I was using Linux mint and attracted by Garuda Draganized version by its look. But after I switched to Garuda Draganized, I realized I made a big mistake. I am going to list out some of the problems.
- Slack application login is not working no matter what browser I use. I tried Brave, Chrome, Vivaldi. Slack application redirects to browser when I click on login and I continue to login on the browser tab and at the end, it redirects me to slack app, but slack app not working after that too. I don't think its browser related problem as I tried multiple browsers.
- I am using vivaldi browser for my daily browsing. When I open slack website on vivaldi, it continuesly crashes after few minutes. I never seen one website can bring down my entire browser application in any other OS. I tried disabling psd, installign vivaldi for all users, nothing worked.
I am not a quick judger. I tried to stick around with Garuda Linux for some days now. But it really wants to go away from me.
I am using multiple applications like pycharm community ide, zoom, youtube app, virtual box, authy, google authenticator, discord, whatsapp app, google chat app, etc.. I haven't tried any of these apps in garuda linux yet and I don't want to. Because I am really not sure how much bugs are you hiding in those apps in Garuda linux. I have no other choices other than switching to another OS now. I am a big fan of Linux for my productivity based works and Garuda Linux disappointed me a lot.
I don't want to troubleshoot anything now. Because I just wanted these apps to work out of the box in linux distro and it worked in that way in all other linux distros except Garuda linux. I just want you to know these problems are really existing in your Garuda linux.
Kernel: 5.19.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e2ff12dc-7315-403a-90ad-1155edbabe97 rw rootflags=subvol=@
resume=UUID=eef3fb26-927e-46e1-a9fa-7ed1145f1433 loglevel=3
Type: Desktop Mobo: Gigabyte model: B550M DS3H AC
serial: <superuser required> UEFI: American Megatrends LLC. v: F14e
date: 10/13/2021
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2515 high: 3640 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 3103 4: 2876 5: 3640 6: 2200 7: 2962 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 bogomips: 88633
Device-1: NVIDIA TU106 [GeForce GTX 1650] vendor: ASUSTeK driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-07) arch: Turing code: TUxxx process: TSMC 12nm
built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 09:00.0 chip-ID: 10de:1f0a class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: DP-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.54x13.23")
diag: 686mm (27.01") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
bus-ID: 09:00.1 chip-ID: 10de:10f9 class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.19.8-zen1-1-zen running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2526 class-ID: 0280
lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 bus-ID: 1-9:2 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 1.36 TiB used: 15.98 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
temp: 38.9 C scheme: GPT
model: WD10EZEX-00BBHA0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 69.7 GiB size: 69.7 GiB (100.00%) used: 15.78 GiB (22.6%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot raw-size: 1024 MiB size: 1024 MiB (100.00%) used: 201 MiB
(19.6%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /boot/efi raw-size: 310.9 MiB size: 310.3 MiB (99.80%) used: 608
KiB (0.2%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /home raw-size: 69.7 GiB size: 69.7 GiB (100.00%) used: 15.78 GiB
(22.6%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-5: /var/log raw-size: 69.7 GiB size: 69.7 GiB (100.00%) used: 15.78
GiB (22.6%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-6: /var/tmp raw-size: 69.7 GiB size: 69.7 GiB (100.00%) used: 15.78
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8
System Temperatures: cpu: 50.8 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 26%
Processes: 314 Uptime: 19m wakeups: 0 Memory: 15.53 GiB used: 2.44 GiB
(15.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1238 lib: 305 Shell: fish v: 3.5.1
Garuda (2.6.7-1):
System install date: 2022-09-14
Last full system update: 2022-09-14
