Hello.
I am using NVIDIA gpu (1650 SUPER), and i'm having the same problem in live cd as in installed environment. The problem is in the scaling option that in the settings doesn't make any changes, and the scale is too large to be usable (i'm getting this problem only on garuda, using manjaro was ok)
here is the screenshot: Desktop-001 — ImgBB
garuda-inxi:
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 11.2.0
root=UUID=0b94ce5d-d009-4332-bc02-3fada2edb47c rw
[email protected] quiet quiet splash
resume=UUID=85344af1-a402-4e3a-9a67-f0d7d08c8d75
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3
info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A
Mobo: ASUSTeK model: PRIME B560M-K v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends
v: 1203 date: 10/27/2021
Info: model: Intel Core i5-10400F bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: 0xA5 (165)
stepping: 3 microcode: 0xEC
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12
smt: enabled cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
Speed (MHz): avg: 4206 high: 4295 min/max: 800/4300
scaling: driver: intel_pstate governor: performance
cores: 1: 4053 2: 4288 3: 4201 4: 4148 5: 4206 6: 4200
7: 4295 8: 4290 9: 4203 10: 4193 11: 4203 12: 4202
bogomips: 69597
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1
sse4_2 ssse3
Type: spectre_v1 mitigation: usercopy/swapgs barriers
and __user pointer sanitization
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER]
vendor: ASUSTeK driver: nvidia v: 510.68.02
alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2187 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 with: Xwayland
v: 22.1.1 compositor: kwin_x11 driver: X: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 304
s-size: 321x90mm (12.64x3.54") s-diag: 333mm (13.13")
Monitor-1: DP-1 pos: primary,left res: 1920x1080
hz: 60 dpi: 305 size: 160x90mm (6.3x3.54")
diag: 184mm (7.23") modes: N/A
Monitor-2: DVI-D-0 pos: primary,right res: 1920x1080
dpi: 102 size: 480x270mm (18.9x10.63")
diag: 551mm (21.68") modes: N/A
OpenGL:
renderer: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 510.68.02 direct render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:f0c8
Device-2: NVIDIA TU116 High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:1aeb class-ID: 0403
Device-3: BEHRINGER GmbH UMC202HD 192k type: USB
driver: snd-usb-audio bus-ID: 1-4:2 chip-ID: 1397:0507
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen
running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK
driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6
chip-ID: 8086:15fa class-ID: 0200
Device-2: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS]
type: USB driver: r8188eu bus-ID: 1-14:5
chip-ID: 2357:010c class-ID: 0000 serial: <filter>
IF: wlp0s20f0u14 state: up mac: <filter>
Local Storage: total: 2.95 TiB used: 22.52 GiB (0.7%)
SMART Message: Unable to run smartctl. Root privileges
required.
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial
model: CT480BX500SSD1 size: 447.13 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 041 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate
model: ST2000DM008-2FR102 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: 0001
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial
model: CT120BX300SSD1 size: 111.79 GiB block-size:
type: SSD serial: <filter> rev: 010 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD6400AAKS-22A7B2 size: 596.17 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 3B01 scheme: MBR
ID-1: / raw-size: 91.71 GiB size: 91.71 GiB (100.00%)
used: 22.52 GiB (24.6%) fs: btrfs dev: /dev/sda7
maj-min: 8:7
ID-2: /boot/efi raw-size: 300 MiB
size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 91.71 GiB
size: 91.71 GiB (100.00%) used: 22.52 GiB (24.6%)
fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-4: /var/log raw-size: 91.71 GiB
ID-5: /var/tmp raw-size: 91.71 GiB
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8 GiB
used: 0 KiB (0.0%) priority: -2 dev: /dev/sda6
maj-min: 8:6
ID-2: swap-2 type: zram size: 15.48 GiB
used: 2.5 MiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia
temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 301 Uptime: 6m wakeups: 0 Memory: 15.48 GiB
used: 3.35 GiB (21.6%) Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 1823 lib: 520 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-04
Last full system update: 2022-05-04
