Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=2a579e0b-5949-4320-b36c-be216438f88f rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: PRIME B350M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5603
date: 07/28/2020
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1766 high: 2445 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2124 2: 1595
3: 1444 4: 1460 5: 2445 6: 1716 7: 2053 8: 1710 9: 1454 10: 1467 11: 1725
12: 2002 bogomips: 81436
vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 0a:00.0
chip-ID: 1002:731f class-ID: 0300
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
model: ViewSonic VX2458 Series serial: <filter> built: 2021 res: 1920x1080
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 600mm (23.6")
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: LED MONITOR
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 15:9, 16:9
OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 13.0.1 DRM 3.44
5.17.9-zen1-1-zen)
v: 4.6 Mesa 22.1.0 direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab38
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
Device-3: ESI Audiotechnik GmbH MAYA22 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.1:4 chip-ID: 2573:0017
class-ID: 0102
Device-4: Kingston HyperX Cloud Flight Wireless Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.4:7 chip-ID: 0951:16c4
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168
Local Storage: total: 2.96 TiB used: 2.02 TiB (68.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: HD103SJ
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD10EZEX-21M2NA0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-1: / raw-size: 122.43 GiB size: 122.43 GiB (100.00%)
used: 27.57 GiB (22.5%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
used: 29.8 MiB (31.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 122.43 GiB size: 122.43 GiB (100.00%)
ID-4: /var/log raw-size: 122.43 GiB size: 122.43 GiB (100.00%)
ID-5: /var/tmp raw-size: 122.43 GiB size: 122.43 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.62 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 3.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 66.0 C
mem: 68.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 482
Processes: 365 Uptime: 39m wakeups: 0 Memory: 15.62 GiB
used: 7.08 GiB (45.3%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1545 lib: 367 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-09
Last full system update: 2022-05-26 ↻
Failed units: bluetooth-autoconnect.service systemd-networkd-wait-online.service
I can't find how to properly mount a ntfs drive to use it with steam, the way they mount by default seems to not allow me to modify files, I can't delete or create files in them from dolphin even with root access, and steam recognizes the library but it can't update games, one of the available updates says "disk write error", but for a split second all of them say that when I try to continue the updates.
I looked around on the internet and most of what I found were people saying not to use ntfs, which isn't really helpful, and only a handful of people saying they got it working and vaguely explaining how, most of them from years ago, stuff as recent as 2019 and as old as 2007.
I tried changing a few things in the "edit mount options" on the included kde partition manager, but everything I could try caused steam to not accept the drive and say something about it needing a disk with execute permission. Unfortunately I can't really say which exact changes I tried, because I was just winging it trying every small change I could find on the internet and trying it in different ways because they were very vague.
I use steam (runtime), I tried installing (native) and it did not make a difference.
In case it's necessary, I know ntfs sucks, I still use windows and have to share some storage.
