I am having an issue with my intel Wifi card, it seems only bluetooth is working for it, as I am unable to get wifi working on it at all. Bluetooth seems to be fine, but the wifi capability is not.
My device will show under "lsusb", but not under "ip a"
sudo garuda-inxi
Kernel: 5.16.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=58412155-bab1-4ecf-ab35-4f62ce3ab0c1 rw rootflags=subvol=@
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Desktop System: Gigabyte product: Z390 AORUS ULTRA v: N/A serial: N/A
Mobo: Gigabyte model: Z390 AORUS ULTRA-CF serial: N/A
UEFI: American Megatrends v: F10 date: 11/05/2021
ID-1: hidpp_battery_0 charge: 76% condition: N/A volts: 4.0 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
status: Discharging
Info: model: Intel Core i9-9900K socket: LGA1151 (U3E1) note: check
bits: 64 type: MT MCP arch: Coffee Lake family: 6 model-id: 0x9E (158)
stepping: 0xD (13) microcode: 0xEC
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4956 high: 5006 min/max: 800/5000 base/boost: 4700/8300
scaling: driver: intel_pstate governor: performance volts: 1.2 V
ext-clock: 100 MHz cores: 1: 5004 2: 4999 3: 5002 4: 5002 5: 4901 6: 4913
7: 4976 8: 4803 9: 4887 10: 4908 11: 4972 12: 4945 13: 4993 14: 5006
15: 5005 16: 4993 bogomips: 115200
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti] vendor: Micro-Star MSI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1e04 class-ID: 0300
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 92 s-size: 1237x402mm (48.7x15.8")
s-diag: 1301mm (51.2")
Monitor-1: DP-0 pos: primary,left res: 2560x1440 dpi: 109
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: PreSonus Audio AudioBox USB 96 type: USB driver: snd-usb-audio
bus-ID: 1-4:2 chip-ID: 194f:0303 class-ID: fe01 serial: <filter>
Device-4: Logitech PRO X Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-7:4 chip-ID: 046d:0aba
Sound Server-1: ALSA v: k5.16.15-zen1-1-zen running: yes
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
bus-ID: 1-13.2:12 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci1 rfk-id: 2 state: up address: N/A
Device-2: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:11 chip-ID: 8087:0aaa class-ID: e001
Report: ID: hci0 rfk-id: 1 state: up address: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
port: 4020 bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 2.79 TiB used: 171.62 GiB (6.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S11 Pro size: 1.86 TiB block-size: physical: 512 B
rev: 42A4SANA temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 69d 7h cycles: 1,103
read-units: 32,678,941 [16.7 TB] written-units: 115,518,116 [59.1 TB]
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: A-Data model: SX6000PNP
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V9002s16
SMART: yes health: PASSED on: 26d 18h cycles: 1,225
read-units: 14,452,899 [7.39 TB] written-units: 23,663,090 [12.1 TB]
used: 171.62 GiB (18.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2
maj-min: 259:7
used: 580 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:6
maj-min: 259:7
maj-min: 259:7
maj-min: 259:7
ID-1: swap-1 type: zram size: 31.26 GiB used: 2.8 MiB (0.0%)
System Temperatures: cpu: 27.8 C pch: 46.0 C mobo: N/A gpu: nvidia
temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 381 Uptime: 24m wakeups: 2 Memory: 31.27 GiB
used: 4.36 GiB (14.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1995 lib: 381 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-16
Last full system update: 2022-03-20
Windows dual boot: Yes
