I got issues on hyprland, ~10 sec. blackscreen
I got issue on hyprland black screen .. while opening through sddm it will get blackscreen and cursor it will stop at center and does not work for 2 or 3min it will go back to normal and open
here is my inxi
  Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    root=UUID=25dd2aeb-ae70-46e6-b236-a75ae0e66896 rw rootflags=subvol=@
  Type: Laptop System: LENOVO product: 82RN v: IdeaPad 3 15ABA7
    serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15ABA7
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76463WIN
    serial: <superuser required> UEFI: LENOVO v: JTCN42WW date: 01/10/2023
  ID-1: BAT0 charge: 19.9 Wh (57.3%) condition: 34.7/38.0 Wh (91.3%)
    power: 5.6 W volts: 7.7 min: 7.7 model: BYD L20B2PF0 type: Li-poly
    serial: <filter> status: discharging cycles: 260
  Info: model: AMD Ryzen 5 5625U with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0xA50000C
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1742 high: 2300 min/max: 1600/4387 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2300 2: 2300
    3: 1451 4: 1600 5: 1600 6: 1600 7: 1360 8: 1600 9: 1600 10: 1600 11: 1600
    12: 2300 bogomips: 55095
  Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7 class-ID: 0300
    temp: 42.0 C
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 174f:2465
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
    compositor: Hyprland driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 1
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x151e built: 2019 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 scale: 1 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
    snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
    gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
    speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
  Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b852
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4853
  Local Storage: total: 476.94 GiB used: 21.82 GiB (4.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512GZL
    lanes: 4 tech: SSD serial: <filter> fw-rev: C01C temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 114.35 GiB size: 114.35 GiB (100.00%)
    used: 21.74 GiB (19.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-2: /boot/efi raw-size: 511 MiB size: 510 MiB (99.80%)
    used: 76.2 MiB (14.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 114.35 GiB size: 114.35 GiB (100.00%)
  ID-4: /var/log raw-size: 114.35 GiB size: 114.35 GiB (100.00%)
  ID-5: /var/tmp raw-size: 114.35 GiB size: 114.35 GiB (100.00%)
  ID-1: swap-1 type: zram size: 13.5 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 43.0 C
  Processes: 304 Uptime: 6m wakeups: 2 Memory: total: 16 GiB note: est.
  available: 13.5 GiB used: 2.21 GiB (16.3%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1454 libs: 380 tools: pamac,paru Shell: Zsh
  v: 5.9 running-in: kitty inxi: 3.3.29
  System install date:     2023-08-13
  Last full system update: 2023-08-26
here is my hyprland conf
monitor=,preferred,auto,1
exec-once=sway-audio-idle-inhibit
exec-once=swayidle -w timeout 300 'hyprctl dispatch dpms off' resume 'hyprctl dispatch dpms on' timeout 305 '~/.config/hypr/scripts/swaylocker.sh' before-sleep '~/.config/hypr/scripts/swaylocker.sh'
exec-once=/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1 &
exec-once=libinput-gestures &
exec-once = wpaperd
exec-once = waybar
blurls = waybar
exec-once = mako
exec-once = foot --server
#pre executions (under development)
exec-once=exec xrdb -load ~/.Xresources
exec-once=copyq
input {
    kb_layout = us
    repeat_rate=50
    repeat_delay=270
    follow_mouse = 3
touchpad {
    natural_scroll = true
    tap-to-click = true
    disable_while_typing = true
    sensitivity = 0 # -1.0 - 1.0, 0 means no modification.
general {
    # See https://wiki.hyprland.org/Configuring/Variables/ for more
    gaps_in = 5
    gaps_out = 10
    border_size = 2
    col.active_border = rgba(33ccffee) rgba(8f00ffee) 45deg
    col.inactive_border = rgba(595959aa)
    resize_on_border=true
    no_cursor_warps = true
    layout = dwindle
decoration {
    rounding = 10
     blur {
        size=6.8 # minimum 1
          passes=2 # minimum 1, more passes = more resource intensive.
