Maulve
26 January 2024 18:53
1
Hello, Im trying to install Garuda Linux KDE Dr460nized.
During the installation on the command
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Garuda --force
it gave me the error code 1.
Note: I know that this is related to the UEFI settings of the BIOS, however I have no idea if I have UEFI boot enabled on my BIOS, since the only option under UEFI is something like “Network Stacking”.
The usb drive the iso is flashed to is set to “EFI Enabled”.
(Insyde H2O BIOS)
Sorry for potentially wasting your time, I’m just really frustrated with this right now and would appreciate any kind of help.
garuda@garuda-dr460nized
OS: Garuda Linux x86_64
Host: SEMRUK S7 V8.1
Kernel: 6.5.9-zen2-1-zen
Uptime: 9 mins
Battery: 100%% [Full]
Packages: 1250 (pacman)[stable]
Shell: fish 3.6.1
Terminal: konsole 23.8.2
CPU: 11th Gen Intel(R) Core(TM) i9-11900K (16) @ 5.10 GHz
GPU: NVIDIA GeForce RTX 3080 Mobile / Max-Q 8GB/16GB
Memory: 3.89 GiB / 31.21 GiB (12%)
╭─garuda@garuda in ~ as 🧙
╰─λ garuda-inxi
misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZED_RAPTOR quiet
systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0
Type: Laptop System: MONSTER product: SEMRUK S7 V8.1 v: N/A
Mobo: MONSTER model: SEMRUK S7 V8.1 serial: <superuser required>
UEFI: INSYDE v: 1.07.01TFB date: 01/11/2020
ID-1: BAT0 charge: 98.4 Wh (100.0%) condition: 98.4/96.5 Wh (102.0%)
volts: 16.3 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Info: model: 11th Gen Intel Core i9-11900K bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x59
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3254 high: 4603 min/max: 800/5100:5300 scaling:
driver: intel_pstate governor: powersave cores: 1: 4367 2: 801 3: 800
4: 2037 5: 3738 6: 4258 7: 4269 8: 4259 9: 4246 10: 4337 11: 4241 12: 4603
13: 800 14: 800 15: 4232 16: 4279 bogomips: 112128
Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: CLEVO/KAPOK driver: N/A alternate: nouveau non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24dc class-ID: 0300
Device-2: Bison [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-8:6 chip-ID: 5986:9102 class-ID: 0e02
alternate: fbdev,nouveau,nv,vesa gpu: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.63x7.99")
s-diag: 338mm (13.3")
Monitor-1: Unknown-1 mapped: None-1 res: 1024x768 hz: 60 size: N/A
modes: 1024x768
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast x11: drv: swrast inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 23.2.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 30.48 GiB unified: yes
Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: CLEVO/KAPOK
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Razer USA [] driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:9 chip-ID: 1532:0552
class-ID: 0301 serial: <filter>
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: N/A
modules: iwlwifi pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 6c:00.0
Device-2: Realtek Killer E3000 2.5GbE vendor: CLEVO/KAPOK driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 6d:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp109s0 state: down mac: <filter>
IF-ID-1: enp0s20f0u4 state: unknown speed: -1 duplex: half mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0032
Device-2: Samsung Galaxy series misc. (tethering mode) driver: rndis_host
v: kernel type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-4:11 chip-ID: 04e8:6863 class-ID: 0a00 serial: <filter>
Local Storage: total: 968.52 GiB used: 0 KiB (0.0%)
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: GXA7301Q temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: N/A size: 14.65 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00 scheme: MBR
ID-1: swap-1 type: zram size: 31.21 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 78.0 C mobo: N/A
Processes: 284 Uptime: 9m wakeups: 7696 Memory: total: 32 GiB
available: 31.21 GiB used: 4.36 GiB (14.0%) Init: systemd v: 254
pm: pacman pkgs: 1250 libs: 347 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2024-01-26
Last full system update: 2024-01-26 ↻
╭─garuda@garuda in ~ as 🧙 took 4s
╰─λ
Maulve
26 January 2024 19:39
3
Regarding the Boot Repair, I get the error
Installing for i386-pc platform.
grub-install: error: cannot open `/usr/lib/grub/i386-pc/fs.lst': No such file or directory.
