i think i have a 8 or 9. gen xbox controller and i just wanna play stk fh5 etc. . How can i do it?
Not sure what your model is exactly, but you might need an adapter like https://www.newegg.com/p/2TP-004R-003K1
You might need AUR (en) - xboxdrv i had to use it in the past.
bro, Open garuda welcome–> Garuda gamer → “Gamer” tab → scroll at bottom on “controller” section. There can choose controller drivers.
Im using xpadneo-dkms.
Note: I had to update the Xbox controller firmware for it to work properly via Bluetooth.
i did but not solved
i dont have bt on my pc im connecting with a usb a to usb c
i didnt work too
- If you haven’t read it yet, do it now:
Please post your
garuda-inxias requested by the template. -
It would be useful to explain WHAT exactly isn’t working. This is not an error description:
Otherwise, this is just pure guesswork.