          new_optimizations = true
    drop_shadow = true
    shadow_range = 8
    shadow_render_power = 3
    col.shadow = rgba(1a1a1aee)
animations {
    enabled = 1
    # Some default animations, see https://wiki.hyprland.org/Configuring/Animations/ for more
    bezier = myBezier, 0.12, 1, 0.12, 1
    animation = windows, 1, 4, myBezier
    animation = windowsOut, 1, 4, default, popin 100%
    animation = border, 1, 10, default
    animation = fade, 1, 4, default
    animation = workspaces, 1, 4, default
dwindle {
    # See https://wiki.hyprland.org/Configuring/Dwindle-Layout/ for more
    pseudotile = true # master switch for pseudotiling. Enabling is bound to mainMod + P in the keybinds section below
    preserve_split = true # you probably want this
    force_split=2
    no_gaps_when_only = false
master {
    # See https://wiki.hyprland.org/Configuring/Master-Layout/ for more
    new_is_master = true
gestures {
    workspace_swipe = on
misc {
	disable_hyprland_logo = true
# Example per-device config
# See https://wiki.hyprland.org/Configuring/Keywords/#executing for more
device:epic mouse V1 {
    sensitivity = -0.5
## See https://wiki.hyprland.org/Configuring/Keywords/ for more
$mainMod = SUPER
# keybing binds
bind=SUPER,Q,killactive
bind=SUPER,B,exec,brave
bind=SUPER,m,fullscreen,1
bind=SUPER,F,fullscreen,0
bind=SUPER,RETURN,exec,kitty
bind=SUPER,t,exec,foot
bind=SUPERSHIFT,RETURN,exec,~/.config/hypr/scripts/fullscreenA.sh
bind=SUPER,R,exec,Ranger $HOME
bind=SUPER,P,pseudo,
bind=CTRL,space,exec,wofi --allow-images
bind=SUPER,space,cyclenext,
bind=SUPERSHIFT,v,exec,VirtualBox Manager,
bind=SUPER,comma,exec,dolphin
bind=SUPERSHIFT,w,exec,wpaperd
bind=SUPER CTRL ALT,p,exec,poweroff
bind=SUPER CTRL ALT,r,exec,reboot
bind=SUPER CTRL ALT,q,exit
bind=SUPERSHIFT,o,toggleopaque
# bind=SUPER,j,layoutmsg,cyclenext
# bind=SUPER,k,layoutmsg,cycleprev
bind=SUPER,j,movefocus,d
bind=SUPER,k,movefocus,u
bind=SUPER,h,movefocus,l
bind=SUPER,l,movefocus,r
bind=ALT,h,resizeactive,-40 0
bind=ALT,l,resizeactive,40 0
bind=ALT,k,resizeactive,0 -40
bind=ALT,j,resizeactive,0 40
bind=SUPERSHIFT,h,movewindow,l
bind=SUPERSHIFT,l,movewindow,r
bind=SUPERSHIFT,k,movewindow,u
bind=SUPERSHIFT,j,movewindow,d
bind=SUPER,1,workspace,1
bind=SUPER,2,workspace,2
bind=SUPER,3,workspace,3
bind=SUPER,4,workspace,4
bind=SUPER,5,workspace,5
bind=SUPER,6,workspace,6
bind=SUPER,7,workspace,7
bind=SUPER,8,workspace,8
bind=SUPER,9,workspace,9
bind=SUPER,0,workspace,10
bind=SUPERSHIFT,1,movetoworkspacesilent,1
bind=SUPERSHIFT,2,movetoworkspacesilent,2
bind=SUPERSHIFT,3,movetoworkspacesilent,3
bind=SUPERSHIFT,4,movetoworkspacesilent,4
bind=SUPERSHIFT,5,movetoworkspacesilent,5
bind=SUPERSHIFT,6,movetoworkspacesilent,6
bind=SUPERSHIFT,7,movetoworkspacesilent,7
bind=SUPERSHIFT,8,movetoworkspacesilent,8
bind=SUPERSHIFT,9,movetoworkspacesilent,9
bind=SUPERSHIFT,0,movetoworkspacesilent,10
# set volume (laptops only and may or may not work on PCs)
bind = ,122, exec, pactl set-sink-volume @DEFAULT_SINK@ -5%
bind = ,123, exec, pactl set-sink-volume @DEFAULT_SINK@ +5%
