After using FireDragon browser for a while, I'm seeing a couple of issues with it.
First, font rendering is bad, or at least, not comparable to browsers in Windows, or even other browsers in Linux. It seems to be a common issue with FireFox on Linux. Going in "about:config" and editing gfx.font_rendering.ahem_antialias_none helped a lot, but still.
Just did a quick comparison of FireFox vs Chrome in Linux. The Chrome text is more balanced and easier to read.
Comparison of a Wikipedia page: FireFox on top, Chrome below (is it using a different font?)
Second, PayPal refuses to login. Probably because of some privacy restriction settings?
Third, Ventusky.com doesn't render properly.
Fourth... and the most annoying. For privacy, it doesn't store my browsing history, but that means that it doesn't remember my URLs either to auto-fill them, and I need to type all the full URLs manually. One thing I did to mitigate that a "little bit" is adding bookmarks for all the main websites I'm using regularly so that it can auto-fill these URLs. If it could at least use LastPass' list of websites to auto-fill the URLs, that would be great. What are my options here?
Kernel: 5.16.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 intel_iommu=on
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 43.7 Wh (100.0%) condition: 43.7/58.8 Wh (74.4%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: Full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3764 high: 4591 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 3641 2: 3365 3: 4500
4: 1814 5: 4505 6: 4529 7: 4591 8: 2047 9: 4519 10: 2680 11: 4485
12: 4503 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f15
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:5
chip-ID: 0408:a061 class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
s-diag: 581mm (22.9")
Monitor-1: HDMI-1-0 res: 1920x1080 hz: 60 dpi: 40
size: 1210x680mm (47.6x26.8") diag: 1388mm (54.6")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.4
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.2:10
chip-ID: 08bb:29b0 class-ID: 0300
Sound Server-1: ALSA v: k5.16.1-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF-ID-3: virbr1 state: down mac: <filter>
bus-ID: 1-14:6 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 1.63 TiB used: 1 TiB (61.8%)
model: PC SN730 SDBQNTY-512G-1014 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3J0
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT275MX300SSD4
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R060 scheme: GPT
ID-1: / raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
used: 188.78 GiB (50.1%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:2
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
ID-4: /var/log raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 58.2 MiB (0.4%)
System Temperatures: cpu: 82.0 C pch: 64.0 C mobo: N/A
Processes: 396 Uptime: 1d 4h 23m wakeups: 1 Memory: 15.46 GiB
used: 5.82 GiB (37.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1715 lib: 490 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