I get this or a similar error for all 3 options to reinstall grub
(MBR, root, ESP)
I will now try to chroot to fix things, following the instructions of the post you linked.
no idea
I think you most likely have UEFI on so check if you have ESP partitions before trying to install to MBR
Maulve
26 January 2024 19:57
5
I do have an ESP partition (at least if i’m reading this correctly)
Trying to reinstall on ESP in the Boot Repair gives me this error
Installing for x86_64-efi platform.
grub-install: error: cannot open `/usr/lib/grub/x86_64-efi/fs.lst': No such file or directory.
Edit: trying to chroot into it and install grub results in the same error
Disk info
sudo fdisk -l
Disk /dev/nvme0n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: SAMSUNG MZVL21T0HCLR-00B00
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 3F076340-67E6-47FC-B3E1-96D9D309F3F6
Device Start End Sectors Size Type
/dev/nvme0n1p1 4096 618495 614400 300M EFI System
/dev/nvme0n1p2 618496 2000397734 1999779239 953.6G Linux filesystem
Disk /dev/sda: 14.65 GiB, 15728640000 bytes, 30720000 sectors
Disk model: ProductCode
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 64 5122467 5122404 2.4G 0 Empty
/dev/sda2 5122468 5130659 8192 4M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 18.94 MiB, 19857408 bytes, 38784 sectors
Disk /dev/loop1: 430 MiB, 450883584 bytes, 880632 sectors
Disk /dev/loop2: 1.25 GiB, 1337995264 bytes, 2613272 sectors
Disk /dev/loop3: 680.74 MiB, 713805824 bytes, 1394152 sectors
Disk /dev/zram0: 31.21 GiB, 33515634688 bytes, 8182528 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
I see this is persisting but I’m not sure what it means.
The file is owned by package grub
, I don’t think it can be missing from the live disk?
What ISO by the way, not some pre-release?
edit: I see there are two EFI partitions, which is the correct one? the nvme I think?
Maulve
26 January 2024 20:10
7
I’m currently on Live ISO
The ISO was downloaded from the official garudalinux website, from the downloads page. I assume it’s not any pre-release. (I can’t find any garuda version in system info)
I did
mount | grep /boot/efi
to see if the /boot/efi directory exists, but apparently it doesn’t exist:
/dev/nvme0n1p1 on /tmp/calamares-root-vj6jgdas/boot/efi type vfat (rw,noatime,fmask=0022,dmask=0022,
codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
/dev/nvme0n1p1 on /mnt/broken/@/boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,i
/boot/broken is from when I tried to chroot, the other seems to be a temp directory
I can’t see any actual /boot/efi directory here, except I’m missing something
Maulve
26 January 2024 20:13
8
Two EFI Partitions?
I only see /dev/nvme0n1p1 - the EFI partition
and /dev/nvme0np2 - the garuda install
maybe I misunderstand
is the /boot/efi
of the main system
Maulve
26 January 2024 20:17
10
but /mnt/broken is the direction I created to chroot in
as seen in this guide
yes, and its @
volume is mounted there, so anything below /mnt/broken/@/
is actually the main system while in chroot. That is the whole point of chroot.
this /usr/lib/grub/x86_64-efi/fs.lst
has me scratching my head, is it there in the main system and the live ISO?
Maulve
26 January 2024 20:24
12
Ah ok.
