Issues not being able to launch programs and Firefox no longer saving tabs and logins
  Kernel: 6.9.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: hpet
    root=UUID=b78f0ace-4b76-4ecb-911e-371d2a924668 rw rootflags=subvol=@ quiet quiet
    resume=UUID=fad1c9fd-e4b0-4830-9857-17676d6daf30 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0 wm: kwin_x11 vt: 2
  Type: Laptop System: Acer product: Swift SFX14-42G v: V1.00 serial: <superuser required>
  Mobo: BC model: Orion_BCU v: V1.00 serial: <superuser required> part-nu: 0000000000000000
    uuid: <superuser required> UEFI: Insyde v: 1.00 date: 01/27/2022
  ID-1: BAT1 charge: 52.8 Wh (100.0%) condition: 52.8/58.8 Wh (89.9%) volts: 16.9 min: 15.4
    model: SMP AP18E7M type: Li-ion serial: <filter> status: full
  Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 4
    level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80)
    stepping: 0 microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3404 high: 4147 min/max: 400/4546 scaling: driver: amd-pstate-epp
    governor: performance cores: 1: 3789 2: 4032 3: 3632 4: 3610 5: 3623 6: 4126 7: 3705 8: 4103
    9: 3679 10: 400 11: 4114 12: 4147 13: 3628 14: 400 15: 3633 16: 3848 bogomips: 63886
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: Acer Incorporated ALI driver: nvidia
    v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-06;
    EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:25a0 class-ID: 0302
  Device-2: AMD Barcelo vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
    class-ID: 0300 temp: 42.0 C
  Device-3: Quanta Acer FHD User Facing driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 0408:4036 class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1 compositor: kwin_x11 driver: X:
    loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1408 built: 2019 res: 1920x1080 hz: 60
    dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0 drv: nvidia device: 2
    drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: radeonsi
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir LLVM 18.1.8 DRM 3.57
    6.9.10-zen1-1-zen) device-ID: 1002:15e7 memory: 500 MiB unified: no
  API: Vulkan v: 1.3.279 layers: 15 device: 0 type: integrated-gpu name: AMD Radeon Graphics
    (RADV RENOIR) driver: mesa radv v: 24.1.4-arch1.2 device-ID: 1002:15e7 surfaces: xcb,xlib
    device: 1 type: discrete-gpu name: NVIDIA GeForce RTX 3050 Ti Laptop GPU driver: nvidia
    v: 555.58.02 device-ID: 10de:25a0 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM
    18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.4-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000
    surfaces: xcb,xlib
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Acer Incorporated ALI
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
  API: ALSA v: k6.9.10-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
  Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse status: active
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter vendor: Lite-On
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7961
  Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-4:4 chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
    hardware: no software: yes address: <filter> bt-v: 5.2 lmp-v: 11 status: discoverable: no
    pairing: no
  Local Storage: total: 476.94 GiB used: 329.36 GiB (69.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N size: 476.94 GiB
    fw-rev: 41020C20 temp: 37.9 C scheme: GPT
  ID-1: / raw-size: 460.16 GiB size: 460.16 GiB (100.00%) used: 329.36 GiB (71.6%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
  ID-3: /home raw-size: 460.16 GiB size: 460.16 GiB (100.00%) used: 329.36 GiB (71.6%) fs: btrfs
  ID-4: /var/log raw-size: 460.16 GiB size: 460.16 GiB (100.00%) used: 329.36 GiB (71.6%)
  ID-5: /var/tmp raw-size: 460.16 GiB size: 460.16 GiB (100.00%) used: 329.36 GiB (71.6%)
  ID-1: swap-1 type: zram size: 14.98 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 16.48 GiB used: 0 KiB (0.0%) priority: -2
  System Temperatures: cpu: 60.8 C mobo: 32.0 C gpu: amdgpu temp: 42.0 C
  Memory: total: 16 GiB note: est. available: 14.98 GiB used: 5.83 GiB (39.0%)
  Processes: 364 Power: uptime: 30m states: freeze,mem,disk suspend: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 5.92 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 256
  Packages: 2193 pm: pacman pkgs: 2187 libs: 589 tools: octopi,paru pm: flatpak pkgs: 6
    Compilers: clang: 18.1.8
 gcc: 14.1.1 alt: 13 Client: shell wrapper v: 5.2.26-release inxi: 3.3.35
  System install date:     2023-04-14
  Last full system update: 2024-07-22
For the past few days I have been having a lot of issues of randomly being unable to launch applications. Everything from Dolphin to Calculator will give the error like:
Launching KCalc (Failed)
Unit app-
org.kde.kcalc@bbbfb51167e14b5e8
944679b96cJb69d.service not found.
I’ve made sure everything is up to date but the problem persists. It seems to happen at random once Firefox has been open for a while. Firefox seems to have gotten stuck at one save state of tabs and is not remembering anything new being opened or any tabs being. I’m also being randomly logged out of all accounts.
FireDragon also seems to have issues and cannot display or play YouTube and getting weird errors rendering other websites as well.
Would resinstalling all packages be a smart move or does this have the potential to mess things up further?
BTW, no problems here with Firedragon or Dolphin, Create new user and check, maybe restore a snapshot from working DE.
Take a look at this solved topic:
Thank you nepti! I think this solved the main problem.
It seems like the issue with FireDragon is completely separate, so I’ll try troubleshooting that later.
