Hi to everybody,
I am using Garuda Linux dr460nized since few days (my first linux experience) and I like it a lot, but I encountered an issue.
If I try to shutdown the system, it freezes and does not completely shutdown even after many (12) hours. The monitor, the keyboard and the mouse are still connected, fans continuate to rotate, monitor displays black screen with no messages.
Here is the otput of journalctl -rb -1 of a session, experiencing the incomplete shutdown:
Since I noticed a possible issue with NetworkManager.service, I tried to turn off bluetooth before shutdown the system. This time, the shutdown is completed in few seconds with no issues.
Here is the otput of journalctl -rb -1 of a session, not experiencing issues:
However, when I boot again the system I cannot turn on bluetooth, settings menu shows no options available (I am a new user, so I cannot post a screenshot).
Here is the output of systemctl status bluetooth:
â—‹ bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: inactive (dead)
Condition: start condition failed at Fri 2021-06-18 19:06:49 CEST; 53min ago
└─ ConditionPathIsDirectory=/sys/class/bluetooth was not met
Docs: man:bluetoothd(8)
giu 18 19:06:49 andrea-vaio systemd[1]: Condition check resulted in Bluetooth service being skipped.
In order to enable bluetooth I have to run the command rfkill unblock bluetooth.
How can I solve the issue with the incomplete shutdown? Is it due to bluetooth as I suspect?
Maybe important info: as soon as Garuda Linux installed, it did not connect to my soundbar with bluetooth. In order to connect it successfully, I had to downgrade Bluez to 5.50-7.
Here my system data:
System: Kernel: 5.12.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=067d6a1b-1bdf-49e0-b577-9243ee1d4f17 rw
systemd.unified_cgroup_hierarchy=1 resume=UUID=da348988-5302-4a90-9a55-269f9ffaed69 loglevel=3 nouveau.modeset=0
Desktop: KDE Plasma 5.22.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Sony product: SVS1511C5E v: C60AUFMB serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Sony model: VAIO serial: <filter> UEFI: Insyde v: R0142C5 date: 05/17/2012
Battery: ID-1: BAT1 charge: 11.8 Wh (100.0%) condition: 11.8/52.2 Wh (22.7%) volts: 12.4 min: 11.1 model: Sony Corporation
type: Li-ion serial: N/A status: Full
CPU: Info: Dual Core model: Intel Core i7-3520M bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 cache: L2: 4 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 23146
Speed: 2348 MHz min/max: 1200/3600 MHz Core speeds (MHz): 1: 2348 2: 1221 3: 1875 4: 3392
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Sony driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 640M LE] vendor: Sony driver: N/A alternate: nouveau bus-ID: 01:00.0
chip-ID: 10de:0fd3 class-ID: 0300
Device-3: Foxconn / Hon Hai USB2.0 Camera type: USB driver: uvcvideo bus-ID: 1-1.3:3 chip-ID: 0489:d601
class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Monitor-1: LVDS1 res: 1920x1080 hz: 60 dpi: 139 size: 350x190mm (13.8x7.5") diag: 398mm (15.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.1.2 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Sony driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.12.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Network: Device-1: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel port: 6000 bus-ID: 02:00.0 chip-ID: 8086:088e
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Sony driver: r8169 v: kernel port: 3000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB driver: btusb v: 0.8 bus-ID: 1-1.2:4
chip-ID: 8087:07da class-ID: e001
Drives: Local Storage: total: 223.57 GiB used: 15.62 GiB (7.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s rotation: SSD serial: <filter> rev: B1D2 scheme: GPT
Partition: ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 14.02 GiB (28.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 560 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 153.07 GiB size: 153.07 GiB (100.00%) used: 1.6 GiB (1.0%) fs: btrfs dev: /dev/sda3
maj-min: 8:3
ID-4: /var/log raw-size: 50 GiB size: 50 GiB (100.00%) used: 14.02 GiB (28.0%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%) used: 14.02 GiB (28.0%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda4 maj-min: 8:4
ID-2: swap-2 type: zram size: 1.92 GiB used: 138 MiB (7.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.92 GiB used: 135.9 MiB (6.9%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.92 GiB used: 137.3 MiB (7.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.92 GiB used: 135.3 MiB (6.9%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 59.0 C mobo: N/A
Info: Processes: 268 Uptime: 57m wakeups: 1 Memory: 7.67 GiB used: 3.18 GiB (41.5%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1242 lib: 294 Shell: fish v: 3.2.2 running-in: konsole
inxi: 3.3.04
