Hello so i tried the garuda network assistant but its doesnt show any driver i installed the driver manually but it doesnt work lets keep it short here is my inxi -Faz
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b7db5aca-6a36-4084-baa3-3af99917d4e0 rw rootflags=subvol=@
quiet resume=UUID=56308c5f-6524-4d0a-98e8-8bfda1961225 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland dm: SDDM
Type: Convertible System: HP product: HP EliteBook x360 1030 G2 v: N/A
serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: HP model: 827D v: KBC Version 44.79 serial: <filter> UEFI: HP
v: P80 Ver. 01.45 date: 12/15/2022
ID-1: BAT0 charge: 12.4 Wh (29.8%) condition: 41.6/57.2 Wh (72.7%)
volts: 10.7 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 429
Info: model: Intel Core i7-7600U socket: BGA1356 (U3E1) note: check bits: 64
type: MT MCP arch: Amber/Kaby Lake note: check gen: core 7 level: v3
note: check built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xF4
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 770 high: 800 min/max: 400/3900 base/boost: 2700/3900
ext-clock: 100 MHz cores: 1: 776 2: 800 3: 705 4: 800 bogomips: 23199
Type: gather_data_sampling mitigation: Microcode
Type: spec_rstack_overflow status: Not affected
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-7:3 chip-ID: 05c8:080b class-ID: 0e02 serial: <filter>
Device-3: Cheng Uei Precision Industry (Foxlink) HP IR Camera
bus-ID: 1-8:4 chip-ID: 05c8:0396 class-ID: 0e02 serial: <filter>
Display: server: X.Org v: 23.2.3 with: Xwayland v: 23.2.3
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
Monitor-1: eDP-1 model: InfoVision Optronics/Kunshan 0x0535 built: 2017
res: 1920x1080 hz: 120 dpi: 168 gamma: 1.2 size: 290x170mm (11.42x6.69")
diag: 337mm (13.3") ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 15.13 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: integrated-gpu name: Intel
HD Graphics 620 (KBL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:5916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.0 status: n/a (root, process) with:
Device-1: Intel Wireless 8265 / 8275 driver: N/A modules: iwlwifi pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3a:00.0 chip-ID: 8086:24fd
Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1:2 chip-ID: 0b95:1790
IF: enp57s0u1c2 state: up speed: 100 Mbps duplex: half mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0000
Local Storage: total: 1.16 TiB used: 21 GiB (1.8%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: EE4S5 size: 238.75 GiB
block-size: physical: 512 B logical: 512 B type: Removable tech: SSD
serial: <filter> scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC300 NVMe 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 20005A00 temp: 28.9 C
SMART: yes health: PASSED on: 2y 317d 14h cycles: 285
read-units: 15,048,949 [7.70 TB] written-units: 55,406,134 [28.3 TB]
ID-1: / raw-size: 936.52 GiB size: 936.52 GiB (100.00%) used: 21 GiB (2.2%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 936.52 GiB size: 936.52 GiB (100.00%)
used: 21 GiB (2.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 936.52 GiB size: 936.52 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 936.52 GiB size: 936.52 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.05 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 50.0 C pch: 41.5 C mobo: N/A
Processes: 210 Uptime: 12m wakeups: 0 Memory: total: 16 GiB
available: 15.5 GiB used: 3.75 GiB (24.2%) igpu: 32 MiB Init: systemd v: 255
pm: pacman pkgs: 1861 libs: 560 tools: octopi,pamac,paru Shell: Bash (su)
v: 5.2.21 running-in: konsole inxi: 3.3.31
so i checked that out and i find a lot of people that have Intel Wireless 8265 / 8275 got the same issue as me
kilo
16 December 2023 01:09
2
If you’re dual booted, could be this. Though I can’t tell from the inxi.
This is one of the reasons why we strongly recommend avoiding dual boot…
Windows loves to hold a grip on HW resources.
What I think you could try is:
Logon to Windows and disable fast startup. See e.g. here .
Open your device manager, go through each driver option and disable any option that relates to wifi power saving
Shutdown your computer, unplug the AC power cord and leave the PC unplugged for a few minutes, then restart the computer and try booting to Linux
Disabling fast startup, and properly shutting down PC may help if that’s the case.
no dual booting also fast startup is disabled
kilo
16 December 2023 01:17
4
Try running
sudo modprobe iwlwifi
and post the results if it errors.
Bro
16 December 2023 01:22
5
Firestorm:
maj-min: 259:1
We want/need your ‘garuda-inxi’
And…
And please check for a more recent BIOS update. They always concern hardware.
tbg
16 December 2023 01:27
6
How exactly?
Which driver?
Detail your exact install procedure, if done from the terminal show input & output of all commands.
You have likely installed an inappropriate driver.
tbg
16 December 2023 01:30
8
That is not the driver, that is the firmware.
Bro
9
This is not how it works.
then i didnt do anything other than seeing the garuda network assistant and the firmware
and as i said its Intel Wireless 8265 / 8275
do you have a link for the driver or something like that?
tbg
16 December 2023 01:41
11
The driver is in the Linux kernel.
Please post:
okay so the good news is that today when i booted my laptop the wifi is working the bad news is that i dont know how it worked and the second bad news is my fingerprint sensor is not supported by libfprint
tbg
16 December 2023 19:58
13
Glad to hear your wifi is now working.
This is a different issue, please open a new help request for this separate problem. We prefer each forum help request to only deal with one issue per thread. Mixing separate issues on the same thread leads to excessively long threads that are confusing and hard to follow.
Be sure to include your garuda-inxi output when opening any new help request.
Good luck with resolving your outstanding issues.
system
Closed
30 December 2023 19:58
14