bind = ,121, exec, pactl set-sink-volume @DEFAULT_SINK@ 0%
bind = ,232,exec,brightnessctl -c backlight set 5%-
bind = ,233,exec,brightnessctl -c backlight set +5%
#\ \        / (_)         | |                   |  __ \     | |
#  \ \  /\  / / _ _ __   __| | _____      _____  | |__) |   _| | ___  ___
#   \ \/  \/ / | | '_ \ / _` |/ _ \ \ /\ / / __| |  _  / | | | |/ _ \/ __|
#    \  /\  /  | | | | | (_| | (_) \ V  V /\__ \ | | \ \ |_| | |  __/\__ \
#     \/  \/   |_|_| |_|\__,_|\___/ \_/\_/ |___/ |_|  \_\__,_|_|\___||___/
# Float Necessary Windows
windowrule=float,wofi
windowrule=float,vlc
windowrule=float,ulauncher
windowrule=float,pavucontrol
windowrule=noshadow,dunst
windowrule=noanim,dunst
windowrule=noborder,dunst
windowrulev2 = float,class:^()$,title:^(Picture in picture)$
windowrulev2 = float,class:^(brave)$,title:^(Save File)$
windowrulev2 = float,class:^(brave)$,title:^(Open File)$
windowrulev2 = float,class:^(LibreWolf)$,title:^(Picture-in-Picture)$
windowrulev2 = float,class:^(blueman-manager)$
windowrulev2 = float,class:^(org.twosheds.iwgtk)$
windowrulev2 = float,class:^(blueberry.py)$
windowrulev2 = float,class:^(xdg-desktop-portal-gtk)$
windowrulev2 = float,class:^(geeqie)$
windowrulev2 = float,class:^(VirtualBox)$,title:^(.*Preferences*.)$
windowrulev2 = size 1060 630,class:^(VirtualBox)$,title:^(.*Preferences*.)$
windowrulev2 = center,class:^(VirtualBox)$,title:^(.*Preferences*.)$
windowrulev2 = fullscreen, class:^(wlroots)
windowrulev2 = fullscreen,class:^(VirtualBox Machine)$,title:^(.*[Running]*.)$
windowrulev2 = float,class:^(thunar)$,title:^(File Operation Progress)$
windowrulev2 = float,class:^(galculator)$
windowrulev2 = size 548 782,class:^(galculator)$
windowrulev2 = center,class:^(galculator)$
windowrulev2 = float,class:^(wps)$
windowrulev2 = center,class:^(wps)$
windowrulev2 = float,class:^(imv)$
windowrulev2 = center,class:^(imv)$
windowrulev2 = float,class:^(feh)$
windowrulev2 = size 1200 720,class:^(feh)$
windowrulev2 = center,class:^(feh)$
windowrulev2 = float,class:^(Tk)$
windowrulev2 = float,class:^(VirtualBox)$,title:^(.*Settings*.)$
windowrulev2 = size 1060 630,class:^(VirtualBox)$,title:^(.*Settings*.)$
windowrulev2 = center,class:^(VirtualBox)$,title:^(.*Settings*.)$
# Increase the opacity
windowrule=opacity 0.92 0.92,thunar
windowrule=opacity 0.96,discord
windowrule=opacity 0.88,obsidian
windowrule=opacity 0.9,Alacritty
windowrule = opacity 0.75 override 0.75 override,^(kitty)$ # set opacity to 1.0 active and 0.5 inactive for kitty
windowrule = opacity 0.9 override 0.9 override,^(Alacritty)$ # set opacity to 1.0 active and 0.5 inactive for kitty
# ^.*nvim.*$
windowrule=tile,librewolf
windowrule=tile,spotify
windowrule=opacity 1,neovim
bindm=SUPER,mouse:272,movewindow
bindm=SUPER,mouse:273,resizewindow
bind=ALT,h,resizeactive,10
#video play paues bindings
bind=,172,exec,playerctl play-pause
bind=,171,exec,playerctl next
bind=,173,exec,playerctl previous
# Use gtk-settings
exec-once = apply-gsettings
it was working perfectly fine for month and today i got this problem
You change the standard values, does it work befor?
