Hello,
So I have two drives in my laptop, a 128gb nvme ssd and a 1tb 2.5" ssd. I want to use the fast nvme ssd for the system, but I want to use the 2.5" ssd for Steam games. I have done some searching the web and am left confused. How do i mount the 2.5" ssd as a subvolume on the same filesystem to home/{username}/Games/steam? I do not want to use raid or let the system drive "merge" with the steam drive through rebalancing the file system. When looking it up, would $ btrfs device add /dev/sda /home/{username}/Games/steam make the system files spread over to the steam drive? I mean like the system files from / take space on the Steam drive? I have installed Garuda to the nvme ssd already, I just need to setup steam.
I could be completely wrong. Sorry for the dumb question. Any response is appreciated!
inxi -Faz
System: Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c0bcb0ff-64d7-499b-82cd-de923c5e7197
systemd.unified_cgroup_hierarchy=1 resume=UUID=a296e8ec-2bfa-461e-a12b-701ef574ce31 loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: G3 3500 v: N/A serial: <filter> Chassis: type: 10
Mobo: Dell model: 0X4NG0 v: A00 serial: <filter> UEFI: Dell v: 1.9.0 date: 06/01/2021
Battery: ID-1: BAT0 charge: 46.1 Wh (90.4%) condition: 51.0/51.0 Wh (100.0%) volts: 13.1 min: 11.4
model: SMP DELL PN1VN06 type: Li-poly serial: <filter> status: Charging
CPU: Info: Quad Core model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 2 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 39999
Speed: 4251 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 4251 2: 4240 3: 4282 4: 4282
5: 4200 6: 4260 7: 4248 8: 4201
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Dell driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:4
chip-ID: 1bcf:2b99 class-ID: 0e02
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8
class-ID: 0401
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 6000 bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169
v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 8087:0026 class-ID: e001
Drives: Local Storage: total: 1.22 TiB used: 20.73 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530 NVMe WDC 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21112012 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 1T02 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1000 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB model: USB DISK 3.0 size: 57.77 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
Partition: ID-1: / raw-size: 229.41 GiB size: 229.41 GiB (100.00%) used: 20.73 GiB (9.0%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 229.41 GiB size: 229.41 GiB (100.00%) used: 20.73 GiB (9.0%) fs: btrfs
ID-4: /var/log raw-size: 229.41 GiB size: 229.41 GiB (100.00%) used: 20.73 GiB (9.0%) fs: btrfs
ID-5: /var/tmp raw-size: 229.41 GiB size: 229.41 GiB (100.00%) used: 20.73 GiB (9.0%) fs: btrfs
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: swap-2 type: zram size: 7.56 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 48.0 C mobo: N/A
Info: Processes: 290 Uptime: 4m wakeups: 8 Memory: 7.56 GiB used: 1.79 GiB (23.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1678 lib: 505
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