** sudo dmesg | grep iwlwifi**
[ 3.858910] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 3.861855] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[ 3.894841] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 3.894844] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 3.894845] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 3.894846] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 3.894847] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 3.894848] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 3.894849] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 3.894850] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 3.894851] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 3.894852] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 3.894853] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 3.894854] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 3.894855] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 3.894856] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 3.894857] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 3.894858] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 3.894859] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 3.895207] iwlwifi 0000:00:14.3: loaded firmware version 46.fae53a8b.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 3.899330] iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
[ 3.899343] iwlwifi 0000:02:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 3.899654] iwlwifi 0000:02:00.0: loaded firmware version 67.8f59b80b.0 cc-a0-67.ucode op_mode iwlmvm
[ 3.982365] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz, REV=0x318
[ 4.029508] iwlwifi 0000:00:14.3: base HW address: 7c:b2:7d:d4:7d:bc
[ 4.097983] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 4.098683] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[ 5.154664] iwlwifi 0000:02:00.0: SecBoot CPU1 Status: 0x5ae4, CPU2 Status: 0x3
[ 5.154677] iwlwifi 0000:02:00.0: UMAC PC: 0x80473dd4
[ 5.154687] iwlwifi 0000:02:00.0: LMAC PC: 0xd0
[ 5.154689] iwlwifi 0000:02:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 5.154804] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[ 5.154805] iwlwifi 0000:02:00.0: Transport status: 0x00000042, valid: 6
[ 5.154806] iwlwifi 0000:02:00.0: Loaded firmware version: 67.8f59b80b.0 cc-a0-67.ucode
[ 5.154806] iwlwifi 0000:02:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 5.154807] iwlwifi 0000:02:00.0: 0x002022F0 | trm_hw_status0
[ 5.154808] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
[ 5.154809] iwlwifi 0000:02:00.0: 0x004FAD06 | branchlink2
[ 5.154809] iwlwifi 0000:02:00.0: 0x004F15FA | interruptlink1
[ 5.154810] iwlwifi 0000:02:00.0: 0x004F15FA | interruptlink2
[ 5.154810] iwlwifi 0000:02:00.0: 0x004F3F0A | data1
[ 5.154811] iwlwifi 0000:02:00.0: 0x00001000 | data2
[ 5.154812] iwlwifi 0000:02:00.0: 0x00000000 | data3
[ 5.154812] iwlwifi 0000:02:00.0: 0x00000000 | beacon time
[ 5.154813] iwlwifi 0000:02:00.0: 0x0000C3D2 | tsf low
[ 5.154813] iwlwifi 0000:02:00.0: 0x00000000 | tsf hi
[ 5.154814] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[ 5.154814] iwlwifi 0000:02:00.0: 0x00011FC0 | time gp2
[ 5.154815] iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
[ 5.154816] iwlwifi 0000:02:00.0: 0x00000043 | uCode version major
[ 5.154816] iwlwifi 0000:02:00.0: 0x8F59B80B | uCode version minor
[ 5.154817] iwlwifi 0000:02:00.0: 0x00000340 | hw version
[ 5.154817] iwlwifi 0000:02:00.0: 0x18C89000 | board version
[ 5.154818] iwlwifi 0000:02:00.0: 0x8001FF03 | hcmd
[ 5.154819] iwlwifi 0000:02:00.0: 0x00020000 | isr0
[ 5.154819] iwlwifi 0000:02:00.0: 0x20000000 | isr1
[ 5.154820] iwlwifi 0000:02:00.0: 0x08F00002 | isr2
[ 5.154820] iwlwifi 0000:02:00.0: 0x00C0001C | isr3
[ 5.154821] iwlwifi 0000:02:00.0: 0x00000000 | isr4
