Hi there,
I have a LaserJet Pro MFP M426fdw. This printer used to work perfectly when I was a Manjaro Gnome user, but for reasons I don't understand, I can't seem to get it working in Garuda Gnome. Whenever I print a document, the printer outputs a page reading:
URP Error
Subsystem: Parser
Error: Internal Overflow or Insufficient Memory
File name: urp_urf_processor.c
Line number: 743
In Gnome's Setting panel, I can see that the printer is showing as: "HP LaserJet MFP M426fdw, driverless" (is the fact that it doesn't show as "Pro" relevant?). I've tried removing and reinstalling the printer, but that doesn't seem to have an effect.
What else should I be trying?
How is the printer connected and thru which protocol?
The only result I found with that error message is Error: Internal Overflow or Insufficient Memory - HP Support Community - 5815740 (though that is another model and on MacOS), there’s no reply from the original poster, anyway the advice there is to use JetDirect.
Although not about an HP, there may be something useful here: Setting up a network printer
P.S. inxi would not hurt.
The printer is connected over wifi.
Here's my inxi:
CPU: 12-core AMD Ryzen 9 5900X (-MT MCP-) speed/min/max: 3289/2200/4950 MHz
Kernel: 6.2.13-zen-1-zen x86_64 Up: 1d 2h 24m Mem: 18274.1/32005.6 MiB (57.1%)
Storage: 465.76 GiB (51.6% used) Procs: 516 Shell: fish inxi: 3.3.26
Reminder
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively, read the tips on the Garuda Wiki:
Your model should be fully supported by hplip.
Have you tried reinstalling it with the relevant tool?
https://wiki.archlinux.org/title/CUPS/Printer-specific_problems#HPLIP
╭─s76v2@s76v2 in ~ took 527ms
╰─λ garuda-inxi
root=UUID=542d3ca9-5005-47ad-85d9-21e20ee155e6 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
Type: Desktop Mobo: System76 model: Thelio Mira v: thelio-mira-r2
serial: UEFI: American Megatrends v: 4403
date: 04/27/2022
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2361 high: 2878 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2532 2: 2434
3: 2200 4: 2872 5: 2200 6: 2597 7: 2200 8: 2194 9: 2197 10: 2200 11: 2196
12: 2196 13: 2200 14: 2200 15: 2872 16: 2603 17: 2878 18: 2690 19: 2200
20: 2194 21: 2216 22: 2200 23: 2194 24: 2200 bogomips: 177260
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: PNY
status: current (as of 2023-03) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.0
chip-ID: 10de:2216 class-ID: 0300
Device-2: HD WEBCAM type: USB driver: snd-usb-audio,uvcvideo bus-ID: 5-1:7
chip-ID: 1d6c:0103 class-ID: 0102 serial:
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 6000x1440 s-dpi: 96 s-size: 1588x381mm (62.52x15.00")
s-diag: 1633mm (64.29")
Monitor-1: DP-0 pos: bottom-l res: 2560x1080 hz: 60 dpi: 79
size: 820x350mm (32.28x13.78") diag: 892mm (35.1") modes: N/A
Monitor-2: HDMI-0 pos: primary,top-right res: 3440x1440 hz: 50 dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.15") modes: N/A
missing.
Device-1: NVIDIA GA102 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel bus-ID: 5-1:7 chip-ID: 1d6c:0103 pcie:
gen: 1 class-ID: 0102 speed: 2.5 GT/s serial: lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-3: HD WEBCAM type: USB driver: snd-usb-audio,uvcvideo
Device-4: Razer USA Seiren Mini type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4:4 chip-ID: 1532:0531
class-ID: 0300 serial:
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api with: aoss
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608
IF: wlp4s0 state: up mac:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
IF: enp5s0 state: down mac:
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac:
Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-6:3 chip-ID: 0e8d:0608 class-ID: e001 serial:
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 465.76 GiB used: 240.54 GiB (51.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
lanes: 4 type: SSD serial: rev: 3B2QGXA7 temp: 37.9 C scheme: GPT
used: 240.54 GiB (51.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 46.8 C mobo: N/A gpu: nvidia temp: 47 C
Processes: 517 Uptime: 1d 2h 47m wakeups: 1 Memory: 31.26 GiB
used: 16.69 GiB (53.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1716
libs: 525 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.26
System install date: 2022-07-03
Last full system update: 2023-04-30
Reinstalling the printer with: hp-setup -u
This worked and solved the issue. Thank you so much!
system
Closed
4 May 2023 16:53
8
