Aegon
14 January 2022 14:28
1
Hi everyone.
I have been using Garuda gnome since a year now. Today I thought of trying out KDE dragonized and I installed.
It installed and I succefully logged back in. I tweaked a littlebit in dock, panel and icons. I updated the system but when i restart it doesn' t bootup. It loads grub bootloader and thereafter it only shows:
Loading Linux Kernel-Zen
Loading initial ramdisk
I reinstalled again but same problem.
Any idea?
filo
14 January 2022 14:34
2
Can you provide your inxi -Faz using the live USB?
Have you tried booting into a snapshot? Or are they also inaccessible?
Aegon
14 January 2022 14:43
4
Yeah just now but I am not sure what happened previously.
Aegon
14 January 2022 14:45
5
I dont know how to do that. I just booted up using snapshot.
filo
14 January 2022 14:47
6
A snapshot is ok, of course.
Open a terminal, enter inxi -Faz copy the results and paste theme here, with
before and after (to make a text block)
SGS
14 January 2022 14:48
7
Please post full ISO name too.
Aegon
14 January 2022 15:02
8
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=7d65090b-4b71-401f-9fc2-472c05d27556 rw rootflags=subvol=@
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
Mobo: HP model: 81EC v: 61.61 serial: <superuser required>
UEFI-[Legacy]: Insyde v: F.49 date: 06/26/2020
ID-1: BAT1 charge: 28.1 Wh (94.9%) condition: 29.6/41.4 Wh (71.5%)
volts: 17.1 min: 14.8 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Charging
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 400/2800 scaling: driver: intel_pstate
governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 19200
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
Radeon 520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
Device-3: Chicony HP TrueVision HD type: USB driver: uvcvideo
bus-ID: 1-5:8 chip-ID: 04f2:b56c class-ID: 0e02 serial: <filter>
loaded: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:b723 class-ID: 0280
bus-ID: 1-4:3 chip-ID: 0bda:b008 class-ID: e001 serial: <filter>
Local Storage: total: 238.47 GiB used: 12.94 GiB (5.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Faspeed model: K5-256G
type: SSD serial: <filter> rev: 232P scheme: MBR
ID-1: / raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
used: 12.94 GiB (5.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-3: /var/log raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-4: /var/tmp raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.66 GiB used: 3.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C pch: 32.5 C mobo: 27.8 C gpu: radeon
temp: 31.0 C
Processes: 210 Uptime: 27m wakeups: 1 Memory: 7.66 GiB
used: 2.67 GiB (34.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1145 lib: 294 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11~~~
filo
14 January 2022 15:12
10
Do you have any way to disable in the BIOS the AMD GPU?
There are often kernel regressions there. E.g. (today, 5.16):
https://bugzilla.kernel.org/show_bug.cgi?id=215492
FGD
11
Out of curiosity, when you do the install from USB which video drivers do you select from the USB boot menu? Standard non-NVIDIA or Proprietary NVIDIA drivers?
Aegon
14 January 2022 15:13
12
I did not selected nvidia drivers.
Aegon
14 January 2022 15:16
13
I dont think i can because it is an old model.
filo
14 January 2022 15:17
14
To rule out a kernel problem, you could try installing the linux-lts kernel
Aegon
14 January 2022 15:18
15
Can I install it from Garuda assistant?
filo
14 January 2022 15:19
16
Yes, but I always go for the terminal:
Otherwise Garuda Settings Manager - > Kernels - > push Refresh - > select kernel to install
Aegon
14 January 2022 15:22
18
I will clean install and will follow your instruction and will inform you.
Heartly thank you for your support.
Aegon
14 January 2022 15:23
19
Its the latest garuda dragonized edition not blackarch not gaming edition. Only garuda dragonized.
SGS
14 January 2022 15:30
20
That doesn't help, the last one will be the second to last one tomorrow.
There are developer versions that resourceful people download, and sometimes they are not bug-free.
So only the full ISO name helps here.
garuda-sway-linux-zen-220101.iso
or
garuda-dr460nized-linux-zen-220114.iso
