invisible font problem
It's been a while that i am using sway and I have found that with default theming there are some problems in visibility of the fonts , some times I have noticed that some fonts in GUI messages for e.g. like this :
the messages written there were not as visible as it is visible in this picture the colour of fonts sometimes were grey instead of white, so for fixing it first I tried to change the theming then i changed the default font :
ββ[email protected] in ~/.config/sway/scripts via ξ v3.10.1 took 5ms
β°βΞ» bat import-gsettings
ββββββββ¬ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
β File: import-gsettings
ββββββββΌββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
1 β #!/bin/sh
2 β
3 β # usage: import-gsettings
4 β config="${XDG_CONFIG_HOME:-$HOME/.config}/gtk-3.0/settings.ini"
5 β if [ ! -f "$config" ]; then exit 1; fi
6 β
7 β gnome_schema="org.gnome.desktop.interface"
8 β gtk_theme="$(grep 'gtk-theme-name' "$config" | cut -d'=' -f2)"
9 β icon_theme="$(grep 'gtk-icon-theme-name' "$config" | cut -d'=' -f2)"
10 β cursor_theme="$(grep 'gtk-cursor-theme-name' "$config" | cut -d'=' -f2)"
11 β font_name="$(grep 'gtk-font-name' "$config" | cut -d'=' -f2)"
12 β gsettings set $gnome_schema gtk-theme 'Sweet-Dark'
13 β gsettings set $gnome_schema icon-theme 'BeautyLine'
14 β gsettings set $gnome_schema cursor-theme 'Sweet-cursors'
15 β gsettings set $gnome_schema font-name 'Noto-Sans'
ββββββββ΄ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
ββ[email protected] in ~/.config/sway/scripts via ξ v3.10.1 took 128ms
β°βΞ»
The problem was solved through it .
I don't know what helped to solve it , whether it was a theming problem or default font problem , I don't know whether it was a problem with my machine only, but this can be a problem for new comers that should be solved .
(sorry for reporting this so late actually It's my first WM experience and before tweaking it I searched a lot and in this process I almost forgot for what I was actually tweaking it)
