So I updated my system yesterday and used it all day without rebooting. Nothing stood out in particular in pacman. I didn't see anything in this section of the forum either. However when I went to boot up my laptop (it defaults to linux-lts
and thats what I use daily) the boot skips over the garuda loading logo and goes straight to the black screen with Loading linux-lts kernel
and Loading initial ramdisk
output and gets stuck there. Atm I am using the regular linux
kernel and it boots just fine. However since I cannot even get to a tty I don't know how to post logs.
Another smaller issue I noticed is that neofetch
got uninstalled somehow. I know I haven't uninstalled it. It was installed just a few hours ago then I open terminal and the output says neofetch can be found in these packages
with a list of teh repos. I would like to add that I have since installed it from official repos and I see the new logo being displayed. Though it isn't color coded like before.
Only thing I did today was use Garuda Assitant to Apply New Configs
as I saw that being suggested in pacman output after Syu
run for a couple of days. Also ran btrfs-trim
a few times from there as well.
sudo inxi -Fxxxza
output
System: Kernel: 5.12.4-arch1-2 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=6bffdc79-d9cf-4de9-a3aa-58bbfb0e7a9c rw [email protected]
quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
intel_iommu=on i915.enable_gvt=1 kvm.ignore_msrs=1 i915.enable_guc=0
Console: tty pts/1 wm: kwin_x11 DM: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: Dell product: G3 3590 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0DKM3T v: A00 serial: <filter> UEFI: Dell v: 1.8.0 date: 11/11/2019
Battery: ID-1: BAT0 charge: 42.2 Wh (100.0%) condition: 42.2/51.0 Wh (82.8%) volts: 12.7 min: 11.4 model: BYD DELL M4GWP98
type: Li-poly serial: <filter> status: Full
CPU: Info: 6-Core model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64 type: MT MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: DE cache: L1: 384 KiB L2: 12 MiB L3: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62431
Speed: 4283 MHz min/max: 800/4500 MHz base/boost: 2600/2600 volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz):
1: 4283 2: 4403 3: 4389 4: 4401 5: 4391 6: 4400 7: 4400 8: 4395 9: 4352 10: 4239 11: 4173 12: 4337
Graphics: Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Dell driver: nvidia v: 465.27
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:2 chip-ID: 0bda:5521 class-ID: 0e02
Display: server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0 screens: 1
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.0 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0401
Device-2: NVIDIA TU116 High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:1aeb class-ID: 0403
Sound Server-1: ALSA v: k5.12.4-arch1-2 running: yes
Sound Server-4: PipeWire v: 0.3.27 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell driver: ath10k_pci v: kernel
port: 3000 bus-ID: 04:00.0 chip-ID: 168c:0042 class-ID: 0280
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 0cf3:e009 class-ID: e001
Drives: Local Storage: total: 1.38 TiB used: 1.15 TiB (83.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 NVMe WDC 512GB size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD serial: <filter> rev: 20220012
temp: 57 Celsius C scheme: MBR
SMART: yes health: PASSED on: 159d 22h cycles: 1,292 read-units: 50,309,450 [25.7 TB]
written-units: 75,494,895 [38.6 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 family: Mobile HDD size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: ACM1
temp: 40 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 53d 8h cycles: 3344 read: 52.37 TiB written: 38.5 TiB Old-Age:
g-sense error rate: 330 Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
Partition: ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 431.08 GiB (90.4%) fs: btrfs block-size: 4096 B
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 568 KiB (0.2%) fs: vfat block-size: 512 B
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 431.08 GiB (90.4%) fs: btrfs block-size: 4096 B
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 431.08 GiB (90.4%) fs: btrfs
block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 431.08 GiB (90.4%) fs: btrfs
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 64.0 C mobo: N/A
Info: Processes: 337 Uptime: 4m wakeups: 1821 Memory: 15.43 GiB used: 3.21 GiB (20.8%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 11.1.0 Packages: pacman: 1775 lib: 546 Shell: fish (sudo) v: 3.2.2
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