(btw could you tell me how I check if it’s on the main system? I think this just checks on the ISO)
But yes, fs.lst does exist:
╭─garuda@garuda in /usr/lib/grub/x86_64-efi🔒 via C v13.2.1-gcc via v3.11.5 as 🧙 took 33s
[🔍] × ls
.rw-r--r-- 16k root 8 Oct 2023 acpi.mod
.rw-r--r-- 1.8k root 8 Oct 2023 adler32.mod
.rw-r--r-- 7.9k root 8 Oct 2023 affs.mod
.rw-r--r-- 8.2k root 8 Oct 2023 afs.mod
.rw-r--r-- 2.0k root 8 Oct 2023 afsplitter.mod
.rw-r--r-- 22k root 8 Oct 2023 ahci.mod
.rw-r--r-- 704 root 8 Oct 2023 all_video.mod
.rw-r--r-- 1.4k root 8 Oct 2023 aout.mod
.rw-r--r-- 5.0k root 8 Oct 2023 appleldr.mod
.rw-r--r-- 4.4k root 8 Oct 2023 archelp.mod
.rw-r--r-- 6.5k root 8 Oct 2023 at_keyboard.mod
.rw-r--r-- 8.5k root 8 Oct 2023 ata.mod
.rw-r--r-- 2.4k root 8 Oct 2023 backtrace.mod
.rw-r--r-- 9.3k root 8 Oct 2023 bfs.mod
.rw-r--r-- 3.1k root 8 Oct 2023 bitmap.mod
.rw-r--r-- 5.2k root 8 Oct 2023 bitmap_scale.mod
.rw-r--r-- 3.4k root 8 Oct 2023 bli.mod
.rw-r--r-- 2.9k root 8 Oct 2023 blocklist.mod
.rw-r--r-- 3.6k root 8 Oct 2023 boot.mod
.rw-r--r-- 1.9k root 8 Oct 2023 boottime.mod
.rw-r--r-- 49k root 8 Oct 2023 bsd.mod
.rw-r--r-- 3.1k root 8 Oct 2023 bswap_test.mod
.rw-r--r-- 27k root 8 Oct 2023 btrfs.mod
.rw-r--r-- 2.8k root 8 Oct 2023 bufio.mod
.rw-r--r-- 2.1k root 8 Oct 2023 cacheinfo.mod
.rw-r--r-- 4.2k root 8 Oct 2023 cat.mod
.rw-r--r-- 5.6k root 8 Oct 2023 cbfs.mod
.rw-r--r-- 5.6k root 8 Oct 2023 cbls.mod
.rw-r--r-- 3.8k root 8 Oct 2023 cbmemc.mod
.rw-r--r-- 1.5k root 8 Oct 2023 cbtable.mod
.rw-r--r-- 4.4k root 8 Oct 2023 cbtime.mod
.rw-r--r-- 8.0k root 8 Oct 2023 chain.mod
.rw-r--r-- 4.5k root 8 Oct 2023 cmdline_cat_test.mod
.rw-r--r-- 3.3k root 8 Oct 2023 cmp.mod
.rw-r--r-- 6.2k root 8 Oct 2023 cmp_test.mod
.rw-r--r-- 3.7k root 8 Oct 2023 command.lst
.rw-r--r-- 5.7k root 8 Oct 2023 config.h
.rw-r--r-- 3.2k root 8 Oct 2023 configfile.mod
.rw-r--r-- 4.3k root 8 Oct 2023 cpio.mod
.rw-r--r-- 4.3k root 8 Oct 2023 cpio_be.mod
.rw-r--r-- 2.5k root 8 Oct 2023 cpuid.mod
.rw-r--r-- 2.1k root 8 Oct 2023 crc64.mod
.rw-r--r-- 936 root 8 Oct 2023 crypto.lst
.rw-r--r-- 6.8k root 8 Oct 2023 crypto.mod
.rw-r--r-- 22k root 8 Oct 2023 cryptodisk.mod
.rw-r--r-- 3.8k root 8 Oct 2023 cs5536.mod
.rw-r--r-- 2.5k root 8 Oct 2023 ctz_test.mod
.rw-r--r-- 3.1k root 8 Oct 2023 date.mod
