Installation failed and network problems
  Kernel: 6.13.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
    lang=en_US keytable=us tz=UTC misobasedir=garuda
    root=miso:LABEL=GARUDA_HYPRLAND_BROADWING quiet systemd.show_status=1
    checksum=y driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: Hyprland v: 0.47.2 with: waybar tools: hypridle avail: swaylock
    vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop X1504ZA_X1504ZA
  Mobo: ASUSTeK model: X1504ZA v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: X1504ZA.312
    date: 09/21/2023
  ID-1: BAT0 charge: 36.8 Wh (87.4%) condition: 42.1/42.1 Wh (100.0%)
    power: 14.1 W volts: 13.0 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion
    serial: N/A status: charging cycles: 39
  Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
    microcode: 0x436
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
    st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
    KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4400:3300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59904
  Device-1: Intel Alder Lake-UP3 GT2 [UHD Graphics] vendor: ASUSTeK
    built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
    chip-ID: 8086:4628 class-ID: 0300
  Device-2: Sonix ASUS HD webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:3 chip-ID: 2b7e:b868
    compositor: Hyprland v: 0.47.2 driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model: BOE Display 0x0c02 built: 2023 res:
    modes: 1920x1080
  API: Vulkan v: 1.4.304 layers: 4 device: 0 type: integrated-gpu name: Intel
    Graphics (ADL GT2) driver: N/A device-ID: 8086:4628
  Info: Tools: api: vulkaninfo wl: kanshi, wdisplays, wlr-randr x11: xprop
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
    bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.13.5-zen1-1-zen status: kernel-api
    bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 505.85 GiB used: 5.8 MiB (0.0%)
    model: MZVL4512HBLU-00BTW size: 476.94 GiB block-size: physical: 512 B
    fw-rev: HXC70W1Q temp: 28.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 model: General USB Flash Disk size: 28.91 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 1100 scheme: MBR
  ID-1: swap-1 type: zram size: 7.44 GiB used: 4.8 MiB (0.1%) priority: 100
    dev: /dev/nvme0n1p3 maj-min: 259:6
  System Temperatures: cpu: 52.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Memory: total: 8 GiB note: est. available: 7.44 GiB used: 3.14 GiB (42.2%)
  Processes: 311 Power: uptime: 17m states: freeze,mem,disk suspend: s2idle
    suspend, test_resume image: 2.94 GiB services: upowerd Init: systemd
    v: 257 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1259 libs: 363 tools: pacseek,paru Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.0 running-in: foot
    inxi: 3.3.37
  System install date:     2025-04-13
  Last full system update: 2025-04-12 ↻
calamares installer failed after setting up partitions:
'Installation Failed'
Bad main script file
Details:
Main script file /usr/lib/calamares/modules/mount/main.py for python job mount raised an exception.
i think if i manually setup the partitions i will be able to install hyprland… but then the network manager stop recognizing networks.
i’ve been trying to install hyprland for some hours now so i have some ideas (i wont be able to post the results as i cant connect to network after rebooting)
does linux-firmware recognize my network device? ill try to sudo systemctl start NetworkManager.service
there is ‘linux-firmware-asus’ and ‘linux-firmware-git’ ill try one at a time and seet if one of those does any good
and lastly ill try some iwlwifi aur packages to see if they fix anything
i cant screenshot in the installation media but now i can only do a manual partitioning.
