I need some help to configure IP cameras. Is there an app that will run flash player even though adobe no longer supports it
Hi there, welcome.
First of all, I’d check if the vendor has provided eg a firmware update to avoid this common problem.
If not, maybe you could try this one:
https://aur.archlinux.org/packages/flashplugin/
Found in this thread, but no final solution there
Maybe check also
https://aur.archlinux.org/packages/flashplayer-standalone/
You could try vlc and setup a network stream.
ie rtsp://"cameraip":80
You can also use zoneminder
This question really should be directed to the manufacturer.
