over the last few days my pc will lag and become totally unusable if i press any button or do anything at all whilst its slowing down/jittering. Usually, one screen is ok- my secondary screen does not lock up until a min later (if i leave it that long).
It feels like i am over loading my pc with tabs and programs but im not doing anything out of the norm
i have tried other kernels but, again, i have changed nothing from when it was working at full fluency.
output of innx fizza:
System: Kernel: 5.10.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=8385376e-058c-4190-b13c-0411b1ce92e4 rw rootflags=subvol=@ quiet splash
resume=UUID=25f83cb9-6cfa-4fc0-9ebb-5459b0de6e09 loglevel=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x serial: <filter>
UEFI [Legacy]: American Megatrends v: 5220 date: 09/12/2019
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92211
Speed: 3660 MHz min/max: 1550/3850 MHz boost: enabled Core speeds (MHz): 1: 3660
2: 3715 3: 3473 4: 3498 5: 3711 6: 3678 7: 3799 8: 3704 9: 3837 10: 3476 11: 3424
12: 3722
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] vendor: Gigabyte driver: nvidia
v: 460.39 alternate: nouveau,nvidia_drm bus ID: 09:00.0 chip ID: 10de:1b83
class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1431 s-dpi: 101 s-size: 967x360mm (38.1x14.2")
s-diag: 1032mm (40.6")
Monitor-1: DP-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DVI-D-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
diag: 547mm (21.5")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 09:00.1 chip ID: 10de:10f0 class ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 0b:00.3 chip ID: 1022:1457 class ID: 0403
Device-3: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-3:2
chip ID: 046d:081b class ID: 0102 serial: <filter>
Sound Server: ALSA v: k5.10.15-zen1-1-zen
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: f000 bus ID: 03:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000 bus ID: 08:00.0
chip ID: 8086:2723 class ID: 0280
IF: wlp8s0 state: up mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-6:3
chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 1.25 TiB used: 78.41 GiB (6.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS256GSSD370S size: 238.47 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 6KB scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-08WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A02 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SSD PLUS 120GB size: 111.8 GiB
serial: <filter> rev: 00RL scheme: MBR
Partition: ID-1: / raw size: 94.61 GiB size: 94.61 GiB (100.00%) used: 78.41 GiB (82.9%)
fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-2: /home raw size: 94.61 GiB size: 94.61 GiB (100.00%) used: 78.41 GiB (82.9%)
ID-3: /var/log raw size: 94.61 GiB size: 94.61 GiB (100.00%) used: 78.41 GiB (82.9%)
ID-4: /var/tmp raw size: 94.61 GiB size: 94.61 GiB (100.00%) used: 78.41 GiB (82.9%)
ID-1: swap-1 type: partition size: 17.19 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc2 maj-min: 8:34
ID-2: swap-2 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
ID-3: swap-3 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
ID-10: swap-10 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram8
ID-11: swap-11 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram9
ID-12: swap-12 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram10
ID-13: swap-13 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram11
Sensors: System Temperatures: cpu: 43.6 C mobo: N/A gpu: nvidia temp: 57 C
Info: Processes: 347 Uptime: 4m wakeups: 0 Memory: 15.63 GiB used: 2.86 GiB (18.3%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1823
lib: 549 Shell: fish v: 3.1.2 default: Bash v: 5.1.4 running in: alacritty
inxi: 3.3.01
