I Have installed Latte Dock But it not working
Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=744736bd-ab80-41dd-ade6-eb0f243d02ce rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
wm: kwin_x11 with: latte-dock vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: HP product: Victus by HP Gaming Laptop 15-fb1xxx v: N/A
Mobo: HP model: 8C30 v: 88.14 serial: <superuser required>
part-nu: 8L083PA#ACJ uuid: <superuser required> UEFI: AMI v: F.03
date: 08/10/2023
ID-1: BAT0 charge: 49.7 Wh (100.0%) condition: 49.7/49.7 Wh (100.0%)
volts: 13.1 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 108
Info: model: AMD Ryzen 5 7535HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 806 high: 1379 min/max: 400/4603 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 1374 3: 400
4: 1375 5: 1372 6: 400 7: 1374 8: 400 9: 1379 10: 400 11: 400 12: 400
bogomips: 79052
Device-1: NVIDIA GA107 [GeForce RTX 2050] vendor: Hewlett-Packard
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 4 speed: 16 GT/s
lanes: 8 link-max: lanes: 16 ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:25ad class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: Hewlett-Packard
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1
bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 47.0 C
Device-3: Chicony HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b766
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x094d built: 2020
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 660M (radeonsi rembrandt
LLVM 18.1.8 DRM 3.57 6.10.6-zen1-1-zen) device-ID: 1002:1681
memory: 500 MiB unified: no
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon 660M (RADV REMBRANDT) driver: mesa radv v: 24.1.6-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2050 driver: nvidia v: 560.35.03
device-ID: 10de:25ad surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.6-arch1.1 (LLVM
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 13d3:3567
Local Storage: total: 476.94 GiB used: 46.88 GiB (9.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCPNRY-512G-1006 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 43.9 C scheme: GPT
used: 46.88 GiB (9.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 6.96 GiB used: 1.25 GiB (17.9%)
System Temperatures: cpu: 48.9 C mobo: 42.0 C gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): fan-1: 2681 fan-2: 0
Memory: total: 8 GiB note: est. available: 6.97 GiB used: 4.49 GiB (64.5%)
Processes: 361 Power: uptime: 6h 59m states: freeze,mem,disk
suspend: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 2.74 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1890 libs: 546 tools: octopi,paru,yay
pm: flatpak pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2024-08-25
Last full system update: 2024-09-04
Is partially upgraded:   Yes
That’s why we sadly had to remove it.
It used to be a corner stone of the Dragonized Edition.
See pinned comment here:
https://aur.archlinux.org/packages/latte-dock
any other alternative for that ?
You alredy have a thread for that!
I mark it solved.
CU SGS