Further I have not checked yet, what you could have changed :wink:
input {
    kb_layout = us
    kb_variant =
    kb_model =
    kb_options =
    kb_rules =
Did you use also all changes I make since 2023-08-13?
==> To follow user config changes open up Garuda Assistant & hit apply configs.
Maybe, if you like, use/try last ISO from https://iso.builds.garudalinux.org/iso/community/hyprland/230823/
I think this version is quite stable considering that Hyprland is still under construction (V 0.28).
Test update today and reboot.
Packages (8) hyprland-git-0.28.0.r100.299d201e-1  lib32-glu-9.0.3-1  lib32-libdrm-2.4.116-1
             lib32-libxcb-1.16-1  libpamac-aur-11.6.1-0  libzip-1.10.1-1  vulkan-headers-1:1.3.262-1
             wlroots-git-0.17.0.r6571.717ded9b-1
Ok, I got the same, so it is upstream, hyprland-git-0.28.0 or wlroots-git?
Just wait a bit until the bug is fixed. :slight_smile:
jctl
jctl
Aug 26 14:43:25 hypr kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C0.TPD0], AE_NOT_FOUND (20230331/dswload2-162)
Aug 26 14:43:25 hypr kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230331/psobject-220)
Aug 26 14:43:25 hypr kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C1.TPL1], AE_NOT_FOUND (20230331/dswload2-162)
Aug 26 14:43:25 hypr kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C2.TPL1], AE_NOT_FOUND (20230331/dswload2-162)
Aug 26 14:43:25 hypr kernel: ACPI BIOS Error (bug): Failure creating named object [\B2PT], AE_ALREADY_EXISTS (20230331/dsfield-637)
Aug 26 14:43:25 hypr systemd-vconsole-setup[156]: /usr/bin/setfont failed with exit status 71.
Aug 26 14:43:25 hypr systemd-vconsole-setup[315]: /usr/bin/setfont failed with exit status 71.
Aug 26 14:43:27 hypr systemd-vconsole-setup[557]: /usr/bin/setfont failed with exit status 71.
Aug 26 14:43:29 hypr kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Aug 26 14:43:29 hypr bluetoothd[639]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
Aug 26 14:43:29 hypr bluetoothd[639]: Failed to clear UUIDs: Failed (0x03)
Aug 26 14:43:29 hypr bluetoothd[639]: Failed to add UUID: Failed (0x03)
Aug 26 14:43:29 hypr bluetoothd[639]: Failed to set mode: Failed (0x03)
Aug 26 14:43:32 hypr sddm-helper[1288]: gkr-pam: unable to locate daemon control file
Aug 26 14:43:32 hypr systemd[1291]: Failed to start Profile-sync-daemon.
β–‘β–‘ Subject: A start job for unit UNIT has failed
β–‘β–‘ Defined-By: systemd
β–‘β–‘ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
β–‘β–‘
β–‘β–‘ A start job for unit UNIT has finished with a failure.
β–‘β–‘
β–‘β–‘ The job identifier is 26 and the job result is failed.