[ 5.154821] iwlwifi 0000:02:00.0: 0x00000000 | last cmd Id
[ 5.154822] iwlwifi 0000:02:00.0: 0x004F3F0A | wait_event
[ 5.154822] iwlwifi 0000:02:00.0: 0x00000000 | l2p_control
[ 5.154823] iwlwifi 0000:02:00.0: 0x00000000 | l2p_duration
[ 5.154824] iwlwifi 0000:02:00.0: 0x00000000 | l2p_mhvalid
[ 5.154824] iwlwifi 0000:02:00.0: 0x00000000 | l2p_addr_match
[ 5.154825] iwlwifi 0000:02:00.0: 0x00000009 | lmpm_pmg_sel
[ 5.154825] iwlwifi 0000:02:00.0: 0x00000000 | timestamp
[ 5.154826] iwlwifi 0000:02:00.0: 0x0000F81C | flow_handler
[ 5.154866] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[ 5.154867] iwlwifi 0000:02:00.0: Transport status: 0x00000042, valid: 7
[ 5.154868] iwlwifi 0000:02:00.0: 0x20100222 | ADVANCED_SYSASSERT
[ 5.154868] iwlwifi 0000:02:00.0: 0x00000000 | umac branchlink1
[ 5.154869] iwlwifi 0000:02:00.0: 0x80455E02 | umac branchlink2
[ 5.154869] iwlwifi 0000:02:00.0: 0x80464658 | umac interruptlink1
[ 5.154870] iwlwifi 0000:02:00.0: 0x00000000 | umac interruptlink2
[ 5.154871] iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data1
[ 5.154871] iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data2
[ 5.154872] iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data3
[ 5.154872] iwlwifi 0000:02:00.0: 0x00000043 | umac major
[ 5.154873] iwlwifi 0000:02:00.0: 0x8F59B80B | umac minor
[ 5.154873] iwlwifi 0000:02:00.0: 0x00011FBA | frame pointer
[ 5.154874] iwlwifi 0000:02:00.0: 0xC0886AD4 | stack pointer
[ 5.154874] iwlwifi 0000:02:00.0: 0x00000000 | last host cmd
[ 5.154875] iwlwifi 0000:02:00.0: 0x00000000 | isr status reg
[ 5.154885] iwlwifi 0000:02:00.0: IML/ROM dump:
[ 5.154885] iwlwifi 0000:02:00.0: 0x00000003 | IML/ROM error/state
[ 5.154896] iwlwifi 0000:02:00.0: 0x00005AE4 | IML/ROM data1
[ 5.154907] iwlwifi 0000:02:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 5.154913] iwlwifi 0000:02:00.0: Fseq Registers:
[ 5.154915] iwlwifi 0000:02:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 5.154918] iwlwifi 0000:02:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 5.154920] iwlwifi 0000:02:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 5.154923] iwlwifi 0000:02:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 5.154925] iwlwifi 0000:02:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 5.154928] iwlwifi 0000:02:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 5.154931] iwlwifi 0000:02:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 5.154934] iwlwifi 0000:02:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 5.154936] iwlwifi 0000:02:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 5.154941] iwlwifi 0000:02:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 5.154945] iwlwifi 0000:02:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 5.154950] iwlwifi 0000:02:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 5.154952] iwlwifi 0000:02:00.0: Failed to start RT ucode: -110
[ 5.154953] iwlwifi 0000:02:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 6.289762] iwlwifi 0000:02:00.0: Failed to run INIT ucode: -110
[ 6.303695] iwlwifi 0000:02:00.0: retry init count 0
[ 6.303932] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 7.329730] iwlwifi 0000:02:00.0: SecBoot CPU1 Status: 0x5b0b, CPU2 Status: 0x3
[ 7.329752] iwlwifi 0000:02:00.0: UMAC PC: 0x80473dd4
[ 7.329759] iwlwifi 0000:02:00.0: LMAC PC: 0xd0
[ 7.329761] iwlwifi 0000:02:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 7.329854] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[ 7.329854] iwlwifi 0000:02:00.0: Transport status: 0x00000042, valid: 6
[ 7.329868] iwlwifi 0000:02:00.0: Loaded firmware version: 67.8f59b80b.0 cc-a0-67.ucode
