No internet connection: Temporary failure in name resolution
Hey guys,
a few hours ago, the internet suddenly stopped working on my garuda system. First I thought, it’s a problem with my router or provider, but all the other devices worked flawless (TV with netflix, mobile phone, etc.). Then I thought it might be the laptop itself, but when i booted into my long discarded windows installation, the internet worked without any problem.
It stopped while watching a longer youtube video when I tried to go to the youtube homepage, no reboot or anything and I’m quite sure also no system update shortly before (there are still like 180 updates to install, if I remember correctly).
I searched the internet for solutions and therefor tried to change the resolv.conf (which I seem to be not allowed to change, it kept it’s content) and I also tried solutions mentioned here (Installation failed and network problems - #3 by filo - iwlwifi, even usb tethering from phone is not working to establish a connection).
My resolv.conf:
# Generated by NetworkManager
nameserver 0.0.0.0
nameserver ::1
garuda-inxi:
  Kernel: 6.14.4-x64v3-xanmod1-1-edge-x64v3 arch: x86_64 bits: 64
    compiler: gcc v: 14.2.1 clocksource: tsc avail: acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-edge-x64v3
    root=UUID=e18d9600-4e54-4041-b4f8-c0da3a3ed542 rw rootflags=subvol=@
    quiet resume=UUID=d54fbdad-bb20-42f9-ba05-581a2c98574a loglevel=3
    nvidia-drm.modeset=1 nvidia-drm.fbdev=1 splash acpi_backlight=native
    nvidia_drm.modeset=1 ibt=off
  Desktop: Hyprland v: 0.48.1 tools: hypridle
    avail: hyprlock,swayidle,swaylock vt: 1 dm: SDDM Distro: Garuda
  Type: Laptop System: Razer product: Blade 18 - RZ09-0484 v: 9.04
  Mobo: Razer model: KI890 v: 4 serial: <superuser required>
    part-nu: RZ09-0484UGH4 uuid: <superuser required> UEFI: Razer v: 2.05
    date: 09/19/2023
  ID-1: BAT0 charge: 57.7 Wh (74.5%) condition: 77.5/91.7 Wh (84.5%)
    volts: 16.0 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
    status: not charging cycles: 49
  Info: model: 13th Gen Intel Core i9-13950HX bits: 64 type: MST AMCP
    microcode: 0x12C
  Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
    st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
    KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
  Speed (MHz): avg: 3729 min/max: 800/5300:5500:4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3729 2: 3729 3: 3729
    4: 3729 5: 3729 6: 3729 7: 3729 8: 3729 9: 3729 10: 3729 11: 3729 12: 3729
    13: 3729 14: 3729 15: 3729 16: 3729 17: 3729 18: 3729 19: 3729 20: 3729
    21: 3729 22: 3729 23: 3729 24: 3729 25: 3729 26: 3729 27: 3729 28: 3729
    29: 3729 30: 3729 31: 3729 32: 3729 bogomips: 154828
  Device-1: NVIDIA AD103M / GN21-X11 [GeForce RTX 4090 Laptop GPU]
    vendor: Razer USA driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm
    non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: none off: DP-1,DP-2,eDP-1
    empty: DP-3,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2757 class-ID: 0300
  Device-2: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.4.2.1.2:21
    chip-ID: 1532:0e03 class-ID: 0102
  Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:6 chip-ID: 30c9:009e
    compositor: Hyprland v: 0.48.1 driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch d-rect: 3440x1600 display-ID: 1
  Monitor-1: DP-1 pos: primary model: PG34WCDM serial: <filter> built: 2024
    res: mode: 3440x1440 hz: 180 scale: 100% (1) dpi: 110 gamma: 1.2
    size: 800x330mm (31.3x13.11") diag: 862mm (33.9") modes: max: 3440x1440
    min: 640x480
  Monitor-2: DP-2 pos: primary model: PG34WCDM built: 2023 res:
    min: 640x480
