1 resume=UUID=ae82cfe5-7222-4e43-b44a-6d3b5d08171e loglevel=3
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 80WK v: Lenovo Y520-15IKBN serial: <filter> Chassis: type: 10
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter> UEFI: LENOVO v: 4KCN45WW
date: 01/11/2019
Battery: ID-1: BAT0 charge: 32.1 Wh (100.0%) condition: 32.1/45.0 Wh (71.4%) volts: 12.2 min: 11.1
model: SMP L14M3P24 type: Li-poly serial: <filter> status: Full
CPU: Info: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19999
Speed: 3300 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3300 2: 3489 3: 3302 4: 3279
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel HD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Lenovo driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0302
Device-3: Realtek EasyCamera type: USB driver: uvcvideo bus-ID: 1-6:4 chip-ID: 0bda:58e5
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.14.16-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.39 running: yes
Network: Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi v: kernel
bus-ID: 03:00.0 chip-ID: 8086:3166 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-11:5
chip-ID: 8087:0a2a class-ID: e001
Drives: Local Storage: total: 931.51 GiB used: 248.84 GiB (26.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LCM2
Partition: ID-1: / raw-size: 166.48 GiB size: 166.48 GiB (100.00%) used: 18.67 GiB (11.2%) fs: btrfs
dev: /dev/sda7 maj-min: 8:7
ID-2: /boot/efi raw-size: 524.4 MiB size: 523.4 MiB (99.80%) used: 580 KiB (0.1%) fs: vfat
dev: /dev/sda5 maj-min: 8:5
ID-3: /home raw-size: 166.48 GiB size: 166.48 GiB (100.00%) used: 18.67 GiB (11.2%) fs: btrfs
ID-4: /var/log raw-size: 166.48 GiB size: 166.48 GiB (100.00%) used: 18.67 GiB (11.2%) fs: btrfs
ID-5: /var/tmp raw-size: 166.48 GiB size: 166.48 GiB (100.00%) used: 18.67 GiB (11.2%) fs: btrfs
ID-1: swap-1 type: zram size: 7.66 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda6
maj-min: 8:6
Sensors: System Temperatures: cpu: 47.5 C mobo: N/A
Info: Processes: 259 Uptime: 18m wakeups: 1 Memory: 7.66 GiB used: 3.53 GiB (46.1%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1538 lib: 365 Shell: fish
v: 3.3.1 default: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.08
Hello, i got this problem where the KDE daemon asks my wifi password on startup everytime, but only on startup. i followed this posts troubleshooting but didn't work:
https://forum.garudalinux.org/t/kde-daemon-is-asking-for-wifi-password-again-and-again/2566
What can i do?
If you include terminal outputs in your post please
use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block
will provide a readable, raw look.
greetings