.rw-r--r-- 2.9k root 8 Oct 2023 datehook.mod
.rw-r--r-- 2.8k root 8 Oct 2023 datetime.mod
.rw-r--r-- 3.0k root 8 Oct 2023 disk.mod
.rw-r--r-- 13k root 8 Oct 2023 diskfilter.mod
.rw-r--r-- 1.2k root 8 Oct 2023 div.mod
.rw-r--r-- 7.8k root 8 Oct 2023 div_test.mod
.rw-r--r-- 2.7k root 8 Oct 2023 dm_nv.mod
.rw-r--r-- 2.9k root 8 Oct 2023 echo.mod
.rw-r--r-- 12k root 8 Oct 2023 efi_gop.mod
.rw-r--r-- 6.9k root 8 Oct 2023 efi_uga.mod
.rw-r--r-- 2.6k root 8 Oct 2023 efifwsetup.mod
.rw-r--r-- 6.4k root 8 Oct 2023 efinet.mod
.rw-r--r-- 3.7k root 8 Oct 2023 efitextmode.mod
.rw-r--r-- 26k root 8 Oct 2023 ehci.mod
.rw-r--r-- 8.7k root 8 Oct 2023 elf.mod
.rw-r--r-- 2.1k root 8 Oct 2023 eval.mod
.rw-r--r-- 8.4k root 8 Oct 2023 exfat.mod
.rw-r--r-- 2.0k root 8 Oct 2023 exfctest.mod
.rw-r--r-- 8.6k root 8 Oct 2023 ext2.mod
.rw-r--r-- 7.4k root 8 Oct 2023 extcmd.mod
.rw-r--r-- 9.8k root 8 Oct 2023 f2fs.mod
.rw-r--r-- 8.5k root 8 Oct 2023 fat.mod
.rw-r--r-- 0 root 8 Oct 2023 fdt.lst
.rw-r--r-- 26k root 8 Oct 2023 file.mod
.rw-r--r-- 2.8k root 8 Oct 2023 fixvideo.mod
.rw-r--r-- 19k root 8 Oct 2023 font.mod
.rw-r--r-- 219 root 8 Oct 2023 fs.lst
.rw-r--r-- 4.4k root 8 Oct 2023 fshelp.mod
.rw-r--r-- 46k root 8 Oct 2023 functional_test.mod
.rw-r--r-- 2.3k root 8 Oct 2023 gcry_arcfour.mod
.rw-r--r-- 9.0k root 8 Oct 2023 gcry_blowfish.mod
.rw-r--r-- 28k root 8 Oct 2023 gcry_camellia.mod
.rw-r--r-- 15k root 8 Oct 2023 gcry_cast5.mod
.rw-r--r-- 12k root 8 Oct 2023 gcry_crc.mod
.rw-r--r-- 16k root 8 Oct 2023 gcry_des.mod
.rw-r--r-- 3.3k root 8 Oct 2023 gcry_dsa.mod
.rw-r--r-- 3.9k root 8 Oct 2023 gcry_idea.mod
.rw-r--r-- 4.0k root 8 Oct 2023 gcry_md4.mod
.rw-r--r-- 4.5k root 8 Oct 2023 gcry_md5.mod
.rw-r--r-- 3.0k root 8 Oct 2023 gcry_rfc2268.mod
.rw-r--r-- 20k root 8 Oct 2023 gcry_rijndael.mod
.rw-r--r-- 7.8k root 8 Oct 2023 gcry_rmd160.mod
.rw-r--r-- 3.2k root 8 Oct 2023 gcry_rsa.mod
.rw-r--r-- 12k root 8 Oct 2023 gcry_seed.mod
.rw-r--r-- 16k root 8 Oct 2023 gcry_serpent.mod
.rw-r--r-- 8.1k root 8 Oct 2023 gcry_sha1.mod
.rw-r--r-- 5.1k root 8 Oct 2023 gcry_sha256.mod
.rw-r--r-- 6.0k root 8 Oct 2023 gcry_sha512.mod
.rw-r--r-- 13k root 8 Oct 2023 gcry_tiger.mod
.rw-r--r-- 33k root 8 Oct 2023 gcry_twofish.mod
.rw-r--r-- 23k root 8 Oct 2023 gcry_whirlpool.mod
