I switched to Gnome 40 today, and I have this weird issue where monitors would turn on and off. I have a triple monitor setup (well 4, but one is disabled, don't know if that's relevant). Anybody having same issue?
my inxi output:
System: Kernel: 5.11.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=407a9383-157c-4ffa-a1d3-f5ad539f9407 rw
Desktop: GNOME 40.0 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 40.0 Distro: Garuda Linux base: Arch Linux
Machine: Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: <filter>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <filter> UEFI: American Megatrends v: F51 date: 07/29/2020
CPU: Info: 8-Core model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 1 stepping: 1
microcode: 8001138 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 95806
Speed: 3073 MHz min/max: 1550/3000 MHz boost: enabled Core speeds (MHz): 1: 3073 2: 2608 3: 2565 4: 2556 5: 2988
6: 2860 7: 2822 8: 3042 9: 2563 10: 2563 11: 2801 12: 2810 13: 2545 14: 3041 15: 2592 16: 2987
Graphics: Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: eVga.com. driver: nvidia v: 460.67
alternate: nouveau,nvidia_drm bus-ID: 07:00.0 chip-ID: 10de:1b06 class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver: loaded: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 6400x1440 s-dpi: 96 s-size: 1693x381mm (66.7x15.0") s-diag: 1735mm (68.3")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102 size: 476x267mm (18.7x10.5") diag: 546mm (21.5")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 102 size: 476x267mm (18.7x10.5") diag: 546mm (21.5")
Monitor-3: DP-4 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67 direct render: Yes
Audio: Device-1: NVIDIA GP102 HDMI Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus-ID: 07:00.1
chip-ID: 10de:10ef class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.11.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:4 chip-ID: 0b05:17cb
Report: ID: hci0 state: up address: <filter>
Drives: Local Storage: total: 2.73 TiB used: 126.89 GiB (4.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB size: 232.89 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 1B2QEXE7 temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC47 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SKC600512G size: 476.94 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0104 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC43 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Kingston model: SUV500240G size: 223.57 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 56RI scheme: GPT
Partition: ID-1: / raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 12.99 GiB (5.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 12.99 GiB (5.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 12.99 GiB (5.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 12.99 GiB (5.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-1: swap-1 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
Sensors: System Temperatures: cpu: 44.9 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 27%
Info: Processes: 461 Uptime: 1h 26m wakeups: 0 Memory: 31.37 GiB used: 4.97 GiB (15.8%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1202 lib: 303 Shell: Zsh v: 5.8 running-in: guake
inxi: 3.3.03
