Hi im new in Garuda.
Please help i don't open Microsoft-Edge in Garuda Gaming KDE.
Install for pamac GUI for chaotic.
Explain?
More detail?
Hi TilliDie.
I have just installed it from pamac and run it, but it doesn't open.
It should be noted that I am a little new in this world of Arch and all that.
Yes, no need for edge, use FireFox, LibreWolf or our beloved FireDragon ![]()
If you start edge from terminal maybe you see the error.
I think this is an excellent decision on your part.
If, on the other hand, you want to open it, please open a terminal and run it from the terminal. There should some output that appears there. Post that output here.
Open on terminal.
(microsoft-edge-dev:33135): Gtk-WARNING **: 13:41:20.438: Theme parsing error: gtk-dark.css:6342:10: 'height'
is not a valid property name
[0908/134120.647383:ERROR:elf_dynamic_array_reader.h(61)] tag not found
[0908/134120.647519:ERROR:elf_dynamic_array_reader.h(61)] tag not found
[0908/134120.648023:WARNING:minidump_to_upload_parameters.cc(36)] duplicate key guid, discarding value 6b2e05c
6e81a4b6088e4b6a9052ad5f2
fish: Job 1, 'microsoft-edge-dev' terminated by signal SIGTRAP (Trace or breakpoint trap)
https://aur.archlinux.org/packages/microsoft-edge-dev-bin/
There seem to be some comments on crashes with the latest version.
It should be noted that in pure Arch it opens without any problem, since I did the test from another pc where I have Arch with KDE.
Can we have your inxi -Fza
Are both the Arch machine and garuda machine fully updated?
On a rolling base like Arch, the library versions are constantly shifting.
Yes, everything is up to date.
It works for me here on an updated Garuda Dr460nized.
Did you try the beta instead of the development build?
This is buggy, as already reported in AUR. So, remove it with
sudo pacman -R microsoft-edge-dev-bin
And install Beta
pamac install microsoft-edge-beta-bin
(microsoft-edge-beta:221337): Gtk-WARNING **: 18:25:02.087: Theme parsing error: gtk-dark.css:6342:10: 'height
' is not a valid property name
[0908/182502.190756:ERROR:elf_dynamic_array_reader.h(61)] tag not found
[0908/182502.190883:ERROR:elf_dynamic_array_reader.h(61)] tag not found
[0908/182502.191321:WARNING:minidump_to_upload_parameters.cc(36)] duplicate key guid, discarding value eece73e
2dda14056b70fb9e7d47e7893
fish: Job 1, 'microsoft-edge-beta' terminated by signal SIGTRAP (Trace or breakpoint trap)
What does ldd microsoft-edge-beta show?
EDIT: As a side note, I get all those same errors in the terminal. However the application opens and works for me on Garuda.
Charly don't you know, Microsoft doesn't want programs that work great, they want programs that look great.
Shamelessly stolen from the old Starkist Tuna commercials (for those old enough to remember the golden days of advertising).
what I want is to download everything I have on edge and export it to firefox just for that I want it
Open on terminal.
(microsoft-edge-beta:69544): Gtk-WARNING **: 20:16:09.901: Theme parsing error: gtk-dark.css:6342:10: 'height'
[0908/201610.086437:ERROR:elf_dynamic_array_reader.h(61)] tag not found
[0908/201610.086569:ERROR:elf_dynamic_array_reader.h(61)] tag not found
[0908/201610.087065:WARNING:minidump_to_upload_parameters.cc(36)] duplicate key guid, discarding value eece73e