.rw-r--r-- 6.3k root 8 Oct 2023 gdb_helper.py
.rw-r--r-- 8.6k root 8 Oct 2023 geli.mod
.rw-r--r-- 8.2k root 8 Oct 2023 gettext.mod
.rw-r--r-- 59k root 8 Oct 2023 gfxmenu.mod
.rw-r--r-- 17k root 8 Oct 2023 gfxterm.mod
.rw-r--r-- 4.3k root 8 Oct 2023 gfxterm_background.mod
.rw-r--r-- 7.6k root 8 Oct 2023 gfxterm_menu.mod
.rw-r--r-- 5.2k root 8 Oct 2023 gptsync.mod
.rw-r--r-- 12k root 8 Oct 2023 gzio.mod
.rw-r--r-- 7.4k root 8 Oct 2023 halt.mod
.rw-r--r-- 8.1k root 8 Oct 2023 hashsum.mod
.rw-r--r-- 10k root 8 Oct 2023 hdparm.mod
.rw-r--r-- 1.8k root 8 Oct 2023 hello.mod
.rw-r--r-- 4.0k root 8 Oct 2023 help.mod
.rw-r--r-- 4.3k root 8 Oct 2023 hexdump.mod
.rw-r--r-- 10k root 8 Oct 2023 hfs.mod
.rw-r--r-- 11k root 8 Oct 2023 hfsplus.mod
.rw-r--r-- 4.2k root 8 Oct 2023 hfspluscomp.mod
.rw-r--r-- 9.0k root 8 Oct 2023 http.mod
.rw-r--r-- 4.2k root 8 Oct 2023 iorw.mod
.rw-r--r-- 13k root 8 Oct 2023 iso9660.mod
.rw-r--r-- 8.8k root 8 Oct 2023 jfs.mod
.rw-r--r-- 11k root 8 Oct 2023 jpeg.mod
.rw-r--r-- 5.7k root 8 Oct 2023 json.mod
.rw-r--r-- 119k root 8 Oct 2023 kernel.img
.rw-r--r-- 6.3k root 8 Oct 2023 keylayouts.mod
.rw-r--r-- 2.8k root 8 Oct 2023 keystatus.mod
.rw-r--r-- 7.9k root 8 Oct 2023 ldm.mod
.rw-r--r-- 16k root 8 Oct 2023 legacy_password_test.mod
.rw-r--r-- 45k root 8 Oct 2023 legacycfg.mod
.rw-r--r-- 28k root 8 Oct 2023 linux.mod
.rw-r--r-- 8.5k root 8 Oct 2023 linux16.mod
.rw-r--r-- 4.5k root 8 Oct 2023 loadbios.mod
.rw-r--r-- 9.0k root 8 Oct 2023 loadenv.mod
.rw-r--r-- 4.8k root 8 Oct 2023 loopback.mod
.rw-r--r-- 6.3k root 8 Oct 2023 ls.mod
.rw-r--r-- 7.0k root 8 Oct 2023 lsacpi.mod
.rw-r--r-- 5.0k root 8 Oct 2023 lsefi.mod
.rw-r--r-- 3.6k root 8 Oct 2023 lsefimmap.mod
.rw-r--r-- 4.3k root 8 Oct 2023 lsefisystab.mod
.rw-r--r-- 2.8k root 8 Oct 2023 lsmmap.mod
.rw-r--r-- 7.2k root 8 Oct 2023 lspci.mod
.rw-r--r-- 3.8k root 8 Oct 2023 lssal.mod
.rw-r--r-- 5.8k root 8 Oct 2023 luks.mod
.rw-r--r-- 21k root 8 Oct 2023 luks2.mod
.rw-r--r-- 12k root 8 Oct 2023 lvm.mod
.rw-r--r-- 6.6k root 8 Oct 2023 lzopio.mod
.rw-r--r-- 4.7k root 8 Oct 2023 macbless.mod
.rw-r--r-- 11k root 8 Oct 2023 macho.mod
.rw-r--r-- 2.6k root 8 Oct 2023 mdraid09.mod
.rw-r--r-- 2.7k root 8 Oct 2023 mdraid09_be.mod
.rw-r--r-- 2.6k root 8 Oct 2023 mdraid1x.mod
.rw-r--r-- 3.1k root 8 Oct 2023 memdisk.mod
