When I first installed Garuda KDE dr4gonized gaming edition, I followed a guide to do manual partitioning and using a btrfs raid 0 for / mount point, this worked well, was beautifully fast, and was stable for a long time until I got hit with a stupid issue due to a qt bug (see this post Garuda kde dr4gonised graphical glitches leading to crashed programs in some cases). After this was resolved I had more time enjoying this wonderful setup. more recently, my system suddenly became unbootable claiming a btrfs problem straight out of grub, I couldn’t boot from any snapshots or even mount the volume in a live environment.
Researching this error lead me up a few garden paths that ultimately proved fruitless. I discovered that it could be a result of bad firmware on some of my drives, so I went through the hell of putting windows on this pc for the first time to use samsung disk magician to update the firmware and check the drives for problems advised in multiple youtube videos and various websites/forum posts regarding the samsung 980 pro 2tb nvme drives (amongst other models with a similar problem). I then did a clean install of garuda in the same manner I had done before. This time the btrfs raid 0 self-destructed after 1 or 2 updates and a reboot. At this point I snapped, went with a single drive for /efi/boot and /, the aim being to create a btrfs raid 0 with the remaining 4 ssds to house my games library. This self-destructed after an update again. Using a virtual machine and passing through the NVME drives to run samsung disk magician software, I found the drives had no problems, and the firmware was correct on all 4 of the drives I had used for the btrfs raid 0. And that brings us to today, please, please tell me what I need to do differently to have that lovely large raid array to run with either a 4 disk or 5 disk raid 0 array that won’t self destruct randomly after an update.
Please note, after each failure of the raid 0 array, the array became unmountable.
here is my current garuda-inxi:
Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=bd10dd0b-5dbe-41bd-9e59-7eef259d26c8 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Mobo: ASUSTeK model: ROG CROSSHAIR VIII EXTREME v: Rev X.0x
serial: <filter> part-nu: SKU uuid: a3a29ff7-4204-061a-4258-04421a064257
UEFI: American Megatrends v: 1505 date: 03/18/2024
Info: model: AMD Ryzen 9 5950X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3400 min/max: 2200/5083 boost: enabled
base/boost: 3400/5050 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3400 2: 3400 3: 3400 4: 3400
5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400
13: 3400 14: 3400 15: 3400 16: 3400 17: 3400 18: 3400 19: 3400 20: 3400
21: 3400 22: 3400 23: 3400 24: 3400 25: 3400 26: 3400 27: 3400 28: 3400
29: 3400 30: 3400 31: 3400 32: 3400 bogomips: 217615
Device-1: NVIDIA GA102 [GeForce RTX 3090] driver: nvidia v: 555.58.02
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none off: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 44:00.0 chip-ID: 10de:2204
Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
display-ID: :1 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1355x381mm (53.35x15.00")
s-diag: 1408mm (55.42")
Monitor-1: DP-3 note: disabled model: Samsung C49RG9x serial: <filter>
built: 2018 res: 5120x1440 hz: 120 dpi: 109 gamma: 1.2
size: 1193x336mm (46.97x13.23") diag: 1239mm (48.8") modes: max: 3840x1080
min: 640x480
API: EGL v: 1.5 platforms: device: 1 drv: swrast surfaceless: drv: swrast
x11: drv: swrast inactive: gbm,wayland,device-0
API: OpenGL v: 4.5 vendor: mesa v: 24.1.6-arch1.1 note: incomplete (EGL
sourced) renderer: llvmpipe (LLVM 18.1.8 256 bits)
Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 44:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 48:00.4 chip-ID: 1022:1487
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-5:3
chip-ID: 0b05:1a27 class-ID: 0300
API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: n/a (root, process) with:
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 3f:00.0
IF: wlp63s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 40:00.0
IF: enp64s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2:2 chip-ID: 8087:0032
Local Storage: total: 60.03 TiB used: 99.83 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 49.9 C
SMART: yes health: PASSED on: 71 hrs cycles: 274
read-units: 11,915,587 [6.10 TB] written-units: 5,998,577 [3.07 TB]
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 45.9 C
SMART: yes health: PASSED on: 46 hrs cycles: 207
read-units: 11,321,942 [5.79 TB] written-units: 4,660,218 [2.38 TB]
ID-3: /dev/nvme2n1 maj-min: 259:6 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 47.9 C
SMART: yes health: PASSED on: 70 hrs cycles: 262
read-units: 11,612,966 [5.94 TB] written-units: 6,375,348 [3.26 TB]
ID-4: /dev/nvme3n1 maj-min: 259:5 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 43.9 C
SMART: yes health: PASSED on: 73 hrs cycles: 262
read-units: 11,880,964 [6.08 TB] written-units: 6,408,090 [3.28 TB]
ID-5: /dev/nvme4n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 42.9 C
SMART: yes health: PASSED on: 73 hrs cycles: 261
read-units: 11,852,429 [6.06 TB] written-units: 6,452,130 [3.30 TB]
ID-6: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWR21E family: X300
size: 12.73 TiB block-size: physical: 4096 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: 0601
temp: 45 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 325d 19h cycles: 1162
ID-7: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWG21E
family: N300/MN NAS HDD size: 12.73 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: 0601 temp: 42 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 51d 22h cycles: 261
ID-8: /dev/sdc maj-min: 8:32 vendor: Toshiba model: HDWG21E
serial: <filter> fw-rev: 0601 temp: 41 C scheme: GPT
ID-9: /dev/sdd maj-min: 8:48 vendor: Toshiba model: HDWR21E family: X300
temp: 44 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 51d 20h cycles: 261
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 99.83 GiB (5.4%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
used: 99.83 GiB (5.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 125.68 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 51.0 C mobo: N/A
Memory: total: 128 GiB available: 125.68 GiB used: 7.6 GiB (6.0%)
Processes: 545 Power: uptime: 1h 36m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 50.23 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2049 libs: 585 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.32
System install date: 2024-08-18
Last full system update: 2024-08-27 ↻
Failed units: nmb.service
Thankyou for taking the time to read this and any subsequent assistance^^
