Hello,
How can I disable a loud beep that occurs when I close the system, or also when I press any key on the board to erase what I had and there is no more space … terrible if you have the headphones.
Thanks.
╭─alnone@alnone in ~ took 7ms
╰─λ inxi Faz
Error 22: Unsupported option: Faz
Check -h for correct useage.
╭─alnone@alnone in ~ took 217ms
[🔴] × inxi -Faz
Kernel: 6.6.23-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=91c0a886-25fe-452a-b52b-00f0e5b90cbe rw rootflags=subvol=@
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Laptop System: Dell product: Inspiron 3583 v: N/A
Mobo: Dell model: 0WHCP7 v: A00 serial: <superuser required> part-nu: 08CA
uuid: <superuser required> UEFI: Dell v: 1.5.1 date: 05/30/2019
ID-1: BAT0 charge: 39.9 Wh (100.0%) condition: 39.9/42.0 Wh (95.0%)
volts: 12.7 min: 11.4 model: SMP DELL VM73283 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
stepping: 0xC (12) microcode: 0xFA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 500 high: 800 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 800
5: 800 6: 400 7: 400 8: 400 bogomips: 28808
Type: gather_data_sampling mitigation: Microcode
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow status: Not affected
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
conditional, RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0
Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0bda:5520
compositor: xfwm4 v: 4.18.0 driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :0.0
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x10ec built: 2017 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (WHL GT2) driver: mesa intel v: 24.0.3-arch1.2
device-ID: 8086:3ea0 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.2 (LLVM
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.6.23-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 238.47 GiB used: 24.24 GiB (10.2%)
model: PC SN520 NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20200012 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 39.58 GiB size: 39.58 GiB (100.00%)
used: 10.58 GiB (26.7%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 1.43 GiB size: 1.43 GiB (99.80%)
used: 210.7 MiB (14.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 39.58 GiB size: 39.58 GiB (100.00%)
ID-4: /var/log raw-size: 39.58 GiB size: 39.58 GiB (100.00%)
ID-5: /var/tmp raw-size: 39.58 GiB size: 39.58 GiB (100.00%)
ID-1: swap-1 type: partition size: 1.42 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C pch: 40.0 C mobo: 35.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 8 GiB available: 7.63 GiB used: 2.64 GiB (34.6%)
Processes: 281 Power: uptime: 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.04 GiB services: power-profiles-daemon,
upowerd, xfce4-power-manager Init: systemd v: 255 default: graphical
Packages: pm: pacman pkgs: 1461 libs: 433 tools: octopi,paru,yay
pm: flatpak pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Bash
v: 5.2.26 running-in: xfce4-terminal inxi: 3.3.33
╭─alnone@alnone in ~ took 1s
╰─λ