.rw-r--r-- 4.2k root 8 Oct 2023 memrw.mod
.rw-r--r-- 5.7k root 8 Oct 2023 minicmd.mod
.rw-r--r-- 5.5k root 8 Oct 2023 minix.mod
.rw-r--r-- 5.6k root 8 Oct 2023 minix2.mod
.rw-r--r-- 5.7k root 8 Oct 2023 minix2_be.mod
.rw-r--r-- 5.6k root 8 Oct 2023 minix3.mod
.rw-r--r-- 5.7k root 8 Oct 2023 minix3_be.mod
.rw-r--r-- 5.6k root 8 Oct 2023 minix_be.mod
.rw-r--r-- 9.1k root 8 Oct 2023 mmap.mod
.rw-r--r-- 5.3k root 8 Oct 2023 moddep.lst
.rw-r--r-- 2.5k root 8 Oct 2023 modinfo.sh
.rw-r--r-- 3.2k root 8 Oct 2023 morse.mod
.rw-r--r-- 43k root 8 Oct 2023 mpi.mod
.rw-r--r-- 3.6k root 8 Oct 2023 msdospart.mod
.rw-r--r-- 2.3k root 8 Oct 2023 mul_test.mod
.rw-r--r-- 22k root 8 Oct 2023 multiboot.mod
.rw-r--r-- 25k root 8 Oct 2023 multiboot2.mod
.rw-r--r-- 6.6k root 8 Oct 2023 nativedisk.mod
.rw-r--r-- 81k root 8 Oct 2023 net.mod
.rw-r--r-- 4.4k root 8 Oct 2023 newc.mod
.rw-r--r-- 9.8k root 8 Oct 2023 nilfs2.mod
.rw-r--r-- 175k root 8 Oct 2023 normal.mod
.rw-r--r-- 16k root 8 Oct 2023 ntfs.mod
.rw-r--r-- 5.6k root 8 Oct 2023 ntfscomp.mod
.rw-r--r-- 4.2k root 8 Oct 2023 odc.mod
.rw-r--r-- 2.1k root 8 Oct 2023 offsetio.mod
.rw-r--r-- 15k root 8 Oct 2023 ohci.mod
.rw-r--r-- 2.2k root 8 Oct 2023 part_acorn.mod
.rw-r--r-- 2.5k root 8 Oct 2023 part_amiga.mod
.rw-r--r-- 2.9k root 8 Oct 2023 part_apple.mod
.rw-r--r-- 4.1k root 8 Oct 2023 part_bsd.mod
.rw-r--r-- 2.6k root 8 Oct 2023 part_dfly.mod
.rw-r--r-- 2.1k root 8 Oct 2023 part_dvh.mod
.rw-r--r-- 3.2k root 8 Oct 2023 part_gpt.mod
.rw-r--r-- 2.9k root 8 Oct 2023 part_msdos.mod
.rw-r--r-- 2.4k root 8 Oct 2023 part_plan.mod
.rw-r--r-- 2.2k root 8 Oct 2023 part_sun.mod
.rw-r--r-- 2.4k root 8 Oct 2023 part_sunpc.mod
.rw-r--r-- 111 root 8 Oct 2023 partmap.lst
.rw-r--r-- 17 root 8 Oct 2023 parttool.lst
.rw-r--r-- 7.2k root 8 Oct 2023 parttool.mod
.rw-r--r-- 2.8k root 8 Oct 2023 password.mod
.rw-r--r-- 4.3k root 8 Oct 2023 password_pbkdf2.mod
.rw-r--r-- 7.4k root 8 Oct 2023 pata.mod
.rw-r--r-- 1.8k root 8 Oct 2023 pbkdf2.mod
.rw-r--r-- 3.4k root 8 Oct 2023 pbkdf2_test.mod
.rw-r--r-- 3.4k root 8 Oct 2023 pcidump.mod
.rw-r--r-- 19k root 8 Oct 2023 pgp.mod
.rw-r--r-- 11k root 8 Oct 2023 plainmount.mod
.rw-r--r-- 3.8k root 8 Oct 2023 play.mod
.rw-r--r-- 11k root 8 Oct 2023 png.mod
.rw-r--r-- 2.2k root 8 Oct 2023 priority_queue.mod
.rw-r--r-- 5.5k root 8 Oct 2023 probe.mod
.rw-r--r-- 3.7k root 8 Oct 2023 procfs.mod
.rw-r--r-- 3.1k root 8 Oct 2023 progress.mod
.rw-r--r-- 1.9k root 8 Oct 2023 raid5rec.mod
.rw-r--r-- 3.3k root 8 Oct 2023 raid6rec.mod
.rw-r--r-- 3.5k root 8 Oct 2023 random.mod
.rw-r--r-- 3.0k root 8 Oct 2023 rdmsr.mod
.rw-r--r-- 2.6k root 8 Oct 2023 read.mod
.rw-r--r-- 1.5k root 8 Oct 2023 reboot.mod
.rw-r--r-- 77k root 8 Oct 2023 regexp.mod
.rw-r--r-- 13k root 8 Oct 2023 reiserfs.mod
.rw-r--r-- 26k root 8 Oct 2023 relocator.mod
.rw-r--r-- 5.5k root 8 Oct 2023 romfs.mod
.rw-r--r-- 6.9k root 8 Oct 2023 scsi.mod
.rw-r--r-- 5.5k root 8 Oct 2023 search.mod
.rw-r--r-- 4.8k root 8 Oct 2023 search_fs_file.mod
.rw-r--r-- 4.9k root 8 Oct 2023 search_fs_uuid.mod
.rw-r--r-- 4.8k root 8 Oct 2023 search_label.mod
.rw-r--r-- 18k root 8 Oct 2023 serial.mod
.rw-r--r-- 912 root 8 Oct 2023 setjmp.mod
.rw-r--r-- 2.5k root 8 Oct 2023 setjmp_test.mod
.rw-r--r-- 8.2k root 8 Oct 2023 setpci.mod
.rw-r--r-- 7.7k root 8 Oct 2023 sfs.mod
.rw-r--r-- 3.1k root 8 Oct 2023 shift_test.mod
.rw-r--r-- 8.1k root 8 Oct 2023 signature_test.mod
.rw-r--r-- 3.3k root 8 Oct 2023 sleep.mod
.rw-r--r-- 3.0k root 8 Oct 2023 sleep_test.mod
.rw-r--r-- 8.3k root 8 Oct 2023 smbios.mod
.rw-r--r-- 3.0k root 8 Oct 2023 spkmodem.mod
.rw-r--r-- 9.9k root 8 Oct 2023 squash4.mod
.rw-r--r-- 3.2k root 8 Oct 2023 strtoull_test.mod
.rw-r--r-- 29k root 8 Oct 2023 syslinuxcfg.mod
.rw-r--r-- 4.8k root 8 Oct 2023 tar.mod
.rw-r--r-- 162 root 8 Oct 2023 terminal.lst
.rw-r--r-- 6.5k root 8 Oct 2023 terminal.mod
.rw-r--r-- 19k root 8 Oct 2023 terminfo.mod
.rw-r--r-- 7.4k root 8 Oct 2023 test.mod
.rw-r--r-- 2.0k root 8 Oct 2023 test_blockarg.mod
.rw-r--r-- 3.7k root 8 Oct 2023 testload.mod
.rw-r--r-- 3.4k root 8 Oct 2023 testspeed.mod
.rw-r--r-- 7.7k root 8 Oct 2023 tftp.mod
.rw-r--r-- 6.3k root 8 Oct 2023 tga.mod
.rw-r--r-- 2.3k root 8 Oct 2023 time.mod
.rw-r--r-- 8.1k root 8 Oct 2023 tpm.mod
.rw-r--r-- 3.6k root 8 Oct 2023 tr.mod
.rw-r--r-- 1.9k root 8 Oct 2023 trig.mod
.rw-r--r-- 1.8k root 8 Oct 2023 true.mod
.rw-r--r-- 12k root 8 Oct 2023 udf.mod
.rw-r--r-- 7.7k root 8 Oct 2023 ufs1.mod
.rw-r--r-- 7.8k root 8 Oct 2023 ufs1_be.mod
.rw-r--r-- 7.7k root 8 Oct 2023 ufs2.mod
.rw-r--r-- 9.8k root 8 Oct 2023 uhci.mod
.rw-r--r-- 18k root 8 Oct 2023 usb.mod
