Hello! I've been trying to install Garuda Gnome without success multiple times. I've tried both booting with open source drivers and NVIDIA drivers; both times get me the same error. I've tried two different laptops with a decent difference in hardware (one high end, the other mid). I'm not sure if it's something I'm doing wrong, but if it is, could you maybe explain the why behind the what for me so I can learn? Inxi is posted below:
Result of garuda-inxi from live iso:
misobasedir=garuda misolabel=GARUDA_GNOME_TALON quiet
systemd.show_status=1 ibt=off driver=free nouveau.modeset=1
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: ASUSTeK product: ASUS TUF Dash F15 FX516PM_FX516PM
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX516PM v: 1.0 serial: <filter> UEFI: American
Megatrends LLC. v: FX516PM.322 date: 08/27/2021
ID-1: BAT0 charge: 52.2 Wh (84.6%) condition: 61.7/76.0 Wh (81.1%)
status: charging cycles: 75
Info: model: 11th Gen Intel Core i7-11370H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check
built: 2020 process: Intel 10nm family: 6 model-id: 0x8C (140)
stepping: 1 microcode: 0xA4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2739 high: 3300 min/max: 400/4800 base/boost: 3300/4800
ext-clock: 100 MHz cores: 1: 3300 2: 3300 3: 1128 4: 3300 5: 986 6: 3300
7: 3300 8: 3300 bogomips: 52838
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-10)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 ports:
active: none empty: HDMI-A-2 bus-ID: 0000:01:00.0 chip-ID: 10de:2520
Display: server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: modesetting,nouveau
Monitor-1: eDP-1 model: Najing CEC Panda 0x004d built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 0000:2e:00.0
bus-ID: 3-10:3 chip-ID: 8087:0026 class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 593.04 GiB used: 6.34 GiB (1.1%)
rev: FXM7201Q temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 96d 8h cycles: 935 read-units: 28,002,406
[14.3 TB] written-units: 40,388,442 [20.6 TB]
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SMI (STMicroelectronics)
model: USB DISK size: 116.1 GiB block-size: physical: 512 B logical: 512 B
type: N/A serial: <filter> rev: 1100 scheme: MBR
ID-1: swap-1 type: zram size: 15.32 GiB used: 290.2 MiB (1.9%)
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 290 Uptime: 23m wakeups: 2324 Memory: 15.32 GiB used: 3.45 GiB
(22.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1134 libs: 314
tools: pamac,paru Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-12-05
Last full system update: 2022-12-04 ↻
Windows dual boot: Yes
