This is a follow-up to my original topic: Install stuck at “Finished LiveMedia Keyring setup.”
Unfortunately I missed the replies to my post and the thread got auto-closed.
I can confirm that even when using the latest image and booting through Ventoy, then selecting open source drivers for install, it still gets stuck after “Finished LiveMedia Keyring setup”.
SGS
24 March 2023 04:22
2
You do not post, again, your garuda-inxi.
You can post it from live ISO.
It could be on some hardware, that the mhwd prozess need mor then 5-10-? minutes
I had this on an 2009 "Medion" AMD CPU/GPU Desktop.
Most of the time, help is, to use free drivers, but without your garuda-inxi we are fishing in the dark
Output of garuda-inxi (apologies for the weirdness, I had to OCR it from a photo of the computer screen because I am not allowed to upload photos):
Kernel: 6.2.7-zen1-1-zen arch: ×86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-×86_64 lang=en_US keytable=us t2=UTC misobasedir=garuda
Info: model: 12th Gen Intel Core 15-12600K bits: 64 type: MST AMCP arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+ process: Intel 7 (10mm ESF) family: 6 model-id: 0×97 (151)
stepping: 2 microcode: 0×25
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled cache: L1: 864 KiB
desc: d-4×32 KiB. 6×48 KiB; 1-6×32 KiB.
4×64 KiB L2: 9.5 MiB desc: 6x1.2 MiB.
1x2 MiB L3: 20 MiB
desc: 1x20 MiB
Speed (MHz): avg: 3738 high: 4315 min/max: 800/4900:3600 scaling: driver: intel_pstate
governor: performance cores: 1: 3700 2: 3700 3: 4315 4: 3700 5: 3700 6: 3700 7: 3700 B: 3700
9. 3700 10: 3700 11: 3700 12: 3708 13: 3700 14: 3700 15: 3700 16: 3700 bogomips: 117964
Flags: avx avx2 ht Im nx pae sse sse2 sse3 ssed_1 sse4_2 ssse3 vmX
Im nx pae sse
<filter>
Device 1: NVIDIA AD102 (GeForce RTX 40901 vendor: Micro-Star MS driver: N/A alternate: nouveau
non-free: 525.xx+ status: current (as of 2023-02) arch: Lovelace code: AD1xx
process: TSMC n4 (5m) built: 2022-23+ pcie: gen:
4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de: 2684 class-ID: 0300
Device-2: Razer USA Gaming Webcam (kiyo) type: USB driver: snd-usb-audio,uvovideo
bus-ID: 3-7.2:5 chip-ID: 1532: 003 class-ID: 0102
1532;
Display: server: X.org v: 1.21.1.7 with: wayland v: 22.1.8 driver: N/A ttu: 102x38
API: OpenGL Message: GL data unavailable in console.
Try -G --display
Device-1: Intel Alder Lake-S HD Audio vendor: ASRock driver: snd_ha_intel bus-ID: 3-7.2:5
v: kernel alternate: snd_sof_pci_ intel_tol chip-ID: 1532:003 bus-ID: 00:1f.3 class-ID: 0102 chip-ID: 8086:7ad0 class- ID:
Device-2: NVIDIA AD102 High Definition Audio vendor: Micro-Star MI driver: snd_hda_intel
v: kernel pcie: gen:
4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID:
10de: 22ba
warning: database file for
warning database file for, coary
'garuda' does not exist usesu
"Su' to download"
warnina:
database file for
extra, does not exist, (use
to download)
does not exist (use
to
warning:
database file for community
'multilib
-S4.-sy
warning:
database file for
does not exist (use
abes not exist usee.-sy
download)
to download)
warning:
database file for
'chaotic-aur does not exist (use to download)
-Sy to download)
Device-3: Razer USA Gaming Webcam (Kiyol type: USB driver: snd-usb-audio,uvevideo
Device-4: SR600202 type: USB driver: hid-generic,snd-usb-audio,usbhid bus-1D: 3-7.4.2:11
chip-ID: 3212:1a01 class-ID: 0300 serial: <filter>
Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
Sound Server-1: PulseAudio v: 16.1 running: no Sound Server-2: PipeWire v: 0.3.67 running: no
Device-1: Intel Ethernet 1219-V vendor: ASRock driver: e1000e v: kernel port: N/A bus-ID: 00:1.6 chip-ID: 8086:1a1d class- ID: 0200
IF: enpOs31f6 state: down mac: <filter>
Device-2: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169 v: kernel pie: gen: 2
speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0 chip-ID: 10ec: 3000 class- ID: 0200
3000 bus-ID:
IF: enp6s@ state: up speed: 1000 Mbps duplex:
full mac:
<filter>
Device-3: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz vendor: Rivet Networks driver: iwiwifi
