Hello, I am new to KDE and Garuda (Garuda Blackarch). I am having some freeze issues(Randomly, like everything goes smooth but when I dragging the applications suddenly freezes and comes back etc etc.)
I heard about sometimes its happens because of swap, so I tried to reduce vm.swappiness(which is set to 133 by default.) But I didn't used zram before so I failed.
I was using GNOME before without any issues, you can find my system info below.
I don't know what to do please help me, thanks.
System Specs (Garuda Assistant)
System: Kernel: 5.13.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=82035f25-a138-4480-8585-1cb740611763 rw rootflags=subvol=@ quiet splash
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: H81M-PLUS v: Rev X.0x serial: <filter> UEFI: American Megatrends
v: 2205 date: 05/26/2015
CPU: Info: Quad Core model: Intel Core i5-4570 bits: 64 type: MCP arch: Haswell family: 6
model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 25598
Speed: 3200 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 3200 2: 3212 3: 3269
4: 3201
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
disabled, RSB filling
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
Screen-1: 0 s-res: 3840x1443 s-dpi: 101 s-size: 967x363mm (38.1x14.3")
s-diag: 1033mm (40.7")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
diag: 547mm (21.5")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 102 size: 476x268mm (18.7x10.6")
diag: 546mm (21.5")
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Audio: Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device(EEPROM) type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-8:5 chip-ID: 0c76:161f
Sound Server-1: ALSA v: k5.13.12-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK H81M-C
driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 703.79 GiB used: 29.39 GiB (4.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: GOODRAM model: SSDPR-CL100-240-G3 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS725050A7E630
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: A3C0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: TransMemory
size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 1.00 scheme: GPT
Partition: ID-1: / raw-size: 70 GiB size: 70 GiB (100.00%) used: 29.37 GiB (41.9%) fs: btrfs
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.8 MiB (26.9%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 70 GiB size: 70 GiB (100.00%) used: 29.37 GiB (41.9%) fs: btrfs
ID-4: /var/log raw-size: 70 GiB size: 70 GiB (100.00%) used: 29.37 GiB (41.9%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-5: /var/tmp raw-size: 70 GiB size: 70 GiB (100.00%) used: 29.37 GiB (41.9%)
ID-1: swap-1 type: zram size: 7.7 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 62 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 14%
Info: Processes: 214 Uptime: 5m wakeups: 0 Memory: 7.7 GiB used: 2.22 GiB (28.8%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1765
lib: 325 Client: Unknown Client: garuda-assistant inxi: 3.3.06
(as mentioned, there are many Nvidia users and gamers)
