Hello Garuda users.
Installed Packages
wayland , wayland-protocols , wayland-utils,eglwayland,kwayland,kwayland-server,xorg-xwayland,qt5-wayland, qt6-wayland,lib32-wayland
And Rebooted still SDDM dont show any option for login in Wayland session but it shows for weston
Is Wayland force disabled on kde-nvidia garuda ?
If not how to enable it ?
filo
26 May 2022 08:29
#2
As far as the KDE+Wayland is concerned, I think you're missing plasma-wayland-session.
See e.g. (but there are many topics about it in the forum)
Then install plasma-wayland-session and change to plasma wayland from the log in screen.
Edit: I just noticed the link you posted, which included basically the same (I think plasma-wayland-session brings in as dependencies the others). If that didn't work, give a look at this thread:
Just consider that now sddm-wayland-git is called sddm-git
As regards the nVidia aspect, I can't help, but I doubt there is a one-fit-all solution (if a real solution exists at all).
They dont show while creating new topic
Also is reply button broken for forum if user uses firefox ?
i rtap reply button but msgs go without tagging
filo
26 May 2022 08:30
#4
You can and have to use the filters. E.g.:
https://forum.garudalinux.org/search?q=kde%20wayland%20status:solved%20order:latest
Then you can remove "solved", add nVidia, but that is a starting point.
No, I'm using Firefox exactly in this moment (edit: with uBlock origin active for this site)
Please create alphabetical list of sections that have solved post like
Alsa
2)Nvidia
3)Wayland
like it is in arch wiki but instead of articles they point out to solved posts
that would simplify the navigation so much
thanks
I think uBlock origin is blocking too much on garuda (28 requests = 1%) is blocked
filo
26 May 2022 08:35
#7
This is out of the scope of this issue and, in my opinion, users should simply learn to use the forum search features. We cannot accomadate any possible request with solved posts!
Seems you block JavaScript.
system
closed
28 May 2022 09:39
#9