.rw-r--r-- 5.7k root 8 Oct 2023 usb_keyboard.mod
.rw-r--r-- 11k root 8 Oct 2023 usbms.mod
.rw-r--r-- 2.8k root 8 Oct 2023 usbserial_common.mod
.rw-r--r-- 3.3k root 8 Oct 2023 usbserial_ftdi.mod
.rw-r--r-- 3.7k root 8 Oct 2023 usbserial_pl2303.mod
.rw-r--r-- 2.2k root 8 Oct 2023 usbserial_usbdebug.mod
.rw-r--r-- 5.5k root 8 Oct 2023 usbtest.mod
.rw-r--r-- 41 root 8 Oct 2023 video.lst
.rw-r--r-- 8.7k root 8 Oct 2023 video.mod
.rw-r--r-- 8.3k root 8 Oct 2023 video_bochs.mod
.rw-r--r-- 8.9k root 8 Oct 2023 video_cirrus.mod
.rw-r--r-- 9.9k root 8 Oct 2023 video_colors.mod
.rw-r--r-- 28k root 8 Oct 2023 video_fb.mod
.rw-r--r-- 5.2k root 8 Oct 2023 videoinfo.mod
.rw-r--r-- 5.3k root 8 Oct 2023 videotest.mod
.rw-r--r-- 3.6k root 8 Oct 2023 videotest_checksum.mod
.rw-r--r-- 2.3k root 8 Oct 2023 wrmsr.mod
.rw-r--r-- 11k root 8 Oct 2023 xfs.mod
.rw-r--r-- 41k root 8 Oct 2023 xnu.mod
.rw-r--r-- 3.2k root 8 Oct 2023 xnu_uuid.mod
.rw-r--r-- 3.0k root 8 Oct 2023 xnu_uuid_test.mod
.rw-r--r-- 19k root 8 Oct 2023 xzio.mod
.rw-r--r-- 56k root 8 Oct 2023 zfs.mod
.rw-r--r-- 8.3k root 8 Oct 2023 zfscrypt.mod
.rw-r--r-- 10k root 8 Oct 2023 zfsinfo.mod
.rw-r--r-- 79k root 8 Oct 2023 zstd.mod
Maulve
26 January 2024 20:43
13
Alright I’ll come back to this tomorrow
Bro
27 January 2024 16:46
14
How did you write the ISO to USB? What procedure/application? Did you verify it? These are important factors.
Maulve
27 January 2024 20:45
15
After thinking about it earlier today, I decided to go for another distro since I just didn’t feel qualified for this. I will come back to Garuda some time though.
As an after thought, I was probably facing at least some of the problems I had because I didn’t verify the integrity of the ISO.
Sorry for wasting everyones time here.
Bro
27 January 2024 23:34
16
Please return any time. There can be several factors involved with any Linux distribution, especially with newer hardware. But I’ve seen only a very few cases where it was not possible and that was usually long ago. What we have to do is start with the basics, and here that starts with the ISO.
Plus we have some of the most experienced “troubleshooters” in the Linux realm. They will help you help yourself, I promise. That’s what we do here.
system
Closed
10 February 2024 23:35
17
