I am new to linux community. I have dual booted linux along with windows 10 so as to have real experience of linux instead of VM. currently I am having kali linux on my machine. Few days ago i saw garuda linux review over YouTube.
So i alloted 50GB of my SSD for garudalinux like i did before for Kali. Basically i wanted to switch from kali to garuda gnome. I tried every tutorial and did my level best to create partitions for garuda. But i failed for 4 time. Can anyone tell me brief info about how can i dual boot garudalinux.
For ssd space allocation i used Disk Management (windows 10 default program) and took 50GB from main ssd partition.
I just wanted to about how many partition and how much space should i give from my 50gb partition in garuda installer as i don't want to mess with my windows.
Do I need to create / /home swap in the manual disk partition from garuda installer.
And what should be the file type ext4 or btfrs for these partition.
When i was trying to install it manly wants a partition with /mount point and fat32 with /boot/efi flag enabled.
I want to dual boot.I am on UEFI. Issue is that linux does not boot after installation simply because something wrong with my installation.
I have a question regarding boot FAT32. I read articles which states that do not mess with boot partition if you already have other os installed just make changes in default partition.
If i create a new partition of 300mb fat32 then will my machine boot? As it will detect that there are two boot partition with different location.
But for boot efi garuda setup throws a popup that a fat32 and /boot/efi is necessary. It will throw popup if i will use btfrs.
As you are sure it will not create any problem if i create another 300mb partition for boot efi I'll do that.
And i also have a problem when i create a bootable USB for gnome ultimate edition balena etcher shows one error that "physical drive...." I am using SanDisk 8GB usb stick. It does not show any error for kali.
But for garudalinux and ubuntu it throws 1 file error.
You are most probably trying to make a bootable usb from iso from same drive or through usb ports or something. Try copying the iso to ssd and then use etcher.
Yes you should definitely make a swap. The best option for you is take that 50 gb partition and cut it into 3 parts, one of 500mb, one of 5 gb and one of rest of storage.
Make 500 mb one as boot / efi, make 5gb one swap and 44.5 gb one as btrfs.
No luck. It's still the same. But i appreciate this forum solving every issue.
I have a thought in my mind do i need to enable bios-grub flag enabled along with boot flag in 500mb partition.
And let me know if i have to turn on any flag in my partition (mount point as /).
