I have nearly installed garuda on my new laptop but for some reason, I can only choose manual partitioning. All my space is clear.
Can someone help me by recommending me what and how much of partitions. I have no idea what partitions I need and how much GB each. I'm sorry, I am very new to Linux.
My specs, I have 119.24GB SSD free space.
I have 8GB RAM
Laptop.
i5 10th gen
Oh I got an error while installing
"Installation Failed
The installer failed to create partition disk (my internal SSD)
Details:
Create a new partition (118.95 GiB, btrfs) on '/dev/nvme0n1'
Job: Create new partition on device '/Dev/nvme0n1'"
Actually you do in part. When you downloaded the ISO some of the answers to those questions were right up the top of the page
Now for more details, it is a minimum of 30Gb of BTRFS partition and 300megs for the EFI/ESP partition, if you choose UEFI/GPT. Otherwise for BIOS/MBR the entire disk can be used in btrfs.
Are you saying that you are stuck on partition part of the garuda installer?
If yes than try to reboot on usb stick again.
And then try again
This is a common problem i also usually face but rebooting without removing USB 99% of the time helped me
Omg, you're a legend!!! I see the other options!!! Thanks
Which one do I pick, I want on garuda on this laptop, I'm not dual booting.
I tried erasing disk yesterday and my laptop ran out of battery, so I see 300mb of nvme and 118.95GB of Garuda Linux. Should I erase disk or something else?
Did you removed the older partition which was made by garuda installer previously?
If not then completely format the disk and try again
Sometimes it may be neither your fault or pc fault so just try again
First tell me is there any partition showing in it named something like UEFI or something?
if yes then select that and click on minus sign below in it
if not then just try again to install ....
(if this is also not working then I am sorry
may be garuda devs can help you )
When I mean by removed is that it says it under pending operations, so I hope that's correct
It's deleted, I'm gonna try installer again with erase disk option
Nope same error
Do you know how to do manual partitioning?
Oh, I pressed apply, I looked on YouTube but it didn't help. I might need to do manual partitioning but I don't know how much and what partitions I need.
Damn, no worries, you helped me anyone, do you know how I can contact the Devs?