v: kernel poie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2725 class- ID: 0280
IF: wIp?sO state:
down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: busb v: 0.8 bus ID: 3-14:9 chip-ID: 8087:0032
class-1D: e001
Report: bt-adapter 1D: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 3.67 TiB used: 0 KiB (0.0%)
1D-1: /dev/nvmeOn1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 27B size: 1.82 TiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes:
4 type: SSD serial: <filter>
rev: 5B2QGXA? temp: 33.9 C scheme: GPT
1D-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO 1B size: 931.51 GiB
block-size: phusical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE? temp: 35.9 C scheme: GPT
1D-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 6b/s type: SSD serial:
<filter> rev: 2B60
1D-4: /dev/sdb maj-min: 8:16 tupe: USB vendor: Kingston model: DataTraveler 3.0 size: 28.82 GiB block-size: physical: 512 B logical: 512 B type: N/A serial:
<filter>
scheme: MBR
SMART Message: Unknown USB bridge, Flash drive/Unsupported enclosure?
ID-1: swap-1 tupe: ram size: 31.11 GiB used: 0 KiB (0.0% priority: 100 dev: /dev/zramB
Sustem Temperatures: cpu: 27.0 C mobo: N/A
Fan Speeds (RPM): N/A info:
Processes: 287 Uptime: 1m wakeups: 0 Memory: 31.11 GiB used: 1.1 GiB (3.5% Init: susted v: 253 default: graphical tool: sustect Compilers: gcc: 12.2.1 Packages:
pm: pacman pkas: 1818
ribs: 514 tools: octopi,paru Shell: Bash v: 5.1.16 running-in: tty 3 inxi: 3.3.25
Garuda (2.6.15-1):
Sustem install date:
2023-03-24
Last fuil susten undate: 2023-03-24
is partially upgraded:
No
Relevant software:
snapper NetworkManager dracut
Windows dral boot:
<superuser required>
SGS
24 March 2023 06:46
4
Please, no pictures from terminal.
Never.
Use garuda-assistant, Systeminfos.
Or copy and paste from terminal as text in forum.
SGS
24 March 2023 07:40
5
Seems a very new GPU,
GeForce RTX 4090 Graphics Cards for Gaming
](NVIDIA GeForce RTX 4090 Graphics Cards )
try to use free driver until the kernel and nvidia drivers include the GPU.
As I mentioned previously, I have already tried to install with the free drivers and the installation hangs at the same place. Is there something else I need to try in order to get the installation to proceed?
Same thing here, I had to do three things:
Create the USB boot drive with Rufus not ventoy
Choose the Free Drive
hang at Live Media Key Ring, let it sit...........................................................................................................................
Wait for at least 4 to 5 minutes and it went on
Once installed I proceeded then to choose the Nvidia drivers etc... Rebbot and no hang at boot off SSD. I will say though it boots quite slower than MX Linux partition.
Now if I can just stop the annoying, startling pop before it plays sound or video I am good. (so he thinks)
Thanks for the reply! I tried the same steps you described but for me it still hangs at the same place. I have left it for 20+ minutes just in case some operation is taking a super long time, but it does not appear that it is going to move past that point in the install.
I faced that issue as well. I use Ryzen 5600G Processors with intergrated Radeon graphics and it does have lots of issue with the graphics driver. The screen goes black screen when I use the the "free driver" boot but it does response with my keyboard and still full black screen. I reboot and edit the grub script on the "free driver" boot option by pressing "e" and deleting "{drivers}.modeset=1" parameter and replace with "nomodeset". But the boot stuck on "[OK] Finished LiveMedia Keyring setup" .
I would love to add my research and discoveries to this issue, but I feel like we are all in the same boat.
My rig consists of a 7950X, a 4090, and a 3090.
I have successfully used either card a few displays on proprietary drivers, but have had 0 luck using xrandr to use the 2 cards and more displays.
My last resort is trying my best to use open drivers, and here I am.
system
Closed
18 April 2023 04:03
11