[ 7.329869] iwlwifi 0000:02:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 7.329870] iwlwifi 0000:02:00.0: 0x002022F0 | trm_hw_status0
[ 7.329871] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
[ 7.329872] iwlwifi 0000:02:00.0: 0x004FAD06 | branchlink2
[ 7.329873] iwlwifi 0000:02:00.0: 0x004F15FA | interruptlink1
[ 7.329873] iwlwifi 0000:02:00.0: 0x004F15FA | interruptlink2
[ 7.329874] iwlwifi 0000:02:00.0: 0x004F3F0A | data1
[ 7.329874] iwlwifi 0000:02:00.0: 0x00001000 | data2
[ 7.329875] iwlwifi 0000:02:00.0: 0x00000000 | data3
[ 7.329875] iwlwifi 0000:02:00.0: 0x00000000 | beacon time
[ 7.329876] iwlwifi 0000:02:00.0: 0x0000C3A2 | tsf low
[ 7.329876] iwlwifi 0000:02:00.0: 0x00000000 | tsf hi
[ 7.329877] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[ 7.329877] iwlwifi 0000:02:00.0: 0x00011FB4 | time gp2
[ 7.329878] iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
[ 7.329879] iwlwifi 0000:02:00.0: 0x00000043 | uCode version major
[ 7.329879] iwlwifi 0000:02:00.0: 0x8F59B80B | uCode version minor
[ 7.329880] iwlwifi 0000:02:00.0: 0x00000340 | hw version
[ 7.329880] iwlwifi 0000:02:00.0: 0x18C89000 | board version
[ 7.329881] iwlwifi 0000:02:00.0: 0x8001FF03 | hcmd
[ 7.329881] iwlwifi 0000:02:00.0: 0x00020000 | isr0
[ 7.329882] iwlwifi 0000:02:00.0: 0x20000000 | isr1
[ 7.329882] iwlwifi 0000:02:00.0: 0x08F00002 | isr2
[ 7.329883] iwlwifi 0000:02:00.0: 0x00C0001C | isr3
[ 7.329883] iwlwifi 0000:02:00.0: 0x00000000 | isr4
[ 7.329884] iwlwifi 0000:02:00.0: 0x00000000 | last cmd Id
[ 7.329884] iwlwifi 0000:02:00.0: 0x004F3F0A | wait_event
[ 7.329885] iwlwifi 0000:02:00.0: 0x00000000 | l2p_control
[ 7.329885] iwlwifi 0000:02:00.0: 0x00000000 | l2p_duration
[ 7.329886] iwlwifi 0000:02:00.0: 0x00000000 | l2p_mhvalid
[ 7.329886] iwlwifi 0000:02:00.0: 0x00000000 | l2p_addr_match
[ 7.329887] iwlwifi 0000:02:00.0: 0x00000009 | lmpm_pmg_sel
[ 7.329888] iwlwifi 0000:02:00.0: 0x00000000 | timestamp
[ 7.329888] iwlwifi 0000:02:00.0: 0x0000F81C | flow_handler
[ 7.329912] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[ 7.329913] iwlwifi 0000:02:00.0: Transport status: 0x00000042, valid: 7
[ 7.329914] iwlwifi 0000:02:00.0: 0x20100222 | ADVANCED_SYSASSERT
[ 7.329914] iwlwifi 0000:02:00.0: 0x00000000 | umac branchlink1
[ 7.329915] iwlwifi 0000:02:00.0: 0x80455E02 | umac branchlink2
[ 7.329916] iwlwifi 0000:02:00.0: 0x80464658 | umac interruptlink1
[ 7.329916] iwlwifi 0000:02:00.0: 0x00000000 | umac interruptlink2
[ 7.329917] iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data1
[ 7.329917] iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data2
[ 7.329918] iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data3
[ 7.329918] iwlwifi 0000:02:00.0: 0x00000043 | umac major
[ 7.329919] iwlwifi 0000:02:00.0: 0x8F59B80B | umac minor
[ 7.329919] iwlwifi 0000:02:00.0: 0x00011FAE | frame pointer
[ 7.329920] iwlwifi 0000:02:00.0: 0xC0886AD4 | stack pointer
[ 7.329920] iwlwifi 0000:02:00.0: 0x00000000 | last host cmd
[ 7.329921] iwlwifi 0000:02:00.0: 0x00000000 | isr status reg
[ 7.329929] iwlwifi 0000:02:00.0: IML/ROM dump:
[ 7.329929] iwlwifi 0000:02:00.0: 0x00000003 | IML/ROM error/state
[ 7.329937] iwlwifi 0000:02:00.0: 0x00005B0B | IML/ROM data1
[ 7.329945] iwlwifi 0000:02:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 7.329949] iwlwifi 0000:02:00.0: Fseq Registers:
