From the first boot and even after the balancing I have noticed some lag on screen when notifications occur or if I hover my mouse over the various status tray icons. Especially if I am watching a youtube video and move the mouse over the various status icons it basically freezes the video because its so much lag. I did a variety of searches on the forum to see what the solution might be, but the most I could find is maybe a driver issue, but I have proprietary nvidia drivers installed, not sure what else I could do to make it better. I have an RTX 3070. Thanks.
SystemSpec:
System: Kernel: 5.13.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6b01d9a0-f1d5-4fcc-a164-83a5dd0cab3b rw [email protected] quiet
cryptdevice=UUID=2aed9b51-5839-4dc7-b7fd-626b0a957268:luks-2aed9b51-5839-4dc7-b7fd-626b0a957268
root=/dev/mapper/luks-2aed9b51-5839-4dc7-b7fd-626b0a957268 splash
resume=/dev/mapper/luks-4f21562b-460c-422e-838e-008dcae4276e loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASRock model: Z590 Steel Legend WiFi 6E serial: <filter>
UEFI: American Megatrends LLC. v: P1.60 date: 06/16/2021
Battery: Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter> charge: 95%
rechargeable: yes status: N/A
Device-2: hidpp_battery_1 model: Logitech Wireless All-in-One Keyboard TK820
serial: <filter> charge: 50% (should be ignored) rechargeable: yes status: N/A
CPU: Info: 8-Core model: 11th Gen Intel Core i9-11900K bits: 64 type: MT MCP
arch: Rocket Lake family: 6 model-id: A7 (167) stepping: 1 microcode: 40 cache:
L2: 16 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 112128
Speed: 4224 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 4224 2: 4776 3: 5091
4: 4854 5: 5015 6: 4871 7: 4991 8: 4889 9: 4863 10: 4882 11: 4982 12: 4918 13: 4868
14: 4895 15: 3618 16: 4669
Graphics: Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2484 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-6.4:8 chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
Screen-1: 0 s-res: 1921x2160 s-dpi: 101 s-size: 483x544mm (19.0x21.4")
s-diag: 727mm (28.6")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 30 size: 1600x900mm (63.0x35.4")
diag: 1836mm (72.3")
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 102 size: 476x268mm (18.7x10.6")
diag: 546mm (21.5")
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Audio: Device-1: Intel Tiger Lake-H HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.13.12-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 8086:2725 class-ID: 0280
Bluetooth: Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:12
chip-ID: 8087:0032 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Drives: Local Storage: total: 4.55 TiB used: 7.53 TiB (165.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS100T2B0C-00PXH0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: 211210WD temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS100T2B0A-00SM50
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 20WD scheme: GPT
ID-3: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: ST3000DM001-1CH166
size: 2.73 TiB block-size: physical: 4096 B logical: 4096 B type: HDD rpm: 7200
serial: <filter> rev: 0503 scheme: MBR
Partition: ID-1: / raw-size: 862.32 GiB size: 862.32 GiB (100.00%) used: 204.76 GiB (23.7%)
mapped: luks-2aed9b51-5839-4dc7-b7fd-626b0a957268
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 707 KiB (0.3%) fs: vfat
ID-3: /home raw-size: 862.32 GiB size: 862.32 GiB (100.00%) used: 204.76 GiB (23.7%)
ID-4: /var/log raw-size: 862.32 GiB size: 862.32 GiB (100.00%) used: 204.76 GiB (23.7%)
ID-5: /var/tmp raw-size: 862.32 GiB size: 862.32 GiB (100.00%) used: 204.76 GiB (23.7%)
ID-1: swap-1 type: zram size: 62.66 GiB used: 3.59 GiB (5.7%) priority: 100
ID-2: swap-2 type: partition size: 68.93 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1 mapped: luks-4f21562b-460c-422e-838e-008dcae4276e
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 100%
Info: Processes: 446 Uptime: 3d 5h 23m wakeups: 57 Memory: 62.66 GiB used: 11.18 GiB (17.8%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 2010 lib: 559 flatpak: 0 Client: Unknown Client: garuda-assistant inxi: 3.3.06