  Monitor-3: eDP-1 pos: primary model: AU Optronics 0x46a7 built: 2022 res:
    mode: 2560x1600 hz: 240 scale: 100% (1) dpi: 168 gamma: 1.2
    size: 390x240mm (15.24x9.53") diag: 456mm (18") ratio: 16:10
    modes: 2560x1600
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090 Laptop
    GPU/PCIe/SSE2 memory: 15.62 GiB
  API: Vulkan v: 1.4.309 layers: 15 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4090 Laptop GPU driver: nvidia v: 570.144 device-ID: 10de:2757
    19.1.7 256 bits) driver: mesa llvmpipe v: 25.0.4-arch1.1 (LLVM 19.1.7)
    nvidia-smi wl: kanshi, nwg-displays, wayland-info, wdisplays, wlr-randr
  Device-1: Intel Raptor Lake High Definition Audio vendor: Razer USA
    snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0401
  Device-2: NVIDIA vendor: Razer USA driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb
  Device-3: SCUF Gaming PC Controller Dongle
    lanes: 1 mode: 1.1 bus-ID: 1-12.1:31 chip-ID: 2e95:434e class-ID: 0300
  Device-4: Razer USA Nari Ultimate driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
    chip-ID: 1532:051a class-ID: 0300
  Device-5: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
  Device-6: Razer USA Seiren Elite driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.4.3.1.1:22
    chip-ID: 1532:0516 class-ID: 0102 serial: <filter>
  API: ALSA v: k6.14.4-x64v3-xanmod1-1-edge-x64v3 status: kernel-api
    with: aoss type: oss-emulator tools: N/A
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  IF: wlan0 state: up mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Razer USA driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 6e:00.0
  IF: enp110s0 state: down mac: <filter>
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.4.5:6
  IF: enp56s0u1u4u5 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:11 chip-ID: 8087:0033
  Local Storage: total: 7.28 TiB used: 3.13 TiB (43.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Western Digital
    model: WD BLACK SN850X 4000GB size: 3.64 TiB block-size: physical: 512 B
    fw-rev: 624331WD temp: 39.9 C scheme: GPT
    fw-rev: 624361WD temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 3.61 TiB size: 3.61 TiB (100.00%) used: 3.13 TiB (86.9%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:9
    used: 192.4 MiB (64.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:8
  ID-3: /home raw-size: 3.61 TiB size: 3.61 TiB (100.00%)
    used: 3.13 TiB (86.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:9
  ID-4: /var/log raw-size: 3.61 TiB size: 3.61 TiB (100.00%)
  ID-5: /var/tmp raw-size: 3.61 TiB size: 3.61 TiB (100.00%)
    zswap: no
  ID-1: swap-1 type: zram size: 30.99 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
  ID-2: swap-2 type: partition size: 34.09 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:10
  System Temperatures: cpu: 41.8 C mobo: N/A
  Memory: total: 32 GiB note: est. available: 30.99 GiB used: 9.32 GiB (30.1%)
  Processes: 653 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
    suspend, test_resume image: 12.31 GiB
    services: power-profiles-daemon,upowerd Init: systemd v: 257
  Packages: 3161 pm: pacman pkgs: 3124 libs: 612
    tools: octopi,pacseek,pamac,paru,yay pm: appimage pkgs: 0 pm: flatpak
    pkgs: 37 Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: garuda-inxi
    default: Zsh v: 5.9 running-in: kitty inxi: 3.3.38
  System install date:     2024-12-11
  Last full system update: 2025-04-30
Maybe someone can help me, I’ll keep on trying in the mean time.
If there is something missing, I’ll try to respond as fast as possible, as I have to switch between OS’ and keep copying stuff to USB and back lol.
Thanks in advance.