regarding network issues ill paste some terminal output (before installing hyprland):
ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: wlo1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
    link/ether dc:45:46:d4:2b:f0 brd ff:ff:ff:ff:ff:ff
    altname wlp0s20f3
    altname wlxdc4546d42bf0
 ╰─λ sudo systemctl status NetworkManager.service
● NetworkManager.service - Network Manager
     Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
     Active: active (running) since Sat 2025-04-12 21:35:28 -03; 32min ago
 Invocation: 2bfd4ebf4abf4045aa4fd8fefa9629a3
       Docs: man:NetworkManager(8)
   Main PID: 872 (NetworkManager)
      Tasks: 4 (limit: 8876)
     Memory: 33.3M (peak: 35M)
        CPU: 2.384s
     CGroup: /system.slice/NetworkManager.service
             └─872 /usr/bin/NetworkManager --no-daemon
sudo dmesg | grep -i iwlwifi
[  144.611217] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz
[  144.693909] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-89.ucode failed with error -2
[  144.844819] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-78.ucode failed with error -2
[  144.850434] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[  144.865521] iwlwifi 0000:00:14.3: loaded firmware version 77.f92b5fed.0 so-a0-jf-b0-77.ucode op_mode iwlmvm
[  145.154347] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[  145.154399] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[  145.154451] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[  145.154467] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[  145.154576] iwlwifi 0000:00:14.3: Detected RF JF, rfid=0x105110
[  145.155874] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[  145.213613] iwlwifi 0000:00:14.3: base HW address: dc:45:46:d4:2b:f0
[  145.421493] iwlwifi 0000:00:14.3: timeout waiting for FW reset ACK (inta_hw=0x0)
[  145.421600] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[  145.421602] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[  145.421604] iwlwifi 0000:00:14.3: Loaded firmware version: 77.f92b5fed.0 so-a0-jf-b0-77.ucode
[  145.422233] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[  145.977142] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[  147.544714] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[  147.544771] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[  147.544780] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[  147.544788] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[  147.546363] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[  147.610822] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
[  147.836588] iwlwifi 0000:00:14.3: timeout waiting for FW reset ACK (inta_hw=0x0)
[  147.836704] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[  147.836705] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[  147.836707] iwlwifi 0000:00:14.3: Loaded firmware version: 77.f92b5fed.0 so-a0-jf-b0-77.ucode
[  147.836708] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[  148.416774] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[  148.418232] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
 ╰─λ sudo lspci -k | grep -A 3 -i network
0000:00:14.3 Network controller: Intel Corporation Alder Lake-P PCH CNVi WiFi (rev 01)
	DeviceName: WLAN
	Subsystem: Intel Corporation Dual Band Wi-Fi 5(802.11ac) Wireless-AC 9560 160MHz 2x2 [Jefferson Peak]
	Kernel driver in use: iwlwifi
 ╰─λ lsmod | grep iwlwifi
iwlwifi               630784  1 iwlmvm
cfg80211             1425408  3 iwlmvm,iwlwifi,mac80211
This might be a recently closed kernel regression:
Due to
wifi: iwlwifi: disable 160 MHz based on subsystem device ID
The driver should not send 160 MHz BW support for 5 GHz
band in HE if PCI subsystem device ID  indicates no 160 MHz support.
In my opinion you should try, using tethering with a mobile phone, to:
  • fully update your system (so including kernel and firmware) and install the LTS and mainline kernels
garuda-update linux-lts linux-lts-headers linux-mainline linux-mainline-headers
  • test all the kernels selecting them each time in the GRUB
  • bios update and pls think on the relevant entries inside bios (f-boot + secure-b), then
    ASUS Vivobook 15 (X1504) - Support
  • you have dualboot → disable hibernation + fastboot inside M$ + only cold start inside linux then.
Welcome to the forum @brianmatozo :waving_hand: :smiley:
Changing Iwlwifi driver options (parameters) is the most likely fix for Intel WiFi adapters.
See:
Hi! sorry for the abstract post, i was really tired at that time.. really liking hyprland so far!
yes! for me switching to LTS fixed the network issues
I’ll need to install windows to update the bios :frowning: . not really sure if the update will last trough the switch, i will try tho
i havent tried this yet as switching to lts fixed the issue, but ill keep this in mind ty!!
no… open the site…and scroll down ..
you can “read” BIOS for ASUS EZ Flash Utility
Hi and Welcome,
lol would write the same as @gampel . i can update my bios over the bios when you put the update file on a flash drive and start it over the bios ez update?upgrade tool;)
Asus is not Acer
did i overread something? i did not wrote acer? i was on the asus website and i have asus too.
Since some models are not able to update BIOS in Windows, this article will introduce how to update BIOS in BIOS Utility.
on my asus mainboard i have a button i can press to flash a new bios even with no other hardware only power supply but is not on a laptop .
Only typing..acer.. have only default bios update over M$. Almost all others offer several options. Alphabet thinking..sorry.
Because of his inxi I thought M$ is installed.
ah i got it yeah acer is very shitti i would say had problems on a acer pc to install hypr or even kde or mokka to it because there is some missing usb support in the isos or whatever :wink:
one last question.. can i use Wine to install drivers from the asus page?
I strongly advise against this, they are all windows drivers and do not work on Linux. :wink:
