Before we get started…
╭─fenris@fenris in ~ as 🧙 took 1m11s
╰─λ garuda-inxi
Kernel: 6.1.60-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=576a4f6d-5c57-475b-8279-4f23d821f833 rw rootflags=subvol=@
quiet resume=UUID=6feff68d-462f-4c25-aead-653957ef83a3 loglevel=3 ibt=off
Type: Desktop Mobo: AZW model: MINI S v: 10 serial: <superuser required>
UEFI: American Megatrends LLC. v: ADLNV104 date: 02/06/2023
Info: model: Intel N100 bits: 64 type: MCP arch: Alder Lake level: v3
note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x11
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 724 high: 799 min/max: 700/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 700 3: 700 4: 799
bogomips: 6452
Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: HDMI-A-1
empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:46d1 class-ID: 0300
Display: x11 server: X.Org v: 21.1.9 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer G247HYL serial: <filter>
built: 2016 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: integrated-gpu
name: Intel Graphics (ADL-N) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:46d1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:54c8
Device-2: C-Media CM106 Like Sound Device
lanes: 1 mode: 1.1 bus-ID: 1-4.2:6 chip-ID: 0d8c:0102 class-ID: 0300
API: ALSA v: k6.1.60-1-lts status: kernel-api tools: N/A
Device-1: Intel CNVi: Wi-Fi driver: N/A modules: iwlwifi bus-ID: 00:14.3
chip-ID: 8086:54f0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.1:3
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u4u1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
Local Storage: total: 931.51 GiB used: 6.15 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 4.12 GiB (4.1%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 719 GiB size: 719 GiB (100.00%)
used: 86.4 MiB (0.0%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 4.12 GiB (4.1%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
ID-2: swap-2 type: zram size: 15.4 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 247 Uptime: 38m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.4 GiB used: 2.31 GiB (15.0%) Init: systemd v: 254
pm: pacman pkgs: 1232 libs: 385 tools: paru Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-12-28
Last full system update: 2023-12-28
Is partially upgraded: Yes
╭─fenris@fenris in ~ took 2s
╰─λ
So I got a fresh install here, on a brand new Beelink Mini S Pro 12 computer, and I just finished installing it from a flash drive, so the first thing I do is try to do “garuda-update” before I do anything, but I get this…
[sudo] password for fenris:
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
error: failed retrieving file 'extra.db' from mirror.metalgamer.eu :
error: failed retrieving file 'extra.db' from repo.slithery.uk :
warning: garuda-settings-manager: local (1.0.2-5) is newer than garuda (1.0.2-3)
:: Replace mhwd-db-garuda-git with garuda/mhwd-db-garuda? [Y/n] y
resolving dependencies...
:: installing dotnet-runtime (8.0.0.sdk100-3) breaks dependency 'dotnet-runtime-7.0' required by pinta
Press enter to exit
I have tried different ways to trying to get the updates in there using a graphic updater, and sudo pacman -Syu however I don’t have much luck. Could someone please tell me what I should do so I can download my massive boat load of updates, thank you
