Here is my garuda-inxi output:
╰─λ garuda-inxi
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "ms_MY.UTF-8",
LC_NAME = "ms_MY.UTF-8",
LC_MONETARY = "ms_MY.UTF-8",
LC_PAPER = "ms_MY.UTF-8",
LC_IDENTIFICATION = "ms_MY.UTF-8",
LC_TELEPHONE = "ms_MY.UTF-8",
LC_MEASUREMENT = "ms_MY.UTF-8",
LC_TIME = "ms_MY.UTF-8",
LC_NUMERIC = "ms_MY.UTF-8",
LANG = "en_MY.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.16.15-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=05323000-3012-4479-b22d-114f8d81f621 rw rootflags=subvol=@
resume=UUID=41bb886d-947b-4425-b7cf-b1746994b7f6 loglevel=3
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1
Type: Laptop System: Notebook product: W740SU v: N/A
Mobo: Notebook model: W740SU serial: <superuser required>
BIOS: American Megatrends v: 4.6.5 date: 09/11/2014
Info: model: Intel Core i7-4770HQ bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x46 (70) stepping: 1 microcode: 0x1C
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2195 high: 2203 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2195 2: 2195 3: 2195
4: 2195 5: 2192 6: 2196 7: 2203 8: 2195 bogomips: 35118
Type: l1tf
Device-1: Intel Crystal Well Integrated Graphics vendor: CLEVO/KAPOK
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:0d26 class-ID: 0300
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x14b6 built: 2015
res: 1920x1080 hz: 60 dpi: 157 gamma: 1.2 size: 310x170mm (12.2x6.69")
diag: 353mm (13.9") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Iris Pro Graphics P5200 (HSW GT3)
v: 4.6 Mesa 22.0.0 compat-v: 3.1 direct render: Yes
Device-1: Intel Crystal Well HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0d0c
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.16.15-zen1-1-zen running: yes
Device-1: Intel Ethernet I217-V vendor: CLEVO/KAPOK driver: e1000e
v: kernel port: f080 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
driver: rtl8723be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 03:00.0 chip-ID: 10ec:b723 class-ID: 0280
bus-ID: 3-4:3 chip-ID: 0bda:b002 class-ID: e001 serial: <filter>
Local Storage: total: 111.79 GiB used: 33.63 GiB (30.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SMS200S3120G
type: SSD serial: <filter> rev: BBF0 scheme: MBR
ID-1: / raw-size: 94.68 GiB size: 94.68 GiB (100.00%)
used: 33.63 GiB (35.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 94.68 GiB size: 94.68 GiB (100.00%)
ID-3: /var/log raw-size: 94.68 GiB size: 94.68 GiB (100.00%)
ID-4: /var/tmp raw-size: 94.68 GiB size: 94.68 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 2.8 MiB (0.0%)
ID-2: swap-2 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 295 Uptime: 1h 6m wakeups: 1 Memory: 15.55 GiB
used: 4.35 GiB (28.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1398 lib: 365 Shell: fish
v: 3.4.1 running-in: yakuake inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2021-06-21
Last full system update: 2022-04-01 ↻
Snapshots: Timeshift
Ok, I want to get a clear instructions on how to enable wayland on my Garuda installation. It is Garuda with KDE and fully updated. I also tried suggestions from this link --> https://forum.garudalinux.org/t/garuda-kde-plasma-wayland-support/17963
But no wayland session.
Thanks for any reply.
