Hello,
I just installed Garuda and tried to install other Software-Apps.
But the Button ' Add/Remove Software' in the Garuda-Welcome screen doesn't work.
So please where I can find Pacman or Octopi?
Regards
Rallebiker
Hello,
Regards
Rallebiker
The suggested method for installing software in Garuda is via pacman, from the command line.
Learn more here and here.
You probably were thinking to pamac, but we believe that it can create troubles in many cases.
And to update the system,
garuda-update
As for the issue with Add/remove software, please provide your garuda-inxi as requested in the topic template.
First of all, anyway, update your system as suggested above. Octopi had an issue a few days ago, fixed with a "rebuild", for which it didn't start as per your issue.
Thank you, but in case to work on commandline means that I would know the name of the package.
You can search with
pacman -Ss <name>
Or you could consider eg pacseek
sudo pacman -Syu pacseek
Anyway Octopi is fine for searching.
Have you tried
garuda-update
And reboot?
Sorry but I don't understand your community software.
Can't use 'quote' ans 'code'.
:: Paketdatenbanken werden synchronisiert …
garuda ist aktuell
core ist aktuell
extra ist aktuell
community 7,2 MiB 14,4 MiB/s 00:01 [----------------------] 100%
multilib ist aktuell
chaotic-aur ist aktuell
--> Refreshing mirrorlists using rate-mirrors, please be patient..
garuda 95,9 KiB 184 KiB/s 00:01 [----------------------] 100%
core 157,7 KiB 1314 KiB/s 00:00 [----------------------] 100%
extra 1754,2 KiB 6,85 MiB/s 00:00 [----------------------] 100%
community 7,2 MiB 16,3 MiB/s 00:00 [----------------------] 100%
multilib 170,1 KiB 1417 KiB/s 00:00 [----------------------] 100%
chaotic-aur 2029,5 KiB 3,89 MiB/s 00:01 [----------------------] 100%
spawn pacman -Su
there is nothing to do
Checking for plugin updates
Nothing to install / update
System updated! 🐧
Kernel: 5.15.78-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8c18065f-324f-4827-860a-7a87f7ad3c7c rw rootflags=subvol=@
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20KD001MMD v: ThinkPad A275
Mobo: LENOVO model: 20KD001MMD serial: <superuser required> UEFI: LENOVO
v: R0NET46W (1.24 ) date: 04/13/2021
ID-1: BAT0 charge: 14.7 Wh (79.5%) condition: 18.5/23.2 Wh (79.9%)
volts: 12.0 min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
status: not charging cycles: 20
ID-2: BAT1 charge: 18.8 Wh (87.9%) condition: 21.4/23.5 Wh (91.1%)
volts: 11.9 min: 11.4 model: LGC 45N1127 type: Li-ion serial: <filter>
status: discharging cycles: 42
Info: model: AMD PRO A12-8830B R7 10 COMPUTE CORES 4C+6G bits: 64
type: MT MCP arch: Excavator level: v3 note: check built: 2015
process: GF 28nm family: 0x15 (21) model-id: 0x65 (101) stepping: 1
microcode: 0x600611A
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 320 KiB
desc: d-4x32 KiB; i-2x96 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1291 high: 1297 min/max: 1300/2500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1296 2: 1283
3: 1297 4: 1289 bogomips: 19964
prctl and seccomp
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: Lenovo driver: amdgpu
v: kernel arch: GCN-3 code: Volcanic Islands process: TSMC 28nm
built: 2014-19 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:01.0
chip-ID: 1002:9874 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-1.3:3 chip-ID: 04f2:b5ab class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x226d built: 2015
res: 1920x1080 hz: 60 dpi: 177 gamma: 1.2 size: 276x155mm (10.87x6.1")
diag: 317mm (12.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
missing.
Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound API: ALSA v: k5.15.78-1-lts running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
port: 1400 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f0 state: down mac: <filter>
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd
bus-ID: 1-1.4.2:6 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 476.94 GiB used: 49.41 GiB (10.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS512GD9TNG-L5B0B size: 476.94 GiB block-size: physical: 512 B
rev: 80750C10 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
used: 15.77 GiB (6.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 26.5 MiB (27.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
ID-4: /var/log raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.19 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): fan-1: 4300
Processes: 248 Uptime: 2m wakeups: 2 Memory: 7.19 GiB used: 1.56 GiB (21.8%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1455 libs: 382
tools: octopi,pamac,paru Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-15
Last full system update: 2022-11-16
Octopi (Add/Remove software) works fine here (I’m on Dr460nized), from Latte-dock, from Application Launcher, etc.
Does it start from terminal?
/usr/bin/octopi
You can post your
by editing one of your posts.
Thanks for providing your garuda-inxi.
I’ve restored the topic and moved it to the xfce category.
Could you please check if octopi can be launched from the terminal or the menu?
You do have these already:
Maybe this could help:
Thanks for help to all.
Octopi , Pamac and Pacseek (with yay) are working very well now.
Will try to learn nicely formatted posts here.
