How to dowland Windows11 and garuda in same nvme and what should i do
Hello I am new to linux and i gona a buy pre build windows 11 pc bc of ram prices (built in grapcihs and have just 1 ssd bc of that i gona dowland them the same ssd), and i want to dual boot the garuda and windows 11, and i did watch 1-2 videos but they just say close secure boot, and idk should i make something else more, and they dont say what can happen on or after dual booting. I just want to know what things are dengareus if i dual boot linux and windows 11 at same ssd, what should i close or make except the usb part like what should i close at bios and etc. Sorry for poor english.
Ty. i did try to find but i didnt find and bc of that i did new one. Ty again
I run Windows 10 and Garuda on different disks and that works flawlessly. I can even use an NTFS drive as kind of a shared storage. However, what you are trying could be a bit more tricky…
If you install both on the same disk, you’ll probably have to do the partitioning manually for both. I would install Windows first so it doesn’t break any Linux partitions because it tends to do things “automatically” (read: against your will).
Also this combo might give you some issues because Windows 11 requires TPM and SecureBoot while Linux prefers both to be turned off. I’d probably look into a Windows boot image creator (like Rufus) to make these requirements go away for this kind of setup.
