Kernel: 6.14.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-zen
root=UUID=60b58089-17d0-400c-a93c-251340096be7 rw quiet loglevel=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: Alienware product: Alienware m16 R1 AMD v: 1.16.0
serial: <superuser required> Chassis: type: 10 v: 1.16.0
Mobo: Alienware model: 09FRTK v: A00 serial: <superuser required>
part-nu: 0BFD uuid: <superuser required> UEFI: Alienware v: 1.16.0
date: 02/06/2025
ID-1: BAT0 charge: 61.9 Wh (100.0%) condition: 61.9/84.3 Wh (73.4%)
volts: 12.0 min: 11.4 model: BYD DELL M59JH39 type: Li-poly serial: <filter>
status: full cycles: 72
Info: model: AMD Ryzen 7 7745HX with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1490 min/max: 400/5153 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1490 2: 1490 3: 1490
4: 1490 5: 1490 6: 1490 7: 1490 8: 1490 9: 1490 10: 1490 11: 1490 12: 1490
13: 1490 14: 1490 15: 1490 16: 1490 bogomips: 114989
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: Dell
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 8 ports: active: none empty: DP-1, DP-2, HDMI-A-1,
eDP-1 bus-ID: 01:00.0 chip-ID: 10de:28e0 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Dell
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-2
empty: DP-3, DP-4, DP-5, HDMI-A-2, Writeback-1 bus-ID: 0a:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 60.0 C
Device-3: Realtek Integrated_Webcam_FHD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1:2 chip-ID: 0bda:555a
gpu: amdgpu display-ID: 0
Monitor-1: eDP-2 model: BOE Display 0x0b04 built: 2022 res:
mode: 2560x1600 hz: 240 scale: 125% (1.25) to: 2048x1280 dpi: 188 gamma: 1.2
size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10 modes:
max: 2560x1600 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
platforms: device: 0 drv: nvidia device: 1 drv: radeonsi device: 2
drv: nouveau device: 3 drv: swrast gbm: drv: kms_swrast surfaceless:
drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 610M (radeonsi
raphael_mendocino LLVM 19.1.7 DRM 3.61 6.14.2-zen1-1-zen)
device-ID: 1002:164e memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon 610M (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: N/A device-ID: 10de:28e0
Device-1: NVIDIA AD107 High Definition Audio vendor: Dell
vendor: Dell driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
bus-ID: 0a:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0a:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.2-zen1-1-zen status: kernel-api with: aoss
Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Foxconn
driver: ath11k_pci v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 17cb:1103 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Dell driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 2000 bus-ID: 09:00.0
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.2:4 chip-ID: 0489:e0e3
Local Storage: total: 1.84 TiB used: 1.36 TiB (74.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 1024GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 36310229 temp: 37.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 44.9 C scheme: GPT
ID-1: / raw-size: 293.66 GiB size: 288.49 GiB (98.24%)
used: 38.14 GiB (13.2%) fs: ext4 dev: /dev/nvme1n1p9 maj-min: 259:13
used: 332 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p7 maj-min: 259:11
ID-1: swap-1 type: zram size: 30.53 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p8 maj-min: 259:12
System Temperatures: cpu: 73.9 C mobo: 41.8 C
Memory: total: 32 GiB note: est. available: 30.53 GiB used: 3.42 GiB (11.2%)
Processes: 401 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 12.15 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 1809 libs: 535 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date: 2025-04-17
Last full system update: 2025-04-18
