Itβs the Arch way. Select what to merge or to keep from your running config.
You may brake your system if you merge or keep the wrong parts.
Simply install meld if it does not already exist and enter it in the terminal
sudo -H DIFFPROG=meld pacdiff
(make
alias pacdif='sudo -H DIFFPROG=meld pacdiff'
Then the new and old versions are next to each other and you can adjust them accordingly.
https://wiki.archlinux.org/title/Pacman/Pacnew_and_Pacsave
