I want to try ndiswrapper because but internet is unavailable every 20mins (but wifi doesn't disconnect). I also have to click connect and disconnect multiple times before getting wifi connected while the loading status is shown in taskbar or else it keeps loading for a long time.
Might it be related to this issue - Doesn't build with Linux 5.8 · Issue #6 · pgiri/ndiswrapper · GitHub ?
Kernel: 5.15.54-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=bef56164-5782-4129-94fa-5969dc499b60 rw rootflags=subvol=@
Console: pty pts/0 wm: xfwm v: 4.16.1 DM: LightDM v: 1.30.0
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: N/A
Mobo: HP model: 81EC v: 61.59 serial: <filter> UEFI: Insyde v: F.46
date: 11/16/2018
ID-1: BAT1 charge: 0.9 Wh (100.0%) condition: 0.9/32.1 Wh (2.7%)
volts: 16.5 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-6200U socket: U3E1 bits: 64 type: MT MCP
arch: Skylake gen: core 6 built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 400/2800 base/boost: 2200/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 19200
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
arch: GCN 1 process: TSMC 28nm built: 2011-20 pcie: gen: 3 speed: 8 GT/s
lanes: 4 link-max: lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6660
class-ID: 0380
Device-3: Chicony HP TrueVision HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 04f2:b56c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting,radeon alternate: fbdev,intel,vesa gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: eDP-1 model: BOE Display 0x0687 built: 2015 res: 1920x1080
ratio: 16:9 modes: 1920x1080
Sound Server-1: ALSA v: k5.15.54-1-lts running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard
bus-ID: 03:00.0 chip-ID: 14e4:4365 class-ID: 0280
IF-ID-1: enp0s20f0u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung Galaxy series misc. (tethering mode) type: USB
driver: rndis_host v: kernel bus-ID: 1-2:10 chip-ID: 04e8:6863
Device-2: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-4:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Report: ID: hci0 rfk-id: 8 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter>
Local Storage: total: 931.51 GiB used: 48.79 GiB (5.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100M
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1U scheme: GPT
ID-1: / raw-size: 96.68 GiB size: 96.68 GiB (100.00%)
used: 48.73 GiB (50.4%) fs: btrfs block-size: 4096 B dev: /dev/sda7
maj-min: 8:7
ID-2: /boot/efi raw-size: 102 MiB size: 96 MiB (94.12%)
used: 56.3 MiB (58.6%) fs: vfat block-size: 512 B dev: /dev/sda2
maj-min: 8:2
ID-3: /home raw-size: 96.68 GiB size: 96.68 GiB (100.00%)
maj-min: 8:7
ID-4: /var/log raw-size: 96.68 GiB size: 96.68 GiB (100.00%)
maj-min: 8:7
ID-5: /var/tmp raw-size: 96.68 GiB size: 96.68 GiB (100.00%)
maj-min: 8:7
ID-1: swap-1 type: zram size: 3.6 GiB used: 1.28 GiB (35.6%)
System Temperatures: cpu: 41.0 C pch: 39.0 C mobo: N/A gpu: radeon
temp: 39.0 C
Processes: 243 Uptime: 17h 58m wakeups: 39 Memory: 3.6 GiB
used: 2.22 GiB (61.7%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1276
lib: 333 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-04-04
Last full system update: 2022-07-14
Is partially upgraded: Yes
Windows dual boot: Yes
Edit: broadcom
