Hi,
I'd like to install this Hyprland Edition alongside my existing KDE Dr460nized Edition. I have my drive split into mulitple partitions, so the Editions will remain seperate from each other. My concern is, what will happen to GRUB, having two "Garuda" entries? If I end up with two Garuda entries in GRUB, how will I be able to identify which is KDE and which is Hyprland?
Many thanks!
garuda-inxi, if necessary:
Kernel: 6.1.51-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4c53965d-52cb-489d-aab3-ae07a0ff2075 rw rootflags=subvol=@
Type: Desktop System: Micro-Star product: MS-7B51 v: 1.0
Mobo: Micro-Star model: MPG Z390 GAMING PLUS (MS-7B51) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.80
date: 12/26/2019
Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
Info: model: Intel Core i5-9600KF bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
desc: 1x9 MiB
Speed (MHz): avg: 4465 high: 4487 min/max: 800/4600:4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4486 2: 4487 3: 4400
4: 4486 5: 4487 6: 4449 bogomips: 44412
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:2182 class-ID: 0300
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 046d:0825
Screen-1: 0 s-res: 3440x1440 s-dpi: 110 s-size: 794x333mm (31.26x13.11")
s-diag: 861mm (33.9")
Monitor-1: HDMI-0 res: 3440x1440 dpi: 110 size: 797x333mm (31.38x13.11")
diag: 864mm (34.01") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX 1660
Ti/PCIe/SSE2 direct-render: Yes
Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.1.51-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 3.64 TiB used: 3.19 TiB (87.6%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Crucial model: CT1000P2SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR033 temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR013 temp: 38.9 C
model: WD10EZRX-00L4HB0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD110
tech: HDD rpm: 7200 serial: <filter> fw-rev: A8J0 scheme: MBR
ID-1: / raw-size: 46.57 GiB size: 46.57 GiB (100.00%)
used: 36.96 GiB (79.4%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:6
ID-2: /boot/efi raw-size: 619 MiB size: 617.8 MiB (99.80%)
used: 222.3 MiB (36.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 46.57 GiB size: 46.57 GiB (100.00%)
ID-4: /var/log raw-size: 46.57 GiB size: 46.57 GiB (100.00%)
ID-5: /var/tmp raw-size: 46.57 GiB size: 46.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 1.2 MiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
ID-2: swap-2 type: partition size: 3.91 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 42.0 C pch: 51.0 C mobo: 34.0 C gpu: nvidia
temp: 42 C
Fan Speeds (rpm): fan-1: 0 fan-2: 828 fan-3: 956 fan-4: 760 fan-5: 783
fan-6: 825 fan-7: 0 gpu: nvidia fan: 47%
Processes: 301 Uptime: 52m wakeups: 4 Memory: total: 32 GiB
available: 31.28 GiB used: 8.67 GiB (27.7%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2162 libs: 560 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date: 2023-08-07
Last full system update: 2023-09-07 ↻
