I guess i have two errors.
Failed to set locale
Dependancy for ICU breaks things when updating
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_CA.UTF-8",
LC_NAME = "en_CA.UTF-8",
LC_MONETARY = "en_CA.UTF-8",
LC_PAPER = "en_CA.UTF-8",
LC_IDENTIFICATION = "en_CA.UTF-8",
LC_TELEPHONE = "en_CA.UTF-8",
LC_MEASUREMENT = "en_CA.UTF-8",
LC_TIME = "en_CA.UTF-8",
LC_NUMERIC = "en_CA.UTF-8",
LANG = "en_CA.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.17.2-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=00b33177-335b-466d-8a5b-e5bad5669f19 rw rootflags=subvol=@
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 24.7 Wh (60.1%) condition: 41.1/51.6 Wh (79.7%)
volts: 11.1 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: N/A
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4081 high: 4302 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 1781 2: 4297 3: 4228
4: 4300 5: 4300 6: 4298 7: 4301 8: 4300 9: 4302 10: 4300 11: 4302
12: 4265 bogomips: 62399
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:5
chip-ID: 04f2:b695 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: i915
Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0xd0ed built: 2019
res: 1920x1080 hz: 120 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
v: 4.6 Mesa 22.0.1 direct render: Yes
Sound Server-1: ALSA v: k5.17.2-zen3-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
driver: btusb v: 0.8 bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 1.38 TiB used: 560.49 GiB (39.8%)
model: PC SN520 SDAPNUW-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20140000 temp: 44.9 C scheme: GPT
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
used: 65.47 GiB (44.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 557 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-4: /var/log raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 1.35 GiB (8.7%)
System Temperatures: cpu: 56.0 C pch: 56.0 C mobo: N/A
Processes: 363 Uptime: 2d 5h 22m wakeups: 5 Memory: 15.47 GiB
used: 3.3 GiB (21.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1837 lib: 551 Shell: fish
v: 3.4.1 running-in: konsole inxi: 3.3.15
Garuda (2.6.1-1):
System install date: 2022-01-25
Last full system update: 2022-04-14
Failed units: pacman-files.service
garuda-update
[sudo] password for jeremy:
core is up to date
extra 1724.3 KiB 303 KiB/s 00:06 [####################################] 100%
community is up to date
multilib is up to date
chaotic-aur 1705.6 KiB 285 KiB/s 00:06 [####################################] 100%
--> Refreshing mirrorlists using reflector, please be patient..
[2022-04-16 16:33:31] WARNING: failed to rate http(s) download (https://archlinux.thaller.ws/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2022-04-16 16:33:47] WARNING: failed to rate http(s) download (https://archlinux.mailtunnel.eu/community/os/x86_64/community.db): Download timed out after 5 second(s).
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2022-04-16 22:33:47 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2022-04-16 22:33:20 UTC
# Last Check: 2022-04-16 22:21:15 UTC
Server = https://geo.mirror.pkgbuild.com/$repo/os/$arch
Server = https://mirror.luzea.de/archlinux/$repo/os/$arch
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
core 157.3 KiB 31.4 KiB/s 00:05 [####################################] 100%
extra 1724.3 KiB 311 KiB/s 00:06 [####################################] 100%
community 6.6 MiB 538 KiB/s 00:13 [####################################] 100%
multilib 175.4 KiB 336 KiB/s 00:01 [####################################] 100%
chaotic-aur 1705.6 KiB 307 KiB/s 00:06 [####################################] 100%
spawn pacman -Su
resolving dependencies...
:: installing icu (71.1-1) breaks dependency 'libicui18n.so=70-64' required by thunderbird-appmenu
:: installing icu (71.1-1) breaks dependency 'libicuuc.so=70-64' required by thunderbird-appmenu
dalto
16 April 2022 22:41
2
Looks like thunderbird-appmenu needs to be rebuilt.
Haha, I just had a related issue crop up - a new build of Electron17 went live before the icu update did and had the two(2) electron apps I use crashing when it tried to call icu71. Digging turned up a good history of posts on other forums that indicates this tends to happen when icu gets a version bump.
Based on those, @dalto is almost certainly correct. Rebuilding should point it to the new version properly.