[ 7.329952] iwlwifi 0000:02:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 7.329954] iwlwifi 0000:02:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 7.329956] iwlwifi 0000:02:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 7.329959] iwlwifi 0000:02:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 7.329961] iwlwifi 0000:02:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 7.329964] iwlwifi 0000:02:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 7.329981] iwlwifi 0000:02:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 7.329984] iwlwifi 0000:02:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 7.329986] iwlwifi 0000:02:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 7.329991] iwlwifi 0000:02:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 7.329995] iwlwifi 0000:02:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 7.330000] iwlwifi 0000:02:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 7.330002] iwlwifi 0000:02:00.0: Failed to start RT ucode: -110
[ 7.330003] iwlwifi 0000:02:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 8.276928] iwlwifi 0000:02:00.0: Failed to run INIT ucode: -110
[ 8.291454] iwlwifi 0000:02:00.0: retry init count 1
[ 8.291765] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 9.505802] iwlwifi 0000:02:00.0: SecBoot CPU1 Status: 0x5ace, CPU2 Status: 0x3
[ 9.505824] iwlwifi 0000:02:00.0: UMAC PC: 0x80473dd4
[ 9.505845] iwlwifi 0000:02:00.0: LMAC PC: 0xd0
[ 9.505846] iwlwifi 0000:02:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 9.505914] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[ 9.505915] iwlwifi 0000:02:00.0: Transport status: 0x00000042, valid: 6
[ 9.505916] iwlwifi 0000:02:00.0: Loaded firmware version: 67.8f59b80b.0 cc-a0-67.ucode
[ 9.505916] iwlwifi 0000:02:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 9.505918] iwlwifi 0000:02:00.0: 0x002022F0 | trm_hw_status0
[ 9.505918] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
[ 9.505919] iwlwifi 0000:02:00.0: 0x004FAD06 | branchlink2
[ 9.505920] iwlwifi 0000:02:00.0: 0x004F15FA | interruptlink1
[ 9.505920] iwlwifi 0000:02:00.0: 0x004F15FA | interruptlink2
[ 9.505921] iwlwifi 0000:02:00.0: 0x004F3F0A | data1
[ 9.505921] iwlwifi 0000:02:00.0: 0x00001000 | data2
[ 9.505922] iwlwifi 0000:02:00.0: 0x00000000 | data3
[ 9.505922] iwlwifi 0000:02:00.0: 0x00000000 | beacon time
[ 9.505923] iwlwifi 0000:02:00.0: 0x0000C396 | tsf low
[ 9.505923] iwlwifi 0000:02:00.0: 0x00000000 | tsf hi
[ 9.505924] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[ 9.505924] iwlwifi 0000:02:00.0: 0x00011F79 | time gp2
[ 9.505925] iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
[ 9.505925] iwlwifi 0000:02:00.0: 0x00000043 | uCode version major
[ 9.505926] iwlwifi 0000:02:00.0: 0x8F59B80B | uCode version minor
[ 9.505927] iwlwifi 0000:02:00.0: 0x00000340 | hw version
[ 9.505927] iwlwifi 0000:02:00.0: 0x18C89000 | board version
[ 9.505928] iwlwifi 0000:02:00.0: 0x8001FF03 | hcmd
[ 9.505928] iwlwifi 0000:02:00.0: 0x00020000 | isr0
[ 9.505929] iwlwifi 0000:02:00.0: 0x20000000 | isr1
[ 9.505929] iwlwifi 0000:02:00.0: 0x08F00002 | isr2
[ 9.505930] iwlwifi 0000:02:00.0: 0x00C0001C | isr3
[ 9.505930] iwlwifi 0000:02:00.0: 0x00000000 | isr4
[ 9.505931] iwlwifi 0000:02:00.0: 0x00000000 | last cmd Id
[ 9.505931] iwlwifi 0000:02:00.0: 0x004F3F0A | wait_event
[ 9.505932] iwlwifi 0000:02:00.0: 0x00000000 | l2p_control
[ 9.505932] iwlwifi 0000:02:00.0: 0x00000000 | l2p_duration
[ 9.505933] iwlwifi 0000:02:00.0: 0x00000000 | l2p_mhvalid
[ 9.505933] iwlwifi 0000:02:00.0: 0x00000000 | l2p_addr_match
[ 9.505934] iwlwifi 0000:02:00.0: 0x00000009 | lmpm_pmg_sel
[ 9.505934] iwlwifi 0000:02:00.0: 0x00000000 | timestamp
[ 9.505935] iwlwifi 0000:02:00.0: 0x0000F81C | flow_handler
[ 9.505958] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[ 9.505959] iwlwifi 0000:02:00.0: Transport status: 0x00000042, valid: 7
[ 9.505960] iwlwifi 0000:02:00.0: 0x20100222 | ADVANCED_SYSASSERT
[ 9.505960] iwlwifi 0000:02:00.0: 0x00000000 | umac branchlink1
[ 9.505961] iwlwifi 0000:02:00.0: 0x80455E02 | umac branchlink2
