Like it says, I’m trying to install the cachyos kernel, however, when I run the sudo mkinitcpio -P command I get sudo: mkinitcpio: command not found.
I started to just install mkinitcpio, and it told me that garuda-dracut-suport would be removed, and I feel like that’s an important thing, since it does have “garuda” in the name. I know that the person that wrote this article doesn’t/didn’t use Garuda, so is there maybe a different way that I’m supposed to do this command? For instance, I know that instead of sudo grub-mkconfig -o /boot/grub/grub.cfg I should just run update-grub, so…ya know. TIA for any advice.
Kernel: 6.4.0-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=dac310bd-540f-47f8-ada4-63df4003b3bf rw rootflags=subvol=@
resume=UUID=62a15cae-218d-42b3-a04e-76a26a7f2fde loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Desktop System: Gigabyte product: X570 AORUS ELITE WIFI v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE WIFI serial: <superuser required>
UEFI: American Megatrends LLC. v: F37d date: 07/20/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3845 high: 4389 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3685 2: 3641
3: 4342 4: 3636 5: 4389 6: 3889 7: 3618 8: 3667 9: 3700 10: 3638 11: 4345
12: 3600 bogomips: 88827
vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0d:00.0
chip-ID: 1002:73df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 3440x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon RX 6750 XT (navi22
LLVM 15.0.7 DRM 3.52 6.4.0-1-mainline) direct-render: Yes
Device-1: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 1102:0012 class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab28
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.4.0-1-mainline status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2 chip-ID: 8087:0aa7
Local Storage: total: 2.29 TiB used: 159.51 GiB (6.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.1 temp: 28.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QEXP7 temp: 32.9 C
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 159.51 GiB (8.6%)
used: 159.51 GiB (8.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.54 GiB used: 1.7 GiB (10.9%)
ID-2: swap-2 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 41.9 C mobo: 32.0 C gpu: amdgpu temp: 44.0 C
mem: 40.0 C
Processes: 398 Uptime: 1h 35m wakeups: 0 Memory: available: 15.54 GiB
used: 7.35 GiB (47.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 2105 libs: 585 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
warning: config file /etc/pacman.conf, line 40: directive 'unimatrix -w -s 99 -c red -a' in section 'options' not recognized.
System install date: 2023-07-01
Last full system update: 2023-07-02 ↻