EDIT:
systemctl status NetworkManager:
● NetworkManager.service - Network Manager
     Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
     Active: active (running) since Thu 2025-05-01 04:41:51 CEST; 11min ago
 Invocation: 1c1bc91f22b74106971c2cfc694ff584
       Docs: man:NetworkManager(8)
   Main PID: 1521 (NetworkManager)
      Tasks: 4 (limit: 37709)
     Memory: 25.9M (peak: 26.9M)
        CPU: 558ms
     CGroup: /system.slice/NetworkManager.service
             └─1521 /usr/bin/NetworkManager --no-daemon
Mai 01 04:51:26 Talahonikus NetworkManager[1521]: <info>  [1746067886.3134] audit: op="connection-update" uuid="bef3c082-d377-3ae4-b391-1d3c7eccc178" name="Kabelgebundene Verbindung 2" pid=4500 uid=1000 result="success"
Mai 01 04:51:26 Talahonikus NetworkManager[1521]: <info>  [1746067886.3188] audit: op="device-reapply" interface="enp56s0u1u4u5" ifindex=4 pid=4500 uid=1000 result="success"
Mai 01 04:51:26 Talahonikus NetworkManager[1521]: <info>  [1746067886.3266] audit: op="connection-update" uuid="99862d14-d732-3fab-8f07-347b3316ce09" name="Kabelgebundene Verbindung 3" args="connection.timestamp" pid=4500 uid=1000 result="success"
Mai 01 04:51:26 Talahonikus NetworkManager[1521]: <info>  [1746067886.3334] audit: op="device-reapply" interface="enp0s20f0u4" ifindex=6 pid=4500 uid=1000 result="success"
Mai 01 04:53:20 Talahonikus NetworkManager[1521]: <warn>  [1746068000.5102] dns-sd-resolved[5f5a20701d4302a3]: send-updates SetLinkDNS@5 failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: Invalid DNS server address
Mai 01 04:53:20 Talahonikus NetworkManager[1521]: <warn>  [1746068000.5125] dns-sd-resolved[5f5a20701d4302a3]: send-updates SetLinkDNS@5 failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: Invalid DNS server address
Mai 01 04:53:20 Talahonikus NetworkManager[1521]: <warn>  [1746068000.8575] dns-sd-resolved[5f5a20701d4302a3]: send-updates SetLinkDNS@5 failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: Invalid DNS server address
Mai 01 04:53:20 Talahonikus NetworkManager[1521]: <warn>  [1746068000.9175] dns-sd-resolved[5f5a20701d4302a3]: send-updates SetLinkDNS@5 failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: Invalid DNS server address
Mai 01 04:53:21 Talahonikus NetworkManager[1521]: <warn>  [1746068001.4834] dns-sd-resolved[5f5a20701d4302a3]: send-updates SetLinkDNS@5 failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: Invalid DNS server address
Mai 01 04:53:21 Talahonikus NetworkManager[1521]: <warn>  [1746068001.5325] dns-sd-resolved[5f5a20701d4302a3]: send-updates SetLinkDNS@5 failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: Invalid DNS server address
EDIT 2:
ping 8.8.8.8 or ping 1.1.1.1 results in 100% data loss
Be sure to reboot router, (other devices working is irrelevant).
Also try this:
(ping -c5 google.com 2>&1) && echo "true"
Post result please.
You can hard code/make immutable the /etc/resolv.conf file so that the DNS servers you select in /etc/resolv.conf cannot be altered.
To select/use the Cloudflare servers in /etc/resolv.conf, issue the following command:
echo -e "nameserver 1.1.1.1\nnameserver 1.0.0.1" | sudo tee /etc/resolv.conf
If you would prefer to use Google’s name servers, issue the following command:
echo -e "nameserver 8.8.8.8\nnameserver 8.8.4.4" | sudo tee /etc/resolv.conf
WRITE PROTECT THE RESOLV.CONF NAMESERVERS:
After changing your nameservers by editing /etc/resolv.conf write protect the file with the following command:
sudo chattr +i /etc/resolv.conf
The +i option (attribute) write protects the /etc/resolv.conf file on Linux so that no one can modify it - not even the root user.
If you need to remove the write protect attribute, use the following command:
sudo chattr -i /etc/resolv.conf
Hope something there helps @Tom.
Edit:
I would also “disable MAC adrress randomization”.
Hi @tbg thanks for your reply :slight_smile:
The router reboot did not lead to any changes.
Output of (ping -c5 google.com 2>&1) && echo “true”:
ping: google.com: Temporärer Fehler bei der Namensauflösung     (Temporary failure in name resolution)
I changed the resolv.conf with the given commands to the cloudflare ones, but ping google still shows the same result, also after restart of NetworkManager.service
It seems, I found the cause. I’m using Proton VPN with autostart for browsing safely, and the server region I was using seems to stopped working out of a sudden. As it didn’t show any specific error, I thought it can’t connect because of my Internet connection not establishing. Closing Proton VPN or switching to another server solved the problem.
Thanks a lot for the help and useful information/commands about resolv.conf.