Aug 26 14:43:37 hypr bluetoothd[639]: Failed to add UUID: Failed (0x03)
Aug 26 14:44:09 hypr bluetoothd[639]: Failed to remove UUID: Failed (0x03)
Aug 26 14:44:19 hypr bluetoothd[639]: Failed to add UUID: Failed (0x03)
Other notebook, befor update
jctl
Aug 26 18:55:10 hypr kernel: integrity: Problem loading X.509 certificate -65
Aug 26 18:55:10 hypr systemd-vconsole-setup[209]: /usr/bin/setfont failed with exit status 71.
Aug 26 18:55:11 hypr kernel: amd_gpio AMDI0030:00: Invalid config param 0014
Aug 26 18:55:11 hypr systemd-vconsole-setup[382]: /usr/bin/setfont failed with exit status 71.
Aug 26 18:55:11 hypr kernel: ACPI Error: No handler for Region [ECSI] (00000000164da4ff) [EmbeddedControl] (20230331/evregion-130)
Aug 26 18:55:11 hypr kernel: ACPI Error: Region EmbeddedControl (ID=3) has no handler (20230331/exfldio-261)
Aug 26 18:55:11 hypr kernel: ACPI Error: Aborting method \_SB.UBTC.ECRD due to previous error (AE_NOT_EXIST) (20230331/psparse-529)
Aug 26 18:55:11 hypr kernel: ACPI Error: Aborting method \_SB.UBTC._DSM due to previous error (AE_NOT_EXIST) (20230331/psparse-529)
Aug 26 18:55:11 hypr kernel: ucsi_acpi USBC000:00: ucsi_acpi_dsm: failed to evaluate _DSM 2
Aug 26 18:55:13 hypr kernel: Error: Driver 'rtw89_8852ae' is already registered, aborting...
Aug 26 18:55:13 hypr systemd-vconsole-setup[656]: /usr/bin/setfont failed with exit status 71.
Aug 26 18:55:15 hypr bluetoothd[715]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
Aug 26 18:55:15 hypr bluetoothd[715]: Failed to clear UUIDs: Failed (0x03)
Aug 26 18:55:15 hypr bluetoothd[715]: Failed to add UUID: Failed (0x03)
Aug 26 18:55:15 hypr bluetoothd[715]: Failed to set mode: Failed (0x03)
Aug 26 18:55:19 hypr sddm-helper[1362]: gkr-pam: unable to locate daemon control file
Aug 26 18:55:20 hypr kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Aug 26 18:55:21 hypr bluetoothd[715]: Failed to add UUID: Failed (0x03)
Packages (10) fastfetch-2.0.5-1  hyprland-git-0.28.0.r100.299d201e-1  lib32-glu-9.0.3-1  lib32-libdrm-2.4.116-1  lib32-libxcb-1.16-1  libpamac-aur-11.6.1-0  libzip-1.10.1-1
              qt5-base-5.15.10+kde+r147-2  vulkan-headers-1:1.3.262-1  wlroots-git-0.17.0.r6571.717ded9b-1
hyprland-git 0.28.0.r100.299d201e-1 … so it is bug ?? and need to wait for next update(hyprland-git)… there is no problem in hyprland config right?
IDK, if your config is ok. :wink:
But the problem comes from some update file today.
Yes, please.
Well, the developers behind hyprland is very active, I find a new update on hyprland-git almost everyday :slightly_smiling_face: .
yeah same
A post was split to a new topic: Brave or chromium base browser that search bar text is too small
Check your monitor line in hyprland.conf, ran thru this this mornining.
Use hyprctl monitors. First I renamed my hyprland.config and after killing that pid for sddm i could log back into hyprland, but with plain autogenerated conf file. Than i knew it's the conf file and had a closer look, just commenting out the monitor line should get you back in.
Welcome :slight_smile:
The login work, but it needs some seconds. Black screen, cursor in center of the screen.
Before the update the login work normal.
So the hyprland.conf is ok. At least for me.