[ 9.505961] iwlwifi 0000:02:00.0: 0x80464658 | umac interruptlink1
[ 9.505962] iwlwifi 0000:02:00.0: 0x00000000 | umac interruptlink2
[ 9.505962] iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data1
[ 9.505963] iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data2
[ 9.505963] iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data3
[ 9.505964] iwlwifi 0000:02:00.0: 0x00000043 | umac major
[ 9.505964] iwlwifi 0000:02:00.0: 0x8F59B80B | umac minor
[ 9.505965] iwlwifi 0000:02:00.0: 0x00011F73 | frame pointer
[ 9.505965] iwlwifi 0000:02:00.0: 0xC0886AD4 | stack pointer
[ 9.505966] iwlwifi 0000:02:00.0: 0x00000000 | last host cmd
[ 9.505966] iwlwifi 0000:02:00.0: 0x00000000 | isr status reg
[ 9.505974] iwlwifi 0000:02:00.0: IML/ROM dump:
[ 9.505974] iwlwifi 0000:02:00.0: 0x00000003 | IML/ROM error/state
[ 9.505981] iwlwifi 0000:02:00.0: 0x00005ACE | IML/ROM data1
[ 9.505989] iwlwifi 0000:02:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 9.505993] iwlwifi 0000:02:00.0: Fseq Registers:
[ 9.505995] iwlwifi 0000:02:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 9.505998] iwlwifi 0000:02:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 9.506000] iwlwifi 0000:02:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 9.506003] iwlwifi 0000:02:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 9.506005] iwlwifi 0000:02:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 9.506007] iwlwifi 0000:02:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 9.506010] iwlwifi 0000:02:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 9.506012] iwlwifi 0000:02:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 9.506014] iwlwifi 0000:02:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 9.506019] iwlwifi 0000:02:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 9.506023] iwlwifi 0000:02:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 9.506028] iwlwifi 0000:02:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 9.506030] iwlwifi 0000:02:00.0: Failed to start RT ucode: -110
[ 9.506030] iwlwifi 0000:02:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 10.460241] iwlwifi 0000:02:00.0: Failed to run INIT ucode: -110
[ 10.475064] iwlwifi 0000:02:00.0: retry init count 2
lsusb
it only lists my device as a Bluetooth device though.
β°βΞ» lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 046d:c539 Logitech, Inc. USB Receiver
Bus 001 Device 005: ID 0416:0123 Winbond Electronics Corp. Ducky One2 SF RGB
Bus 001 Device 004: ID 046d:0aba Logitech, Inc. PRO X Wireless Gaming Headset
Bus 001 Device 003: ID 046d:0abb Logitech, Inc. PRO X Wireless Gaming Headset Battery Charger
Bus 001 Device 002: ID 194f:0303 PreSonus Audio Electronics, Inc. AudioBox USB 96
Bus 001 Device 011: ID 8087:0aaa Intel Corp. Bluetooth 9460/9560 Jefferson Peak (JfP)
Bus 001 Device 012: ID 8087:0029 Intel Corp. AX200 Bluetooth
Bus 001 Device 010: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 009: ID 048d:8297 Integrated Technology Express, Inc. IT8297 RGB LED Controller
Bus 001 Device 008: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 007: ID 0e8d:1887 MediaTek Inc. Slim Portable DVD Writer
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
** lspci -kv**
02:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200NGW
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at 55400000 (64-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
rfkill
ID TYPE DEVICE SOFT HARD
0 wlan phy0 unblocked unblocked
1 bluetooth hci0 unblocked unblocked
2 bluetooth hci1 unblocked unblocked
I have already:
Tried installing the drivers
Disabling Fast Boot
Disabling Secure Boot
Disabling Hibernation
Updating Bios