Yep dalto, just tried and got the same error:
:: Paketdatenbanken werden synchronisiert …
core 157,3 KiB 605 KiB/s 00:00 [-----------------------------------------] 100%
extra 1724,0 KiB 1300 KiB/s 00:01 [-----------------------------------------] 100%
community 6,6 MiB 4,29 MiB/s 00:02 [-----------------------------------------] 100%
multilib 175,4 KiB 664 KiB/s 00:00 [-----------------------------------------] 100%
chaotic-aur 1705,5 KiB 738 KiB/s 00:02 [-----------------------------------------] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..
core 157,3 KiB 828 KiB/s 00:00 [-----------------------------------------] 100%
extra 1724,4 KiB 1831 KiB/s 00:01 [-----------------------------------------] 100%
community 6,6 MiB 6,83 MiB/s 00:01 [-----------------------------------------] 100%
multilib 175,4 KiB 918 KiB/s 00:00 [-----------------------------------------] 100%
chaotic-aur 1705,5 KiB 555 KiB/s 00:03 [-----------------------------------------] 100%
spawn pacman -Su
Garuda-inxi:
@Clockwork in ~ as 🧙 took 34s
[🔴] × garuda-inxi
Kernel: 5.17.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=de43fccd-7f1e-439e-9eca-59d05e719941 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.F0
date: 12/16/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3814 high: 4601 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3670 2: 4601
3: 3638 4: 3922 5: 3674 6: 3805 7: 3691 8: 4201 9: 3616 10: 4168 11: 3722
12: 3608 13: 3611 14: 3885 15: 3616 16: 3606 bogomips: 121611
STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASUSTeK
driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 2f:00.0 chip-ID: 1002:73bf
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left model: Asus VS248
serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,right model: Asus VS248
OpenGL: renderer: AMD Radeon RX 6800 XT (sienna_cichlid LLVM 13.0.1 DRM
3.44 5.17.3-zen1-1-zen)
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab28
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.3-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 516.13 GiB (55.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P4CR311
temp: 38.9 C scheme: GPT
used: 516.13 GiB (55.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.78 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 52.6 C mobo: N/A gpu: amdgpu temp: 36.0 C
mem: 34.0 C
Processes: 370 Uptime: 14h 16m wakeups: 0 Memory: 62.78 GiB
used: 7.16 GiB (11.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 2095 lib: 583 Shell: fish
Garuda (2.6.1-1):
System install date: 2022-04-05
Last full system update: 2022-04-16
If I understand correctly, you might have to remove thunderbird-appmenu, upgrade icu, then build thunderbird-appmenu from the AUR instead of the current chaotic build? Not 100% certain though.
dalto
16 April 2022 23:16
6
What does paru -Si thunderbird-appmenu return?
I didn't do anything with thunderbird yet. Hence a system upgrade should work flawlessly.
I guess dalto recognized the issue pretty fast and there might be a bug. I'm curious about his findings
type or paste code h╭─martin@Clockwork in ~ took 3s
[🧱] × paru -Si thunderbird-appmenu
Repositorium : chaotic-aur
Version : 91.6.0-2
Beschreibung : Thunderbird from extra with appmenu patch
Architektur : x86_64
URL : https://www.mozilla.org/thunderbird/
Lizenzen : MPL GPL LGPL
Gruppen : Nichts
Stellt bereit : thunderbird=91.6.0
Hängt ab von : glibc gtk3 libgdk-3.so=0-64 libgtk-3.so=0-64 mime-types dbus libdbus-1.so=3-64
dbus-glib alsa-lib nss hunspell sqlite ttf-font libvpx zlib bzip2 libbz2.so=1.0-64
botan libwebp libwebp.so=7-64 libwebpdemux.so=2-64 libevent libjpeg-turbo libffi
libffi.so=8-64 nspr gcc-libs libx11 libxrender libxfixes libxext libxcomposite
libxdamage pango libpango-1.0.so=0-64 cairo gdk-pixbuf2 icu libicui18n.so=70-64
libicuuc.so=70-64 freetype2 libfreetype.so=6-64 fontconfig libfontconfig.so=1-64 glib2
libglib-2.0.so=0-64 pixman libpixman-1.so=0-64 gnupg
Optionale Abhängigkeiten : libcanberra: sound support
In Konflikt mit : thunderbird
Ersetzt : Nichts
Größe des Downloads : 63,14 MiB
Installationsgröße : 196,21 MiB
Packer : Nico Jensch <dr460nf1r3@chaotic.cx>
Erstellt am : Mi 23 Feb 2022 17:21:55
Verifiziert durch : MD5-Summe SHA-256-Summe Signatur
ere
dalto
16 April 2022 23:18
9
It looks like it is the chaotic-aur version that needs to be rebuilt.
You can either just wait for that to happen or you can uninstall it, update and then build the AUR version.