I had it actually on 2 Laptops, both had a monitor line like
and after getting all that info from hyprctl I setup a monitor specific line like
monitor=eDP-1, 1920x1080@60, 0x0, 1
and that fixed the freeze on 2 laptops.
It is actually already since 2 days, i just didnt bother to look at it , snapped back and was thinking to wait on an update, that came this morning and didnt bring any change to my problem.
I actually bought a new laptop just for Garuda-Hyperland, because it's just so awesome. I just dont have to much time to spent with. You guys doing a great job there!
Thank you for this more detailed explanation. :slight_smile:
So far my attempts to get it to work via these "arandr" values had failed, especially on my second notebook.
xrandr --output eDP --primary --mode 2880x1800_90.00 --pos 0x0 --rotate normal
Seems, something change again in Hyprland :smiley:
I will try it tomorrow.
Recommended rule for quickly plugging in random monitors:
:smiley:
In case I haven't mentioned it yet, for Hyprland it is recommended to use it in dual boot or to have a live ISO (ventoy.net) with Garuda Linux at hand :slight_smile:
But the latter can always be used to chroot all other DE's.
Actually, with the default values Hyprland itself should read and use everything correctly, but it does not.
With the taken values of hyprctrl monitors it works again as @veitw wrote.
Quite strange :smiley:
If this should affect more people in the long run, one would have to open an issue, or I write a script for it. Which is never easy for me :smiley:
hyprland-git update to r101 do not fix it, only first boot work.
The values from
hyprctl monitors
Monitor eDP-1 (ID 0):
	2880x1800@90.000000 at 0x0
	description: California Institute of Technology 0x1402 (eDP-1)
	make: California Institute of Technology
	model: 0x1402
	serial:
	active workspace: 2 (2)
	special workspace: 0 ()
	reserved: 0 40 0 0
	scale: 1.50
	transform: 0
	focused: yes
	dpmsStatus: 1
	vrr: 0
must be this
monitor=eDP-1, 2880x1800@90, 0x0, 1.5
But on first boot after fresh install scale is 1 not 1.5.
I changed it to 1.5, I can not read anything on scale 1 :smiley:
Looks like it is easier if the user DIY and not a script extract the values with grep, awk .. for one and up to X monitors :smiley:
If they can't do it at Hyprland, then I certainly can't.
xrandr
xrandr
Screen 0: minimum 16 x 16, current 1920 x 1200, maximum 32767 x 32767
eDP-1 connected 1920x1200+0+0 (normal left inverted right x axis y axis) 300mm x 190mm
   1920x1200     89.91*+
   1600x1200     89.91
   1440x1080     89.93
   1400x1050     89.92
   1280x1024     89.91
   1280x960      89.91
   1152x864      89.80
   1024x768      89.72
   800x600       89.85
   640x480       89.73
   320x240       87.89
   1680x1050     89.94
   1440x900      89.83
   1280x800      89.89
   1152x720      89.83
   960x600       89.70
   928x580       89.74
   800x500       89.80
   768x480       89.62
   720x480       89.45
   640x400       89.60
   320x200       87.62
   1920x1080     89.93
   1600x900      89.88
   1368x768      89.74
   1280x720      89.80
   1024x576      89.65
   864x486       89.72
   720x400       89.87
   640x350       89.05
working
Seems, they can’t do it, too.
identical behavior with my system too... (2023 LG gram 16 2-in-1)... I just wait a few seconds and all then works fine.
You can fix it,
This is a issue with WL_ROOTS check here
Edit: So something really weird I found out. the 10s black screen goes alway almost instantly if I move the mouse (while the screen is black) to ontop of the waybar.... Maybe I am wrong and this is a Hyprland issue after all.
For example, if you follow the github issue link, you will see that it also affects other distributions or hyprland, screen resolutions other than 1920x1080 px or multiple screens, taking the values from hyperctl monitors fixes the problem. I have created a script that puts these values in hyprland.config. It is included in the ISO from today.