Waiting is a lot simpler.
It seems that way.
What should we do next? Or should we just wait until you've fixed it?
EDIT - timing overlap of posts xD
okay dalto
thx
Yeah, same for me. I am getting a flashback, same error happening from the past.
Calling Dr. Bombay! Emergency! Come right away! @dr460nf1r3
I still get the ICU error.
Plus a time out error :
core 157,3 KiB 869 KiB/s 00:00 [------------------------------------] 100%
extra 1724,4 KiB 3,86 MiB/s 00:00 [------------------------------------] 100%
community 6,6 MiB 6,79 MiB/s 00:01 [------------------------------------] 100%
multilib 175,4 KiB 864 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur 1704,7 KiB 459 KiB/s 00:04 [------------------------------------] 100%
Error: failed to connect to , consider increasing fetch-mirrors-timeout
Failed to update mirrorlist
spawn pacman -Su
This turned out to be a tricky one, rebuilds did not solve this as the package still demands libicu 70
fcinq
17 April 2022 10:53
16
Hi all,
I am having the same trouble i think :
╭─user@laptop in ~
╰─λ thunderbird
XPCOMGlueLoad error for file /usr/lib/thunderbird/libxul.so:
libicui18n.so.70: cannot open shared object file: No such file or directory
Couldn't load XPCOM.
╭─user@laptop in ~ took 60ms
[⚡] × firedragon
XPCOMGlueLoad error for file /usr/lib/firedragon/libxul.so:
Couldn't load XPCOM
I have upgrade my systems this morning with the command garuda-update -a
I have just to wait a rebuild, or i can do something alone ?
Best regards.
Alright, this was caused by our builders using an outdated mirror as package source ( shame on you, Cloudflare! ). Now the real builds can start.
This is the way. Builders are working
edit: thunderbird-appmenu is updated
fcinq
17 April 2022 17:25
18
Perfect for thunderbird-appmenu is working again. But i can't run firedragon anymore :
[⚡] × firedragon
Couldn't load XPCOM
Whats is the best to do ?
My garuda-inxi:
root=UUID=c0f75d9e-6e1f-4e3b-8385-5e4fd8e89f17 rw rootflags=subvol=@
resume=UUID=ed6f1df7-3f2e-4ca9-b56c-7442968255fa loglevel=3
Type: Laptop System: Dell product: Latitude 5400 v: N/A
Mobo: Dell model: 0PD9KD v: A00 serial: <superuser required> UEFI: Dell
v: 1.5.1 date: 08/21/2019
ID-1: BAT0 charge: 61.6 Wh (98.7%) condition: 62.4/68.0 Wh (91.8%)
volts: 8.6 min: 7.6 model: LGC-LGC8.948 DELL X77XY99 type: Li-ion
Info: model: Intel Core i5-8365U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 819 high: 889 min/max: 400/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 802 2: 803 3: 889 4: 802
5: 842 6: 808 7: 801 8: 805 bogomips: 30399
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0bda:565c class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x463d built: 2018
res: 1920x1080 hz: 60 dpi: 157 gamma: 1.2 size: 310x170mm (12.2x6.69")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
chip-ID: 8086:9dc8 class-ID: 0403
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bd class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 476.94 GiB used: 243.39 GiB (51.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNS512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 10410104 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 459.69 GiB size: 459.69 GiB (100.00%)
used: 243.39 GiB (52.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 459.69 GiB size: 459.69 GiB (100.00%)
ID-4: /var/log raw-size: 459.69 GiB size: 459.69 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.69 GiB size: 459.69 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.99 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 25.0 C pch: 37.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 248 Uptime: 2m wakeups: 109 Memory: 15.44 GiB
used: 1.68 GiB (10.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1314 lib: 330 Shell: fish
e[1;34mGaruda (2.6.1-3):e[0m
e[1;34m System install date:e[0m 2021-12-01
e[1;34m Last full system update:e[0m 2022-04-17
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Timeshift (maybe)
e[1;34m Failed units: e[0m
Best regards.
It also got rebuild, you might have catched the one with pkgrel=2 which got built with the outdated mirror earlier today. I suggest simply reinstalling it to fix that: sudo pacman -Syu firedragon. Ignore the warning about the package being broken and press yes to the removal prompt, then run the command again.
fcinq
17 April 2022 17:38
20
firedragon is back ! Thx a lot @dr460nf1r3
Thanks guys!
Woah, 2 days without update and I've got a 727MB download size on my garuda-update
100Mbits internet FTW
Bruce
